allihjelm Samba Member
Joined: April 29, 2009 Posts: 231 Location: Akureyri, Iceland
Posted: Tue Apr 27, 2010 2:59 am Post subject: What kind of battery meter? |
Hi there.
I'm realizing more and more the imortance of monitoring the battery charge when driving my 6V Bug.
In this light I would be glad if you guys could give me advice on what kind of meter would be the most informative for me. Would it be a voltmeter or an ammeter? And what information should I be looking for in a healthy battery?
Thanks, Al. _________________ 1967 European 6V Volkswagen 1300 Beetle |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Tue Apr 27, 2010 5:20 am Post subject: |
Quote: |
Would it be a voltmeter or an ammeter? |
Voltmeter. Long as the generator is putting out over 6vdc, you're OK. How much the battery is charging? Doesn't matter as long as it's over 6vdc. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
61SNRF Samba Member
Joined: March 29, 2009 Posts: 4657 Location: Whittier 90602
Posted: Tue Apr 27, 2010 7:06 am Post subject: |
You can get inexpensive multimeters at most online tool venders or Radio Shack. They feature both volts, ohms and amps. You can find basic info on meters and batterys at www.howstuffworks.com
Basicly, you can determine the state of charge the battery is in by measuring the voltage at rest after the car has set one hour or more. A good 6v battery will have 6.3v.
With the meter still connected and reading volts, start the car and increase the RPM, the voltage should rise above battery voltage. I don't have the specifications in front of me, but output should be about 6.6 to 7.2 volts with a good generator and regulator. |
Bruce Amacker Samba Member
Joined: December 26, 2007 Posts: 1786 Location: Cleveland, Ohio
Dangermouse Samba Member
Joined: November 23, 2005 Posts: 1266 Location: Beautiful New Zealand
Posted: Tue Apr 27, 2010 1:52 pm Post subject: |
It may help simplify your decision to know that 6V voltmeters (gauges) are practically impossible to find!
If anybody has one of these please PM me
_________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
Wayne S. Johnson Samba Member
Joined: April 12, 2006 Posts: 1265 Location: GILROY, CA
Posted: Tue Apr 27, 2010 3:02 pm Post subject: |
DATEL's DMS-20PC-DCM Series of self-powered, positive-reading, dc voltage monitors
are great replacements for older, hard-to-read, analog panel meters. Simply connect
a positive dc voltage across the rear terminals and the
meters are fully operational — no additional components
or power supplies are required! The large, 0.37"/9.4mm,
LED displays can be easily read from 15 feet away. Four
versions are available: +4.50-19.99Vdc (0.01V resolution),
+8.0-50.0Vdc (0.1V resolution), +30.0-199.9Vdc
(0.1V resolution) and +30-264Vdc (1V resolution).
Built-in reverse polarity protection assures simple,
trouble-free installation. $59
http://www.mouser.com/ProductDetail/Murata-Power-S...MrrpCIY%3d
http://www.murata-ps.com/data/meters/pc0-dcms.pdf
_________________ Additional products https://www.thesamba.com/vw/classifieds/search.php?username=Wayne+S.+Johnson
Additional products with Bluetooth http://www.thesamba.com/vw/classifieds/detail.php?id=2097231 |
Posted: Tue Apr 27, 2010 3:05 pm Post subject: |
Not exactly pretty though _________________ Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you. |
KTPhil Samba Member
Posted: Tue Apr 27, 2010 8:37 pm Post subject: |
I prefer an ammeter, though it is far harder to install. I ran an 8 ga wire form the reg and battery to the meter, and similarly heavier than stock wires to the headlamp switch and relay from there. These are the high-current devices.
A voltmeter tells you you have SOME output form the generator, but it doesn't tell you if you are actualyl charging the battery. Also, the bahavior as it runs, charges, and discharges (like at idle) tells you a lot about the health of your gen. reg, and the draw from devices.
Sometimes a dying battery will draw a very heavy current but not charge. You will still see 6-7V on a voltmeter, so you don't see it coming.
I don't see the value of a voltmeter that the standard idiot light doesn't already tell me. |
Posted: Wed Apr 28, 2010 5:34 am Post subject: |
Quote: |
ran an 8 ga wire form the reg and battery to the meter |
That's alot of un-fused wire running thru the car. Here is some more info, talks about a MGA, but when it comes to cars, electricity is international. The articles say go with the voltmeter also.
http://mgaguru.com/mgtech/electric/et220.htm
http://mgaguru.com/mgtech/electric/et221.htm _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
KTPhil Samba Member
Posted: Wed Apr 28, 2010 8:17 pm Post subject: |
runamoc wrote: |
That's alot of un-fused wire running thru the car. |
No more than in a stock VW. Gotta get it from the batt/reg to the light switch without a fuse. |
Posted: Wed Apr 28, 2010 8:44 pm Post subject: |
Quote: |
Gotta get it from the batt/reg to the light switch without a fuse |
AND back again without a fuse. _________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Posted: Wed Apr 28, 2010 8:55 pm Post subject: |
I have one of these in my possesion but am still debating whether to install it or not; any tips would be welcome...
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Wed Apr 28, 2010 9:42 pm Post subject: |
Cusser wrote: |
Voltmeter is TONS easier to wire up. What's wrong in using your charging light as your warning? |
Problem with that, is by the time the light goes on you are pulling over to the shoulder with a dead VW! BTDT!
Voltmeter shows how the charging system is doing or not, and has warned us several times. Plus having the warning before the engine dies allows one to find a more convenient place to park and fix the problem! _________________ In Stereo, Where Available! |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Wed Apr 28, 2010 10:59 pm Post subject: |
Nerd alert:
After some thinking, I figured there was an easier way to measure DC current than running all that wire. Use a hall effect sensor on the wire you want to monitor, send info to gauge. After some googling:
http://scienceshareware.com/how-to-measure-AC-DC-current-with-a-hall-effect-clamp-.htm
But yeah...Idiot lights are good enough for me. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
