risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Tue Apr 27, 2010 12:29 pm Post subject: Mag case in a 200 degree parts washer ok? |
Wondering if its ok to put a mag case, one half at a time, in a parts washer that gets up to about 200 degrees F. It has a citrus type cleaner in it and has done very well with some aluminum parts before. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Tue Apr 27, 2010 12:32 pm Post subject: |
normal oil temps are 180ºF-210ºFand it's not considered hot until 230ºF, so you will be fine. _________________ Glenn
Member #1009
#BlueSquare |
risk Samba Member
Posted: Tue Apr 27, 2010 12:34 pm Post subject: |
Thanks Glenn!.. didn't think about that.. really my only concern is that the case won't be bolted together.. just wondering if the heat will cause any warpage with it being split. |
Glenn Mr. 010
Posted: Tue Apr 27, 2010 12:51 pm Post subject: |
risk wrote: |
I can't say100%, but I don't think so.... wait for others to post up. _________________ Glenn
Member #1009
#BlueSquare |
millerje78 Samba Amishman
Joined: October 16, 2005 Posts: 2445 Location: Holmes County, Ohio
Posted: Tue Apr 27, 2010 1:26 pm Post subject: |
risk wrote: |
oh goodness no, 200 F is perfectly safe, even with the case halved. _________________ always seeking a better way
my 73 standard project
do your research, consult with experts, and buy quality parts. you won't be sorry |
risk Samba Member
Posted: Tue Apr 27, 2010 2:15 pm Post subject: |
sweet, i will post some before and after pics..
the engine was built about 20 years ago and has been sitting on the shelf ever since.. i split the case and the builder used some kind of heavy grease on the cam that had hardened over time.. what a mess. |
turboblue Samba Member
Joined: October 09, 2003 Posts: 4216 Location: Central Indiana
Posted: Tue Apr 27, 2010 2:44 pm Post subject: Re: Mag case in a 200 degree parts washer ok? |
risk wrote: |
Be sure that solution is compatible with magnesium. _________________ Gary
Turbo VW Sand Drag Buggy
"If you don't run into the Devil every once in awhile, you must be going in the same direction!" |
&Dan Samba Member
Posted: Tue Apr 27, 2010 3:37 pm Post subject: Re: Mag case in a 200 degree parts washer ok? |
turboblue wrote: |
risk wrote: |
Be sure that solution is compatible with magnesium. |
That's good advice- I recently cleaned a Solex carb in heated lemon juice and was shocked and dismayed to pull a very corroded carb out of the soup.
Damn near ruined the thing 'cause I was too dumb to do my homework. |
risk Samba Member
Posted: Thu Apr 29, 2010 8:05 am Post subject: |
Well, i put a magnesium timing gear i had laying around in the washer this morning.. pulled it out after about 45 minutes and it instantly formed a white coating.. uniform etch is what one guy called it. Didn't ruin the part, but made me nervous about the bearing surfaces and case parting line. Don't think i'll be putting the case in there. |
Jake Raby Samba Member
Joined: August 23, 2003 Posts: 7433 Location: Aircooled Heaven USA
Posted: Thu Apr 29, 2010 8:13 am Post subject: Re: Mag case in a 200 degree parts washer ok? |
risk wrote: |
No problem, thats what we use here for final cleaning prior to assembly.
Just ensure that you IMMEDIATELY remove the cleaner with fresh water after pulling the case out of the tank. If not it will discolor.
There are different detergents available, anything compliant with aluminum will be safe for magnesium as long as it it thoroughly rinsed afterward. _________________ Jake Raby
Raby Engine Development
www.rabyenginedevelopment.com
"I've never given anyone Hell, I just told them the truth and they thought it was Hell" |
