tencentlife Samba Member
Joined: May 02, 2006 Posts: 10067 Location: Abiquiu, NM, USA
Posted: Thu May 13, 2010 7:10 am Post subject: |
This is easy to do without the need for extra jumpers if you can isolate both ends of the wire you want to test. You can either do it by voltmeter or testlight, or ohmmeter:
Just clip your testlight or voltmeter to a power source on one end (alternator positive pole is always hot in the engine bay), the other lead to the wire you want to test. If the wire is isolated from ground, you would see no voltage or the testlight will not light up. Then go to the other end of the wire and ground it, your testlight will glow, or your voltmeter show voltage.
Or use the ohmmeter, connect the leads between any grounded point and one end of the wire you want to test, there should be infinite ohms, then ground the opposite end and you will see a circuit. This method is easiest because you don't need to find a positive power point. Best of all is if your VOM has a continuity buzzer you can put it in ring mode and test this way without the need to see the meter. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
16CVs Samba Member
Joined: February 22, 2004 Posts: 4020 Location: Redwood City, California
Posted: Wed May 12, 2010 10:54 pm Post subject: long wires and testing |
Buy a " power probe " ,it comes with leads long enough to go around a Semi .
It has a lot of great features like being able to check components and let you know if a circuit is Power ,ground or dead .
They may seam expensive at over $100.00 ,but will be the most used arrow in your quiver .
Stacy |
targis58 Samba Member
Joined: July 11, 2006 Posts: 539 Location: sunnyvale,ca
Posted: Wed May 12, 2010 9:47 pm Post subject: |
I have a roll of 100' 24guage wire with aligator clips on both end to check long distance continuity. Works good on vanagons as well as on house projects _________________ 90 westy 2wd w/ TBD |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Wed May 12, 2010 9:35 pm Post subject: Long distance continuity tests |
I need to test some wires going from the dash to the engine compartment, what is the best way of doing this? A really long jump wire? _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
