stevo96 Samba Member
Posted: Tue Feb 19, 2013 10:09 pm Post subject: |
Is the picture in this thread of the shift plate the right way around for both right and left hand drive vans??
Cheers |
curtis4085 Samba Member
Posted: Tue Feb 19, 2013 10:42 pm Post subject: |
stevo96 wrote: |
Cheers |
Im gonna go out on a limb and say for right hand drive it oposite. Please someone correct me if im wrong _________________ Special Thanks to:
Headflow Masters - Vista, CA
www.headflowmasters.com |
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed Feb 20, 2013 12:11 am Post subject: |
curtis4085 wrote: |
stevo96 wrote: |
Cheers |
Im gonna go out on a limb and say for right hand drive it oposite. Please someone correct me if im wrong |
why would it be opposite? is reverse down to the right on RHD cars? no...if the shift pattern is the same, same trans and all, it would most likely be the same design.
but then again, thats just a guess. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
Posted: Wed Feb 20, 2013 12:19 am Post subject: |
Stuartzickefoose wrote: |
curtis4085 wrote: |
stevo96 wrote: |
Cheers |
but then again, thats just a guess. |
I must be wrong in thinking that if this was a right hand drive bus the stop plate and everything else is turned in the other direction. Im not from across the pond so im just guessing. You need the reverse lookout to catch and I was thinking if the stop plate setup for a left hand drive you will not engage the lookout properly. I could be totally wrong here...
LHD reverse down and to the left
RHD reverse down and to the right _________________ Special Thanks to:
Posted: Wed Feb 20, 2013 5:09 pm Post subject: |
Thanks for guessing but does anyone actually know??
Cheers
Steve |
airschooled Air-Schooled
Posted: Wed Feb 20, 2013 5:17 pm Post subject: |
The owners manuals from RHD and LHD countries all show the same shift pattern. _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
stevo96 wrote: |
Cheers
Steve |
I've been wrong before. But think about it... Why would the stop plate go in the say way on a RHD as it does on a Left hand drive. It's ment to keep you from going in reverse gear when looking for second. If you keep the stop plate the same as a LHD bus on your RHD bus your stop plate becomes useless.
Please someone tell me I'm wrong?? _________________ Special Thanks to:
Posted: Wed Feb 20, 2013 5:19 pm Post subject: |
curtis4085 wrote: |
stevo96 wrote: |
Cheers
Steve |
Please someone tell me I'm wrong?? |
My mistake then. So RHD reverse is down and to the left? _________________ Special Thanks to:
busdaddy Samba Member
Posted: Wed Feb 20, 2013 7:03 pm Post subject: |
curtis4085 wrote: |
curtis4085 wrote: |
stevo96 wrote: |
Cheers
Steve |
My mistake then. So RHD reverse is down and to the left? |
Yes, to alter it would require more than just a stop plate flip, RHD would require a whole new transmission. RHD shifts exactly the same as LHD but you use the other hand. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jtauxe Samba Member
Joined: September 30, 2004 Posts: 5780 Location: Los Alamos, New Mexico
Posted: Thu Aug 18, 2016 8:42 am Post subject: Re: ? about Bentley Stop Plate Adjustment Picture |
Just found this thread, as I am getting into shifter stop plate adjustment.
I can confirm that RHD buses have the same shift pattern and mechanism that LHD buses do. I have a 1978 RHD double cab, with a Gene Berg shifter, and if you sat in the passenger's seat (on the left) you would shift exactly the same as you do for a LHD bus.
I will say that it is a bit odd to be shifting with your left hand.
FWIW, the pedals are also laid out the same. That is, the left foot handles the clutch, and the right foot handles accelerator and brake. If they had reversed that, I would have to completely retrain myself. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
Posted: Thu Aug 18, 2016 9:05 am Post subject: Re: ? about Bentley Stop Plate Adjustment Picture |
I would also like to ask for clarification on the actual shifter on RHD buses. My OG LHD shifter has a slight rotation to it, allowing all 4 forward gears to be slightly moved towards the driver. Aftermarket stock style shifters do not have this slight rotation, so 3 and 4 are closer to the passenger than driver on LHD buses. Do RHD buses utilize a shifter that gives a slight right bias? Because if they used the stock LHD shifter, the pattern would not be close enough to get the Volkswagen factory ergonomic sign-off.....
Tcash Samba Member
Posted: Thu Aug 18, 2016 11:25 am Post subject: Re: ? about Bentley Stop Plate Adjustment Picture |
Thnx jerseylooker #3
Tcash |
Posted: Thu Aug 18, 2016 11:30 am Post subject: Re: ? about Bentley Stop Plate Adjustment Picture |
Whoops. Didn't think to check there. Good to know the aftermarket stock shifter will suck equally on cars all over the world.
SGKent Samba Member
Posted: Thu Aug 18, 2016 12:27 pm Post subject: Re: ? about Bentley Stop Plate Adjustment Picture |
might as well post an update to my part while it is active again. Hoody found me a new pipebowl and shift lever in Europe. That plus the new stop plate and cover made it work completely normal. The shifter stays down when it is in reverse. With rebuilding the transmission last year the shifter feels solid and no slop at all in it.
Prior to that Ken Madsen sent me a used pipe bowl, shifter and cover - the best he had and that improved things greatly but the new ones are like the bus was when it came from the factory. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
