Wheel_Works Samba Member
Joined: August 05, 2009 Posts: 347 Location: Michigan
Posted: Fri May 07, 2010 2:49 pm Post subject: Is there a better dipstick conversion? |
I bought a 1835 in a Type 3 case. It has a cheap Empi Dipstick conversion like this. http://www.chircoestore.com/catalog/product_info.php?products_id=3288
It seems cheap and flimsy. The tube doesn't seem to be in the mounting block very well. I'd like to buy something that put together a little better. |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Fri May 07, 2010 2:58 pm Post subject: |
Drill the case and put in a standard dip stick, if you are using the engine as an upright.
Or, rebuild the engine with the right case, and sell me that one. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Fri May 07, 2010 3:19 pm Post subject: |
Russ it's a fresh motor, don't really wanna disassemble it(I'm Lazy). Just thought somebody out there might make something a little nicer. |
Posted: Fri May 07, 2010 3:21 pm Post subject: |
Modify a T-3 dip stick tube, and dipstick.
What is this being used in? _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Posted: Fri May 07, 2010 6:38 pm Post subject: |
Buggy. It's converted to a Type 1 style. I just see the cheap setup on it causing problems down the road. |
pow_rider17 Samba Member
Joined: October 13, 2006 Posts: 509 Location: Burque, NM
Posted: Sat May 08, 2010 1:45 am Post subject: |
If it helps, I have used one of those conversion kits before.
Or I should say I had an engine with one installed.
I got it used and then put a bunch of miles on it.
Never had a problem with the dipstick....other than the one behind the wheel. |
Posted: Sat May 08, 2010 9:32 am Post subject: |
If it is a late EMPI POS, yes, I would worry. Especially off-road.
Since it is off-road, I would look into modifying a T-3 tube and dipstick. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
