Vanagon & Westy Measurements/Dimensions
Page: Previous  1, 2, 3  Next
Timwhy
Timwhy is offline
PostPosted: Fri Feb 25, 2011 4:53 am    Post subject: Reply with quote
mb wrote:
great work! .... but
Only three nations out of 203 have not officially adopted the International System of Units as their primary or sole system of measurement: Burma, Liberia, and the United States of America.
The United States is the only industrialised country in the world that has an aversion to using the International System of Units as its predominant system of measurement.
Countries which have officially adopted the metric system (green).
[map]
Text & Image: Wikipedia
[tape measure]
Luckily for YOU that you can reference your tape measure to find out what the
measurements are. Good Luck With That!
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
nod7
nod7 is offline
PostPosted: Fri Feb 25, 2011 11:46 am    Post subject: Reply with quote
Wow, Nice post Tim! Very good idea for a thread.
This is a good candidate for; Links to the best threads on the Vanagon Forum (FAQ)
-nod7
My Projects
Propane Rework & Rust Prevention
Pop Top & Tent Restoration
House Battery, Yandina, Xantrex & Atwood Install
Blueconundrum
Blueconundrum is offline
PostPosted: Fri Feb 25, 2011 11:50 am    Post subject: Reply with quote
Brilliant! I may do this for my Syncro and post it up since I have half the measurements already. I'm doing a custom kitchen, keeping it a tin-top and a full-width bed, so those measurements might be helpful for others with similar plans in mind.
1988 Vanagon Syncro EJ22
carterzest
carterzest is offline
PostPosted: Fri Feb 25, 2011 12:11 pm    Post subject: Reply with quote
May I be the first to nominate this for a STICKY Question
This is StickyLiscious!
Good job!
Happiness=Portland, Oregon in the rearview mirror!
BlueGrasser
BlueGrasser is offline
PostPosted: Tue Apr 14, 2015 10:16 am    Post subject: Reply with quote
Wow, if this thread is not a sticky it should be! Very useful!
Going to where the grass is bluer...
1985 Vanagon Westfalia Camper with 1.8T
oldschool84
oldschool84 is offline
PostPosted: Tue Apr 14, 2015 10:36 am    Post subject: Reply with quote
Second that -
kamzcab86
kamzcab86 is offline
PostPosted: Tue Apr 14, 2015 12:28 pm    Post subject: Reply with quote
oldschool84 wrote:
Second that -
Added to the FAQ.
http://www.thesamba.com/vw/forum/viewtopic.php?p=6236057#6236057
~Kamz Anxious
2016 Golf GTI S
"I fear the day that technology will surpass our human interaction; the world will have a generation of idiots." ~Albert Einstein
djkeev Premium Member
djkeev is online now
PostPosted: Tue Apr 14, 2015 1:05 pm    Post subject: Reply with quote
These dimensions were posted in the Weekender kitchen thread but thought it would be helpful to have them here as well.
This is an 86 Multivan (weekender) Left rear side cabinet Dimensions.........
I have heard that the newer grey / gray ? interior has the rear seat angle different from the brown/beige interior.
Not sure if this is true...... but if it is....... Is the Weekender cabinet size different?
Here is what I have.........
Not very high tech but masking tape and a Sharpie work!
Overall length........ 32 3/4".......
Overall height to shelf bottom...... 33 1/2" ....... From lower engine cover rib.......
Overall depth....... 14 3/4" ........
View of angle and fit into the rear. The cabinet fits snug against the metal upright and the breaks and follows the lid angle holding back a consistent distance..........
The top intersection ...........
Difficult one....... The angles and cuts of the bottom.
The front is flush to the metal floor for 6",
The rear is parallel with the floor for 7 1/2" until the radius begins, this is 3 3/4" above the lower rib of the engine cover.
The gradual angle starts at the 6" mark from the front and runs for 17 1/4" ending 2 1/4" above the floor where the radius begins.......
The small door is 6 1/4" x 16 1/4" .............
The large door is 19" x 24 1/2" ..........
If you need any other views or dimensions..... Let me know.
Dave
Ghia
Vanagon
Beetle
noganav
noganav is offline
PostPosted: Sun Aug 16, 2015 9:51 pm    Post subject: Reply with quote
Looking for clarification on the upper bunk measurement, I'm away from my van right now. How much space is left over for storage behind the folded bit when the upper bunk is folded?
Up Top
Thanks!
Nimbus'87
Nimbus'87 is offline
PostPosted: Mon Aug 17, 2015 10:45 am    Post subject: Upper bunk dimension... Reply with quote
I measured 20".+- for folded tent etc.
...or were you looking for height? +- pad? Confused
SS.
'87 Wolfram Grey Westy. '92 2.2 Subie, KEP/Calif. Reg.
noganav
noganav is offline
PostPosted: Mon Aug 17, 2015 10:46 am    Post subject: Reply with quote
That's perfect, thanks!
specialev
specialev is offline
PostPosted: Thu Jan 28, 2016 1:22 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
Does someone have an upper rear cabinet they can measure and post in this thread? Length, height, top and bottom width, etc.
I'd like to get enough detail to be able to draft the cabinet with dimensions in Catia. I've got an idea for a cabinet i'd like to build for my Syncro but I've got no idea what the original is dimensions are. I can share my model to anyone that wants it.
Thank you!
89 Tristar Doka Build!
pinetreeporsche
pinetreeporsche is offline
PostPosted: Thu Jan 28, 2016 2:55 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
OK- how about the weight of various models-- tin top, weekender, and full Westy. And a Syncro-- at least one version, to compare. Maybe empty of fuel and no water in tank if it has the Westy style fresh water tank. Wheels-- I son't know-- the original alloys I guess.
Californio
Californio is offline
PostPosted: Thu Jan 28, 2016 4:28 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
The Dometic is 9" deep? I never thought about that. No wonder it's completely useless.
PostPosted: Thu Jan 28, 2016 5:07 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
Thank you!
Maybe tomorrow I'll grab my roll of green tape and see what I can document.
Dave
Ghia
Vanagon
Beetle
specialev
PostPosted: Thu Jan 28, 2016 6:46 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
Thank you!
Dave
You're a champ, Dave!
PostPosted: Sun Jan 31, 2016 12:49 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
Took a bit longer..... Sorry.....
If you need dimensions not here...... Just ask.
Note space for Right Rear Curtains........
Dave
Ghia
Vanagon
Beetle
c2mrdale
c2mrdale is offline
PostPosted: Thu May 19, 2016 4:40 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
What a fantastic resource!
I would love to try and replicate the rear cabinet and headknocker, is the height you show for the closet, to the top of the cabinet or to the bottom of the headknocker cabinet?
Do you have interior measurements?
Westified
Westified is offline
PostPosted: Sun Oct 09, 2016 7:34 am    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
Here are the kitchen inlet dimensions/locations.
1984 Westy Wolfsburg, owned since 1987.
travis740
travis740 is offline
PostPosted: Fri Jan 06, 2017 6:39 pm    Post subject: Re: Vanagon & Westy Measurements/Dimensions Reply with quote
Does anyone happen to know the height of a 1984 Camper? Wanting to know if it'll fit in my garage.
I can't seem to find an owner's manual online. Brand new at trying to figure this out. Thank you
Page 2 of 3
