Luxury Tools
Page: Previous  1, 2, 3, ... 33, 34, 35  Next
Alaric.H
Alaric.H is offline
PostPosted: Fri Sep 17, 2010 7:30 pm    Post subject: Reply with quote
I have a few sets of these.
dhaavers
dhaavers is offline
PostPosted: Fri Sep 17, 2010 9:38 pm    Post subject: Reply with quote
Alaric.H wrote:
I have a few sets of these. <QuikCenter broken bolt remover>
So, which do you find to be most useful? As I'm running pretty much stock, I'm probably in for the fine & coarse metric, & the website says ~30% off right now...
86 White Westy Weekender
"The WonderVan"
Alaric.H
Alaric.H is offline
PostPosted: Sat Sep 18, 2010 4:13 am    Post subject: Reply with quote
I would get both. But 8mm 1.25 is a useful one.
dhaavers
dhaavers is offline
PostPosted: Sat Sep 18, 2010 7:20 am    Post subject: Reply with quote
I just ordered both. At $25 each set I'm already ahead of every other time I needed them (two broken EZ-outs; 3 broken drill bits; week and a half looking for help once & $20 box of steaks for my buddy who finally got the last one done for me...)
Thanks for the tip, Al!
"The WonderVan"
Alaric.H
Alaric.H is offline
PostPosted: Sat Sep 18, 2010 6:17 pm    Post subject: Reply with quote
iltis74
iltis74 is offline
PostPosted: Sun Sep 19, 2010 11:48 am    Post subject: Reply with quote
In my garage that's called a shell cleaner, but used about the same.
Alaric.H
Alaric.H is offline
PostPosted: Wed Oct 06, 2010 3:59 pm    Post subject: Reply with quote
So I am trying out this used thing I got on ebay it is pretty neat.
I tried it out on a few old things hanging around.
This is after 10min
buildyourown
buildyourown is offline
PostPosted: Wed Oct 06, 2010 4:05 pm    Post subject: Reply with quote
I've used these a lot. Very nice to have.
Just don't put your hand in there.
Alaric.H
Alaric.H is offline
PostPosted: Wed Oct 06, 2010 4:34 pm    Post subject: Reply with quote
Now you tell me I did have gloves on.
Corwyn Premium Member
Corwyn is offline
PostPosted: Sun Oct 10, 2010 5:29 pm    Post subject: Reply with quote
Somebody's got WAAAY too much money! Smile
'90 White Westy ("Whirlpool")
FAS Gen V 2.0
The Annual Baja Rally
~ Captain Ron ~
wjjr
wjjr is offline
PostPosted: Sun Oct 10, 2010 7:16 pm    Post subject: Reply with quote
Redneck Version= 1 50 gallon fish tank + 30 gallons water + 1 Heavy Duty Truck Battery or old battery charger + 2 2ft pieces of rebar + 6ft piece of 12-2 wire
Be careful, works great
'90 Vanagon Carat auto x2
'87 Vanagon Gl Syncro
'85 Vanagon Wolfsburg Weekender (poptop)
wiartonallan
wiartonallan is offline
PostPosted: Sun Oct 10, 2010 8:07 pm    Post subject: Reply with quote
Great thread! Just thinking- have and old style paint shaker, sand and a gallon can. Hmm....
wiartonallan
85 Westfalia/Bostig
02 1.8t Jetta
08 Frieghtliner Sprinter
purplepeopleeater
purplepeopleeater is offline
PostPosted: Sun Oct 10, 2010 8:08 pm    Post subject: Reply with quote
Don't laugh, I've done this....doesn't work that great on grease though.
wenholzm
wenholzm is offline
PostPosted: Sun Oct 10, 2010 8:09 pm    Post subject: Reply with quote
My best tool is a machete, you can use it for everything, most versatile invention ever!
Alaric.H
Alaric.H is offline
PostPosted: Sun Oct 17, 2010 8:36 pm    Post subject: Reply with quote
I like this spring hose clamp tool.
Alaric.H
Alaric.H is offline
PostPosted: Mon Oct 18, 2010 5:57 am    Post subject: Reply with quote
This is great for checking break lights and keeping the RPM at a constant rate with only one person.
Alaric.H
Alaric.H is offline
PostPosted: Mon Oct 18, 2010 1:35 pm    Post subject: Reply with quote
Here is a special jig so you can remove the crank pulley while it is still in the van.
dredward
dredward is offline
PostPosted: Mon Oct 18, 2010 7:07 pm    Post subject: Reply with quote
I like these too. Before i was useing vise grips of diff sizes, prob is there are a few where this tool is need due to access....
Cars owned: 1979/89 scirraco, 1983 gti, 1984 gti, 1986 gti, 1990 gli, 1989 cabriolet(2.0,16v conversion), 1992 gti, 1982 Westy, 1987 syncro Westy(w/ 1.8t conversion stg1 chip), and finally 2004 r32....
Alaric.H
Alaric.H is offline
PostPosted: Mon Oct 18, 2010 8:48 pm    Post subject: Reply with quote
Some one was mentioning ball joint and tie rod removal with out damaging the rubber boots.
Alaric.H
Alaric.H is offline
PostPosted: Wed Oct 20, 2010 6:40 am    Post subject: Reply with quote
When working on these things you find a distorted nut here and there and I have used these tools to get them off you hammer it on the offending nut and most times it takes it right off other times it breaks it off.
Page 2 of 35
