djkeev  Samba Moderator
Joined: September 30, 2007 Posts: 26217 Location: North West New Jersey
hansh Samba Member
Joined: January 13, 2004 Posts: 586 Location: Bend, OR
Posted: Sun Sep 21, 2014 4:45 pm Post subject: Re: DIY Grey water tank |
I'm going to make something like this ASAP for a month of van living. How are the inlet and output ports sealed? Not necessarily houndsbourgh's but, anyone who has done something similar. _________________ ‘85 ej22
'84 Westfalia |
hansh Samba Member
Posted: Fri Sep 26, 2014 8:08 am Post subject: |
Hmmm...bump.
Maybe my question seems like a no-brainier to others? PVC is round and any circular hole seems as if it would have gaps that wouldn't be filled-in using PVC glue. I have some epoxy glue stuff that seems as if it'd allow me to adhere joint fittings externally, over inlet/outlet holes, while also compensating for gaps. Is there a better way? _________________ ‘85 ej22
'84 Westfalia |
Nuthin2It  Samba Member
Joined: December 31, 2011 Posts: 252 Location: Marietta, GA
Posted: Fri Sep 26, 2014 9:03 am Post subject: |
This may be a no-brainer, but my brain had a hard time with it, too.
For the hose that goes into the tank, I was able to drill a hole (I think it was some weird size like 1 1/16") and thread it with a steel pipe, then screw a PVC fitting in.
I tried the same procedure for the drain end but it leaked, so I had to try something else. I can't remember exactly what PVC parts I had but I used an o-ring to seal it. I may have just glued a short piece of PVC to the elbow, then put it through the hole in the cap on the 6" pipe. After sliding the o-ring on the pipe, a short fitting can be glued to the pipe to compress the o-ring. You might also find the parts to have a threaded end on the pipe that goes into the tank then screw a fitting on that to seal the o-ring. Either way, this actually works better for the drain end because the elbow can rotate to level the drain pipe. If I were to do it again, I would use an o-ring on both ends.
The 6" PVC pipe end cap I got at Home Depot is dome shaped. This worked but after building my gray tank I happened to see a flat end cap at a local Ace Hardware store. These would be easier to seal if you can find them.
As far as the ground clearance question, the crossover exhaust pipe on my 1.9 liter is 10" from the ground. The engine carrier is 10 1/2" from the ground. The 6" PVC pipe is 9 1/2" above the ground, about 9 1/4" at the drain pipe end. So yes, the gray water tank will hit before anything else, especially at the drain, but what have you lost, about $10 worth of PVC? OK, full disclosure, I have some Home Depot stock. But I think a 6" pipe is more likely to hold a day's worth of gray water if you cook and clean dishes. _________________ 1985 1.9L Westfalia |
gene l Samba Member
Joined: August 31, 2013 Posts: 136 Location: LOS OSOS,CA.
Posted: Fri Sep 26, 2014 4:13 pm Post subject: |
instead of vinyl pipe, I used the flexible metal pipe off of a house hot water heater. Works well, and doesn't crimp. |
the joker Samba Member
Posted: Sat Sep 27, 2014 6:44 am Post subject: |
I consider my westy just a great tent on wheels
VW would have added a stock one if there were environmental issue
Like it was stated before a little gray water ( properly disposed) never was an issue
Your just adding wt and paying to dump a minuscule amount of waste h2o
I act like tent people and even request the tent site to be away from the summer homes on wheels
Isn't that the beauty of the westy less complicated  |
singler3360 Samba Member
Joined: February 25, 2009 Posts: 1191 Location: Corvallis, Oregon
Posted: Sat Sep 27, 2014 10:00 am Post subject: |
the joker wrote: |
I often stop short of projects on our Westy that begin to go down the path of an RV. If we don't want a tent on wheels, then we should invest in a different vehicle for these purposes altogether. However, in the case of collecting grey water, it's a bummer to show up to camp site with evidence of the previous camper's kitchen disposal. I'm not saying we need to collect our grey water for every dispersed camp site we've occupied, but having some method of collection in more frequented areas is being considerate. I use a collapsible 2.5 gal. water cube but I applaud the ingenuity in this thread. |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1557 Location: Between Here and There
Posted: Sat Sep 27, 2014 12:39 pm Post subject: |
For those of us that live in areas with bears or other potentially aggressive scavengers, it's just plain irresponsible for campers to not properly dispose of waste water that has food, toothpaste or other attractants in it in a campsite that others will be using. Dispersed campsites may not be as big a deal, although it depends on how much they're used. Responsible disposal can help save people, and animals, whole lot of grief. _________________ 1984 Westy, base model, 2WD. Plus some goodies.
________________________
Sold: 1972 Bay Campmobile |
hansh Samba Member
Posted: Sat Sep 27, 2014 4:16 pm Post subject: |
Please remember that personal opinions may not apply well to all situations. I will be urban stealth camping for a month while doing an internship at an out-of-state hospital. I want to be able to spit my toothpaste and wash my dishes without worrying about where I'm parked at the moment.
No need to debate the rationality of a gray water tank. Do what works for you. _________________ ‘85 ej22
'84 Westfalia |
hansh Samba Member
Posted: Sat Sep 27, 2014 4:25 pm Post subject: |
Nuthin2It wrote: |
You might also find the parts to have a threaded end on the pipe that goes into the tank then screw a fitting on that to seal the o-ring. Either way, this actually works better for the drain end because the elbow can rotate to level the drain pipe. If I were to do it again, I would use an o-ring on both ends.. |
Great points Nuthin2It. I had assumed an o-ring wouldn't work because of the curvature of the cap/pipe, but you've given me some good ideas. Articulating ports are definitely best if they can be sealed. However, static ports glued over a hole are cheap and would work (and are easiest). I'll need to go price out cost vs fx. _________________ ‘85 ej22
'84 Westfalia |
Posted: Sun Sep 28, 2014 6:27 am Post subject: |
Thinking back, I probably flattened the inside of the end cap around the hole with a large Forstner bit so the o-ring would seat. Because Forstner bits are rather expensive and should be used with a drill press, it would be much easier to find a flat end cap. Or, if you know someone into woodworking, they probably have the tools.
Earlier I made a comment about a charge at Lassen Volcanic NP for dumping gray water. In our month-long trip last May from Georgia to the California Coast and back, this was the only place that charged a fee for wastewater disposal. All other campgrounds that had wastewater disposal did not charge a fee; i.e., each camper paid for it in their camping fee, whether they used it or not. This may change in the future, but at this point one shouldn't expect to have to pay extra to dispose of gray water. _________________ 1985 1.9L Westfalia |
