raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Sat Feb 03, 2018 8:00 am Post subject: Re: CLK wheels |
Don’t forget to keep a set of front bolts and rear nuts for your steel spare if you don’t have 5 clks. They have different ball seat diameters.
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
Pinetops Samba Member
Posted: Sat Feb 03, 2018 8:42 am Post subject: Re: CLK wheels |
raoul mitgong wrote: |
-d |
I know they probably won't but do clk wheels fit in the stock tire carrier with any size tire? _________________ "A rolling bus gathers no rust." |
Italjohn Samba Member
Joined: October 29, 2016 Posts: 193 Location: Molde, Norway
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4349 Location: United States, Iowa
Posted: Sat Feb 03, 2018 7:31 pm Post subject: Re: CLK wheels |
Pinetops wrote: |
I know they probably won't but do clk wheels fit in the stock tire carrier with any size tire? |
Well, "any size" is pretty vague: simple answer is that if you have only a rim, sure put it in the spare clam.
You got some options, of course. The width of the tire you choose should approximate the original dimensions, which is 185 millimeters. More Vans came with that width from dealer lots, than the wider ones at 195 mm, as far as I've come to understand. Even the 195.75.14D BFG AllTerrain TA's (out of production) would fit in the clamshell, so that was a HUGE Go-To tire for enthusiasts for many years.
I thought I knew where the threads where that described the %'s difference that doing X or Y or Z to tire size/diameter would do to your spare clamshell predicament, but I can't put my fingers on it right now. In general, there are a few options for you, in terms of adapting the clamshell area to a wider tire with a simple mod to the hanger clip and hinges. Simple stuff. I will keep looking, and try to get this linked in here. Don't fret, you'll still have options, and of course you can go to the swingaway on the rear anyway for the spare.
For MANY reasons, I have been a big fan of sticking to the MFG's spec's, not only having to do with how the stock engine performs poorly with larger diameter tires.
Gray areas are more like 50 shades than black/gray/white.
You'll find something that works for you, don't get too antsy. _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Posted: Sun Feb 04, 2018 8:33 am Post subject: Re: CLK wheels |
Thanks for the response.
By "any size" tire I mean are there any sizes that will fit in the clamshell mounted on a clk? Obviously larger sizes will not fit.
I didn't know if it was the size/shape or width of the wheel that preveneted it from fitting or just the outside diameter of the tire (I have never removed the clamshell). From your post it sounds like outer diameter is what matters.
I'd prefer not to mount a spare on the rear hatch. It looks cool, I just don't want to have to swing it away every time I open the hatch spend more than I have to. _________________ "A rolling bus gathers no rust."
Posted: Sun Feb 04, 2018 8:41 am Post subject: Re: CLK wheels |
My tires are 205-65 R16, it fits in my spare holder with just a 3/4” spacer on the front bolt.
Posted: Sun Feb 04, 2018 8:43 am Post subject: Re: CLK wheels |
Excellent, that is the size I was thinking of using. _________________ "A rolling bus gathers no rust." |
benandmj Samba Member
Joined: October 29, 2012 Posts: 550 Location: Atlanta
Posted: Mon Feb 05, 2018 7:42 pm Post subject: Re: CLK wheels |
Just a quick reminder here folks, you MUST remove the two drum retaining bolts prior to mounting CLK’s and many other non stock wheels on your vehicle.
DO NOT expect your tire shop to notice that the rear wheels are not flush or spinning true because the bolts interfere. I’m describing the bolts that are in the location circled below.
_________________ 85 Westfalia Weekender
91 Syncro Westy |
Jim Hunter Samba Member
Joined: February 14, 2014 Posts: 107 Location: MB, Slovenjia
Posted: Tue Feb 06, 2018 3:50 am Post subject: Re: CLK wheels |
Italjohn wrote: |
Finally I found some nice and cheap center caps for my Mercedes rims.
Links to the caps and VW stickers in the decription in the video.
These caps looks great Italjohn !!!
Thanks for sharing your findings , but we need to see them mounted on the car as well!!!
Jim |
katzenjammer Samba Member
Joined: September 22, 2005 Posts: 113 Location: Santa Cruz
Posted: Sat Feb 17, 2018 3:46 pm Post subject: Re: CLK wheels |
Here's a set of rims in northern California for $600 (or maybe it's $1000, kind of hard to tell). If it's $600, that's about how much people are asking for them in the classifieds. The downside is that, as the seller told me when I asked, "the car goes with them."
https://sfbay.craigslist.org/nby/cto/d/1999-mercedes-benz-clk/6495018790.html _________________ 1990 Westy Multivan, Auto (3.08 R&P) 1.8T by SAH |
Posted: Wed Feb 21, 2018 9:00 am Post subject: Re: CLK wheels |
I'm having a hard time finding a fifth CLK rim for my spare. Originally I planned to run a steel wheel for my spare but I realize now I need to do a 5 tire rotation so I'd like the fifth to match. Anyone have any tips for finding a single CLK rim? _________________ 85 Westfalia Weekender
91 Syncro Westy |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed Feb 21, 2018 9:22 am Post subject: Re: CLK wheels |
benandmj wrote: |
I'm having a hard time finding a fifth CLK rim for my spare. Originally I planned to run a steel wheel for my spare but I realize now I need to do a 5 tire rotation so I'd like the fifth to match. Anyone have any tips for finding a single CLK rim? |
https://www.ebay.com/itm/122892647443 |
danfromsyr Samba Member
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Wed Feb 21, 2018 10:26 am Post subject: Re: CLK wheels |
davevickery wrote: |
benandmj wrote: |
I should have mentioned I was aware of a few on eBay. This one is the nicest and cheapest but considering I paid $200 for 4 I can’t stomach that price tag plus the powder coat to match the other 4... _________________ 85 Westfalia Weekender
91 Syncro Westy |
Posted: Wed Feb 21, 2018 10:46 am Post subject: Re: CLK wheels |
Yup, $200 for 4 was a great price. Now folks are lucky to find 4 for $800 _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Oilline Samba Member
Posted: Sat Feb 24, 2018 10:52 am Post subject: Re: CLK wheels |
So I've come across a set of what i am hoping are forged CLK rims, however they are ET33 which to me is better than the ET37.
The part number is 211 401 1102. They are thin section where the lug holes are. 7 x 16.
Can anybody confirm if they are forged and therefore strong enough for my application? |
Posted: Sat Feb 24, 2018 10:57 am Post subject: Re: CLK wheels |
Oilline wrote: |
Yes, those wheels are forged and also made by Fuchs. They are about 7mm thick and they use large ball seat lugs, not large ball seat. You can use the stock front (Syncro) and rear studs, but for a 2wd, you would need slightly longer lug bolts since the stock ones are too short. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sat Feb 24, 2018 11:09 am Post subject: Re: CLK wheels |
Oilline wrote: |
I think your question is answered (“yes”) on page 19 of this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=298574&start=360 _________________ 1990 Westy Multivan, Auto (3.08 R&P) 1.8T by SAH |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
Posted: Sat Feb 24, 2018 11:16 am Post subject: Re: CLK wheels |
Oilline wrote: |
I have those wheels on my syncro (one of the sets I use), and in my opinion they are even better suited than the et37 (CLK) variant. More clearance for tires, and no need for special lug nuts. They were standard on some E-class Mercedes and that is a slightly heavier car than the CLK. Never seen any official weight ratings for them though...
Stock Syncro 16 inch rims were 5,5x16 et34 so reasonably close to that et as well. _________________ 1991 VW Multivan syncro 1,9 TD |
