icemanhd Samba Member
Joined: May 07, 2007 Posts: 275 Location: Camano Island, WA
Posted: Fri May 14, 2010 10:41 am Post subject: 62 Convertible farm find & questions |
Brought home a 2 owner 62 ghia convertible last night. Overall other than being filthy the body is relatively straight with little rust and its never been hit in the nose. It is missing the front/rear bumpers and the drivers side door glass is broken but other than that its essentially complete. It was originally pacific blue but was repainted in the late 60s the horrid orange color, even the top is original (but in tatters).
I bought 2 ghias last week as well, a 68 coupe which is 60% complete with a body off resto and a 69 parts car. I want to focus my attention on the convertible since its older and is a drop top so I'm having a no reserve fire sale on the 68 coupe on e bay, I just listed it last night.
Questions (thanks in advance for any/all help)!!!
1. The engine serial number is funky, from talking to the previous owners they never had the engine changed and they bought it in 1970 so I would assume original engine but the S/N is 6034828 which lines up with the engine numbers from 61/62 bugs but is miles off the 40 hp serial numbers used on ghias. Any thoughts? Perhaps it was swapped with a bug 40 hp motor?
2. I have searched Samba and struck out, any idea where I could get a drivers window? From info on Samba it appears all the convertible windows are the same from 59.5 till 74.
_________________ 71 Drag Ghia
67 Bug, Hot VWs feature car
68 912
76 912E
87 911 Carrera |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Fri May 14, 2010 10:50 am Post subject: |
Nice score on the Ghias.
Sent you a PM on the window glass. _________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
aerosilver Samba Member
Posted: Fri May 14, 2010 10:58 am Post subject: |
Thanks! I searched the other night and came up blank, I should have varied my search words! My mind is pretty preoccupied since I have bought 3 cars in 1 week, trying to find places to park/put them all. _________________ 71 Drag Ghia
68 912
76 912E
87 911 Carrera |
moogie32 Samba Member
Joined: April 06, 2005 Posts: 663 Location: Connecticut
Posted: Fri May 14, 2010 11:02 am Post subject: Nice find! |
Looks like a nice solid car - I'm in the middle of restoring a Pacific Blue '63 convertible too- wish I could help you more with your engine question -Do you have any more pictures of it? I'd love to see more of the interior, especially if it's original.... _________________ RIP HBB (1984-2009)
Du liefst so gut
Du warst so schön
Doch leider musst du von uns gehn |
Posted: Fri May 14, 2010 11:02 am Post subject: |
Ok, my brain has re-engaged... I had searched Samba for the differences between the convertible and coupe door glass and those are all for coupes which have the rounded rear corner. Thanks for the leads, keep them coming!!! _________________ 71 Drag Ghia
68 912
76 912E
87 911 Carrera |
Posted: Fri May 14, 2010 11:05 am Post subject: |
icemanhd wrote: |
Ok, my brain has re-engaged... those are all for coupes which have the rounded rear corner. Thanks for the leads, keep them coming!!! |
Coupes have the pointed upper rear corner.
Convertibles are rounded. _________________ ****************************
Posted: Fri May 14, 2010 11:06 am Post subject: |
moogie32, just sent you a pm with my e mail address and asking for yours. I have a few other pics posted in the ghia vert gallery and will post some pics of the interior in the gallery after I get it cleaned up this weekend. _________________ 71 Drag Ghia
68 912
76 912E
87 911 Carrera |
Scooterboyd Samba Member
Joined: January 18, 2009 Posts: 342 Location: Rancho Cordova, California
Posted: Fri May 14, 2010 12:37 pm Post subject: |
Be careful when taking off the front turn signals. The studs on the back tend to break off easy when removing them. Use PB Blaster on the nuts. _________________ President of "Society of Unappreciated Overachievers"
62 - 23 Window Bus
60 - Karmann Ghia Convertible
59 - Convertible Raceable Baja Bug
63 - Dune Buggy
65 - Single Cab |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Fri May 14, 2010 7:29 pm Post subject: |
Thanks to all for the replies! Knowing that the Ghia Vin/Engine number charts are a little whacky really helps. Since the (former) current owners got the car in 1970 I suspected the motor was original. Knowing that is a very strong possibility leads me to the conclusion if I cant get it running I'll rebuild it.
Its currently locked/frozen but they say as recent as a year ago they would go out and turn it over without starting it (probably the worst thing they could have done). Suspect the rings are rusted to the cylinders so if some pb blaster fogged in the plug hole and some rocking back and forth doesn't do it, I'll pull it and go through it. If it had been swapped I would just swap it out again with another 40 hp...
Complete double brain lapse on my part on the door glass, yes I checked the RH side and its rounded so that is what I'm after and will reply back to a PM from ghiaaddict.
Spent the afternoon pulling the 68 and 69 I bought last week to a neutral location since I promised the seller I would have them out in a week... I have too many ghia projects in flow at the same time (not to mention my 57 oval and 67 blowthrough turbo). I will be updating the e bay listing on the 68 ghia (auction is currently at $105 with no reserve) tomorrow to include pics of the specific rust repair parts from KGPR that are included in that auction. If only there was a ghia chassis based kit car!
Again, thanks to all!!!! _________________ 71 Drag Ghia
68 912
76 912E
87 911 Carrera |
vdublammy Samba Member
Posted: Fri May 14, 2010 10:06 pm Post subject: |
Nice score. I picked up a original owner blake plate 62 sedan a month ago.
Peace,
Mike |
lemke Samba Troll
Joined: February 24, 2004 Posts: 1249 Location: Seattle
Posted: Sat May 15, 2010 10:23 am Post subject: |
I looks like it has the original Lemmerz wheel trim rings. If they are in good shape, those a worth a lot of buck$$ |
Posted: Mon May 17, 2010 4:59 am Post subject: |
Major major scrub down this weekend on the new find. Despite sitting for years and years (although it was covered) it was beyond filthy. After going through the car with a trash can, brushing and vacuuming as much as possible, powerwashing under the front hood and interior (yes, I powerwashed the interior, I had to - some very mucky water got in there), dousing the power washed areas with 3 quarts of rubbing alcohol (to absorb the water and evaporate), and some scrubbing on the interior panels and seats the car looks MUCH better. I think the door panels are usable with some repair, passenger seat is in great shape (but the vinyl is stiff/brittle) and 1/2 of the back seat is great but brittle.
Left hand side of motor (#3 and #4) is why it won't turn over, some moisture got in there and rusted the rings to the cylinders. I'll pull the motor and at least hone the cylinders, put new rings in, and do a valve job. Dependent how the rest of it looks I might split the case just to clean it up and check the bearings.
68 912
76 912E
87 911 Carrera |
Posted: Mon May 17, 2010 6:19 am Post subject: |
My bad, I posted the same pic twice above. Here is the missing one.
68 912
76 912E
87 911 Carrera |
seanboy69 Samba Member
Joined: October 22, 2008 Posts: 1107 Location: Templeton PA
Posted: Mon May 17, 2010 6:52 am Post subject: 62 Convertible farm find & questions |
Looks great!!!! My wife would love to get a Ghia Vert!!!!! _________________ In a sea of american muscle there is alittle bug hiding in the corner...
Oh, and I am 39 years old.....I am supposed to know better......ha!!!
1956 oval ragtop
1962 baha
2276 in progress |
tondemonai Samba Member
Joined: January 08, 2008 Posts: 364 Location: Memphis, TN
Posted: Mon May 17, 2010 7:59 am Post subject: |
Sent you a PM - I have both windows off a 66 vert. _________________ (O= i =O) One day, lad, this car will be yours. |
Posted: Mon May 17, 2010 9:26 am Post subject: |
Wow, looks MUCH better!!!
New upholstery in original material can be had for a fair price, don't sweat it and it is "easy" to put on.
The engine? I just tore down an engine which would NOT rotate. Had been sitting for a few years and as it turns out had been immersed in water and I also thought, rings rusted to the cylinders. After pulling the head and literally smashing one cylinder off of the piston (totally rusted on) it turned out to be # 1 Main rusted to the crankshaft was my main problem. I had to literally beat that bearing off with a hammer and a drift!!
The engine otherwise was in GOOD shape, no pounded mains, the bores were still the proper size and round. I ended up getting the crank turned .0010 and it is in the process of reassembly. I have a pile of heads so I swapped them out for some better ones as well as pistons and cylinders.
Over all this will be a very inexpensive stock displacement rebuild! I have an engine that only got about 10,000 miles on a rebuild (unknown builder) before it spun the #1 main. Most of those good parts have gone into the rebuild.
Keep us updated on your progress....
Ghia
Vanagon
Beetle
Broadacus Samba Member
Joined: January 25, 2003 Posts: 535 Location: Manchester. ENGLAND, UK
hpw Samba Member
