Need new wiring plug for coolant level sensor
coclimber
coclimber is offline
PostPosted: Sun Feb 16, 2014 7:13 am    Post subject: Need new wiring plug for coolant level sensor Reply with quote
Mine crumbled to dust and while I *think* I can still plug/unplug just the clips of the two wires on, I'd rather splice in a new/different plug. Anybody know how to get one?
All my online searches come back with the coolant level sensor for the bottle, but no replacements for the plug
Jason
'83.5 Westfalia Camper - SOLD
'86 Westfalia Weekender
2001 Subaru Legacy 2.5L donor
Rocky Mountain Westy kit
http://westycamper.blogspot.com/
ZsZ
ZsZ is offline
PostPosted: Sun Feb 16, 2014 8:48 am    Post subject: Reply with quote
VW part nr is: 443 906 231
Tyco (AMP) part nr: 925014-0
info on connectors:
http://www.vw-bus-land.de/tips/stecker/stecker.html
1.9 MTdi Multivan (ex Caravelle)
Van since 2006, engine since 2008
insyncro
Banned
insyncro is offline
PostPosted: Sun Feb 16, 2014 11:13 am    Post subject: Reply with quote
Get "the tank" from RMW and be done with plastic and that sender.
They use new pressure caps and a better sensor.
You need to cut off the old connector for use with the RMW tank Wink
crazyvwvanman
crazyvwvanman is offline
PostPosted: Sun Feb 16, 2014 11:29 am    Post subject: Re: Need new wiring plug for coolant level sensor Reply with quote
Vans typically have 4-8 of those same 2 pin female connectors. If you have a self-serve parts yard you can get one from the brake fluid cap switch on many VWs. That is a fairly protected spot so the connector stays nice and is easy to grab.
Mark
Jason
coclimber
PostPosted: Sun Feb 16, 2014 11:10 pm    Post subject: Reply with quote
info on connectors:
very helpful. Thanks!
coclimber
PostPosted: Wed Feb 19, 2014 11:42 pm    Post subject: Reply with quote
I've checked 3 different online shops and just 2 spade terminals and the terminal housing are running approx. $10 + 17 shipping. How does it cost so much to ship something that collectively is the size of my thumbnail!?? LOL!!
If anybody has a coolant sensor housing they can spare, plz cut me off a good 4-6" of wiring and ship it out. I'd be happy to pay, just not $17 in shipping Smile Otherwise, time to scrounge around the CO scrap yards. Thinking at least an 80s Jetta or Golf would have similar parts.
coclimber
PostPosted: Sun Feb 23, 2014 9:36 am    Post subject: Reply with quote
Consider this thread CLOSED. Smile Successfully!!! I hit the trusty scrapyard and found what I needed plus a spare. Total $4 vs. $54 ($27 each x 2)... What a bargain for putting on the coveralls and mixing in a bit of elbow grease!! These came of an '88 Jetta and an '85 Golf, respectively. One had a crack in it, so it will be the spare.
Jason
