Radiator Baffles
unitedracing
unitedracing is offline
PostPosted: Tue Feb 23, 2021 7:11 am    Post subject: Radiator Baffles Reply with quote
Good morning. Do any of you have any experience with these replacement pieces from Go Westy or others? I have a 1983 Diesel The GW kit says it doesn't fit Diesels but it looks exactly like other suppliers that say they do. What have you done. I would make my own, my originals are practically non existent so can't use as a template.
djkeev Premium Member
djkeev is offline
PostPosted: Tue Feb 23, 2021 7:14 am    Post subject: Re: Radiator Baffles Reply with quote
Somewhere in this forum are DIY instructions, even an template!
Where? I dunno.......
I'll see if I can find it.
Meanwhile pick up some left over election signs, they all seem to gone except for a few Trump ones, some night tiptoe to your neighbors and snag it!
Those realtor open house signs will work too!
Dave
Ghia
Vanagon
Beetle
unitedracing
PostPosted: Tue Feb 23, 2021 7:18 am    Post subject: Re: Radiator Baffles Reply with quote
Dave
Thanks. If you find the template i would appreciate it! I've been looking but no dice. I do have some old real estate signs...Massachusetts will arrest you if you touch someones political signs...
JudoJeff
JudoJeff is offline
PostPosted: Tue Feb 23, 2021 7:47 am    Post subject: Re: Radiator Baffles Reply with quote
Dave’s right on the money, that’s what I used for years. You can spray paint them if you don’t want “UMP” showing.
Goal is to block air flow so it only goes through radiator. Don’t overthink it.
I live in Southwick, but snowbird in Florida until May. Can help you when I return.
1989 Vanagon GL Westfalia Camper, Burned up on 7/31/16.
1987 Vanagon GL Westfalia Camper, Bostig & Rebuilt, sold
1986 Vanagon GL Westfalia Camper, Bostig.
unitedracing
PostPosted: Tue Feb 23, 2021 8:29 am    Post subject: Re: Radiator Baffles Reply with quote
Thanks, yes it looks like a great solution. I found the templates on here finally. And hi neighbor! I live in Westfield and grew up in Granby ct so I know Southwick well. When you're back you'll have to check out the van. I'm hoping to have him on the road in a few weeks.
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Feb 23, 2021 8:44 am    Post subject: Re: Radiator Baffles Reply with quote
Some discussion here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=718081&highlight=pattern+baffle
While you're at it - you may also wish to renew the baffles on the backside of the grille:
MarkWard
MarkWard is online now
PostPosted: Tue Feb 23, 2021 9:00 am    Post subject: Re: Radiator Baffles Reply with quote
Our 82 diesel has had a later model radiator and aftermarket dual pass AC condenser installed in the nose. I have an aluminum panel for the bottom of the radiator to seal it, but none of the others panels. As is, the diesel takes quite a while to get to temp, but even at 70mph continuous with the AC cranked, I never see above 190 F engine temp even when the ambient is 100 F.
What's my point? I am not 100 % sure they are worth the effort of fitting them. Do some before and after temp studies when you get them in and report back. Your results may vary.
1982 Vanagon Camper with ALH TDI.
1990 Vanagon Camper Syncro.
In Car https://youtu.be/5hbfdUJR88Q
ZsZ
ZsZ is offline
PostPosted: Tue Feb 23, 2021 9:20 am    Post subject: Re: Radiator Baffles Reply with quote
here is the topic about the templates although the pdfs are taken down
I have saved them before so just will make a dropbox folder or something
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=20
edit: here is my mirror folder of those files of Vanis13
https://www.dropbox.com/sh/jverdl3rbitnzuj/AAAizIU2DUijFPBIINtWf7mHa?dl=0
Zoltan
1.9 MTdi Multivan (ex Caravelle)
Van since 2006, engine since 2008
Vanagon Nut
Vanagon Nut is offline
PostPosted: Tue Feb 23, 2021 11:04 am    Post subject: Re: Radiator Baffles Reply with quote
This.
I ran my '81 (air to gas water cooled) with later style radiator for some years w/o baffles. After installing the GW baffles, I did not see any appreciable and/or repeatable difference at the temp gauge or in fan cycling behaviour.
Possible install error aside, I found I had to adapt a means to attach each GW side piece to body. IIRC I used a giant metal screw to attach each to existing hole in body.
Neil.
1981 Westy air cooled to 15º ABA swap: http://tinyurl.com/y9n4xob8
50º ABA Swap in to '88 Westy: http://tinyurl.com/yap5hpwt
Vanagon VAG GAS engine swap Google Group:
https://tinyurl.com/2f24rmh
VE7TBN
Jeffrey Lee
Jeffrey Lee is offline
PostPosted: Tue Feb 23, 2021 8:31 pm    Post subject: Re: Radiator Baffles Reply with quote
I've installed the GoWesty radiator baffles on a couple of '83 diesel Vanagons, and I do not recall any fitment issues, or modifications required. The '82s may be different. (And I suspect GoWesty's general dislike of the diesel Vanagon sometimes causes their ignorance of the diesel Vanagon.)
Like others, I also detected no measurable difference in cooling efficiency, despite replacing all cooling system parts. But I enjoy greater confidence in the reliability.
Camp Westfalia
Camping Tips • Newsletter • Cool Campervan Apparel
www.CampWestfalia.com
unitedracing
PostPosted: Wed Feb 24, 2021 5:08 am    Post subject: Re: Radiator Baffles Reply with quote
Thanks. Mine is an '83 and was going to try theirs even though they say they don't fit Diesels. I think it should say '82 Diesel. And yes, for such a decent company it's really been annoying how they shit on Diesel vans. I really don't understand that especially seeing the popularity of them and they are in business to make money...why piss off the consumer with attitude??
djkeev is offline
PostPosted: Wed Feb 24, 2021 5:49 am    Post subject: Re: Radiator Baffles Reply with quote
This is going to become a "tomorrow" task.
Time is running short and the to-do list is long.
Dave
Ghia
Vanagon
Beetle
unitedracing
PostPosted: Wed Feb 24, 2021 5:51 am    Post subject: Re: Radiator Baffles Reply with quote
Dave
Dave, I found the information! But thanks much for offering help. I've decided to create my own and save a few $$
