grandpa pete Samba Member
Posted: Wed Sep 29, 2010 10:39 am Post subject: |
pittwagon, please share info on how you will put a water storage tank under your bus,,,thanks |
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Wed Sep 29, 2010 5:08 pm Post subject: |
The tank will go under the floor between the two jack points on the driver's side. Tank will be about 32" x 12" x 4" and give about the same capacity as the westfalia one. Tank will not sit lower than the frame rail.
Mounts will be similar to the propane tank mounts.
Filler can be left in the stock location by the sink and a flexible pipe between the fill fitting and the front of the tank. Outlet (for pump) will be at the front of the tank with an internal hose running to the lowest point at the rear owing to the slightly higher stance of the van in the front. Drain at the rear.
Might use a hand pump instead of the electric one and I might reconfigure the sink as well. Don't know yet. Cabinet rebuilding might not happen until next week. |
jnsjr58 Samba Member
Joined: February 24, 2009 Posts: 34 Location: Mt Pleasant NC (Charlotte Area)
Posted: Thu Sep 30, 2010 2:19 pm Post subject: Headbanger |
74' Tintop Camper
_________________ 74' Tin Top Camper |
thewalrus Big Jack
Joined: March 27, 2006 Posts: 3014 Location: Belchertown, MA
Posted: Fri Oct 01, 2010 10:34 am Post subject: Re: Headbanger |
jnsjr58 wrote: |
74' Tintop Camper
Found a '75 in the gallery
_________________ '73 Transporter 1.7L Dual Carb
notchboy wrote: |
You ran over some #Vanlife'ers hopes and dreams? |
60vwnewengland wrote: |
Looking forward to next weekend, weed, krunk juice, hookers, blow, hanging with bums, philly, ...the awards! |
farfromcruzin Samba Member
Posted: Fri Oct 01, 2010 10:35 am Post subject: |
Have you considered just having a cabinet maker make a headbanger for you? It would be such a small and fast job it might cost about the same as buying and shipping an old one. You could even look on craigslist for a cheap finish carpenter. And as far as matching the simulated wood grain, some online companies will even send you sample chips. I know, I just saw one. I could find it again if you are interested. And it's only like $8 a roll. Hmmm. Maybe I should just hunt down a good match, buy bulk and sell it in here. lol |
poptop tom Samba Member
Joined: July 27, 2004 Posts: 1607 Location: The Hoosier State
danilo209 Samba Member
Joined: June 21, 2010 Posts: 81 Location: Stockton, CA
Posted: Sun Jan 02, 2011 11:47 pm Post subject: Re: Headbanger |
i have the same exact setup in almost as nice condition
jnsjr58 wrote: |
74' Tintop Camper
_________________ 1974 Westfalia tin top (sold)
1956 VW Allied 20-2 Fiberglass buggy (in parts)
1971 German Look Super Beetle (Sold)
1967 Ruby Red Bug |
