tencentlife Samba Member
Joined: May 02, 2006 Posts: 10075 Location: Abiquiu, NM, USA
Posted: Wed Jun 16, 2010 12:51 pm Post subject: |
If you want to really check the pinion bearing radial play, here's an idea: up on stands, handbrake on, nose cone off, trans in 4th gear. Have a helper put a wrench on the crankshaft pulley bolt (30mm) with a long lever and try to turn it back and forth while you are below looking for movement. They'll have to work it pretty hard, remember there is over 100ft.lb. going down that shaft normally. This will simulate the sideforces inside the gearbox that wallow out the shaft bearings, by putting hard torsion directly into the 4th gear pair; that's the pair that beats the forward bearings as the torque makes the gears try to push apart from one another. You might turn up play this way that you wouldn't be able to simulate by hand; remember there is another pinion bearing just a couple inches behind the forward one on a Syncro trans, which may thwart your efforts to establish play by hand. Doing what I describe generates forces inside the gearbox that you will not be able to simulate from outside.
I would try it in 4th gear first, then also engage G and reverse since those gears are in between the two forward pinion shaft bearings.
Curious to see what you find out, but my opinion is that no amount of imbalance or misalignment of propellor shaft or CV axles that you could stand to drive down the road with could result in the trouble you've described. And just because it works well with the standard nose cone back on isn't conclusive, that would be comparing an apple to a pomegranate. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Wed Jun 16, 2010 2:31 pm Post subject: |
syncrosimon wrote: |
On my de-coupler I initially omitted the two locating dowels between the coupler and the gearbox. My originals were sent back as the core unit, and the new one did not come with any, nor did I realise that there should be any there.
Just a thought.
Simon. |
... and a very good thought, too. Omitting these dowels could possibly be a cause for this type of failure. |
Classicvibe Samba Member
Joined: August 03, 2009 Posts: 743 Location: Salt Lake City
Posted: Wed Jun 16, 2010 4:16 pm Post subject: |
tencentlife wrote: |
Curious to see what you find out, but my opinion is that no amount of imbalance or misalignment of propellor shaft or CV axles that you could stand to drive down the road with could result in the trouble you've described. And just because it works well with the standard nose cone back on isn't conclusive, that would be comparing an apple to a pomegranate. |
Tencent, can you give me a little more info on the differences (apple/pomegranate)? It seems the stock cone would be under more constant pressure than the 'de-coupled' decoupler.
Thanks to you and Simon and Gears...I am considering your comments now as I type... _________________ On a mission, the destination is just an excuse.
Syncro Solstice 2022...see you there!
1986.5 Wolfsburg Syncro Westfalia Poptop Weekender Transporter |
Posted: Wed Jun 16, 2010 4:51 pm Post subject: |
I'm just saying that between the front end of the pinion shaft and the output flange stub, you have a different assembly, that connects to the pinion shaft in a slightly different way, and is able to rotate independently of the output flange when disengaged. I'm not saying that what you observe by putting the stock nose cone back on means nothing, just that it isn't conclusive of anything. You need more data to make any meaningful determination. It's a basic logical distinction, there are other variables that that doesn't account for. You're not swapping one component for another of the same, therefore apple to pomegranate (because a pomegranate is a "Granada Apple", which is closer to an apple, namewise at least, than an orange is. But I digress...).
There is the possibility that if the locating pins were omitted, the nose cone could shift a bit and that would cause a tight and true-running pinion shaft to wallow out the decoupler spline or guide bushing if it ends up being off-center. But there are so many bolts holding the cover on that I think it would stay where it was bolted even under heavy lateral loading, but without the locating pins how would you know it was installed on-center in the first place? Once again, though, the omission of guide pins would be an installer error, sorry to say. And so far as I know, yours were where they were supposed to be anyway.
If you did have loose front and center pinion shaft bearings, I would think you would have some whine in the top gears, 3 and 4, but the gears would probably still engage smoothly. When I sent my Syncro trans off to Daryl, with about 170k miles on the OEM build, the main gearcase had to be replaced because the shaft bearing housings had wallowed out. He says that is very common. But I don't know for sure whether it was the main or secondary bearing housing that had gotten beaten out, or both. I'm presuming it was the forward bearings because the spreading force is greatest between the taller gears as I understand it. But I'm not a trans guy so consider what I say with the appropriate skepticism, like the kind I have when dweebs go off about engines. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
JED THE SPREAD Samba Member
Joined: July 14, 2009 Posts: 626 Location: South London UK
Posted: Wed Jun 16, 2010 5:34 pm Post subject: |
Why do you lot love decouplers so much? it takes the syncro out of the syncro as far as most of us think in the UK. You buy a vehicle that has this amazing early 80's technology way ahead of its time to take away the forward thinking of off road driving, complimented with diff locks then fit a product to take all that away and complane when you fit a Japanese engine in a german van that is not ment to be in that messes your van up?
I dont get it
Ok i know VW popped the odd decoupler in here and there for a specialized market, And I also know of the sports or solid VC. I can understand why you would want a decoupler under these conditions but why for road trip use etc...
What is the point in spending x amount of $ on something that makes your van for those who actually go off road less capable
jed _________________ Visit CAMPERVANCULTURE.COM real camping and video uploads
Subscribe to Campervan Culture by Email
Follow us on Facebook, Campervanculture.com |
gears Samba Member
Posted: Wed Jun 16, 2010 5:43 pm Post subject: |
I really think Simon's insight is spot on. (Of course only the OP knows if the sleeves were omitted). The forward pinion needle roller bearings don't really "fail" in the same dramatic fashion as say, a mainshaft ball bearing will. There would have had to have been missing rollers to contribute to this failure.
I feel that this should serve as a lesson for the supplier, too (of course it isn't a "lesson" for them unless they suck it up for the replacement bits). The locating sleeves are typically removed when the output housing ("nosecone") is located on a mill for machining. Sometimes they are damaged in the process of removal. At any rate, the supplier should be making certain that any housing returned has two installed locating sleeves, even if the core was received without them. For the cost of this kit, what's another couple bucks?
... and I think you're paying too much for the decoupler kit. You're definitely being bent over for the replacement parts. JMHO |
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Wed Jun 16, 2010 8:05 pm Post subject: |
JED THE SPREAD wrote: |
What is the point in spending x amount of $ on something that makes your van for those who actually go off road less capable jed |
What's not to love? Other than issues like this of course
The decoupler only takes the syncro out of a syncro when you don't need it, like on the highway, then you can engage it and the syncro is fully functional, capable, and ready to rock.
Plus it allows you to run a solid shaft in place of the VC, dramatically improving the off road capability of the syncro. |
syncrosimon Samba Member
Joined: November 20, 2008 Posts: 257 Location: Devon, England
Posted: Thu Jun 17, 2010 1:00 am Post subject: |
I dont get it
jed |
Change the record. _________________ 1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
Thinking about Thing or 181 (182) ownership. |
Posted: Thu Jun 17, 2010 3:26 am Post subject: |
BushChicken wrote: |
Isnt that what the VC (or a viscous clutch as the Swiss guy that reconditions them for us all in the UK) is for?
Posted: Thu Jun 17, 2010 6:23 am Post subject: |
gears wrote: |
My de-coupler managed 27,000 miles without the dowel locating pins inserted, and it didn't explode though? _________________ 1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
gears Samba Member
Posted: Thu Jun 17, 2010 7:56 am Post subject: |
Well, let me tag along next time you go to the horse races ;>)
Think about it ... Would you install the intermediate housing without the dowel pins? Without the locating pins (or sleeves), your chances of the two housings aligning perfectly and staying there are low. "How Low" is anyone's guess. |
Posted: Thu Jun 17, 2010 9:37 am Post subject: |
Tencent and Gears and others, thanks for the brainstorming. Let me respond to narrow the scope being considered here:
heftysmurf wrote: |
Its because your driveshaft was not aligned propperly.
You need to be very tideous on reinstalling it again after adding a decoupler. Also going 80-90 mph with a major vibration will cause a major catastrophy like that. |
So, I am thinking along the lines of something on the front end like this, but, seriously man, 4 bolts (I only removed the aft connection)...could someone really mess that up? Even if you add the other 4 up front, it seems there is little potential for mistake? Please, enlighten me because like I said, I believe it is a drive-line issue or something else in front of the decoupler. But, 80-90?-...we are talking about Vanagons here, right?
I'm just saying that between the front end of the pinion shaft and the output flange stub, you have a different assembly, that connects to the pinion shaft in a slightly different way, and is able to rotate independently of the output flange when disengaged. I'm not saying that what you observe by putting the stock nose cone back on means nothing, just that it isn't conclusive of anything. You need more data to make any meaningful determination. It's a basic logical distinction, there are other variables that that doesn't account for. You're not swapping one component for another of the same, therefore apple to pomegranate (because a pomegranate is a "Granada Apple", which is closer to an apple, namewise at least, than an orange is. But I digress...). |
My assumption, (since the vacuum tubes were only hooked up like 2 weeks before the decoupler went out and I never engaged the decoupler) is that the forces on the decoupler should have been less the the stock cap. As a matter of fact, nothing is engaged when it is decoupled. Now this makes me think of the events leading up to the damage...I noticed on this trip that my gear shift started hopping around in 4th, and perhaps 3rd as well. It started out light, and by the time I put it together that this might be something bad, I noticed the leak in the cone. But what happened, what caused the "funky chicken" in the stick shift? Was it the chicken or the egg (the cause or a result)? Anyway, if you agree that there very little stress on the decoupled decoupler, then what?
There is the possibility that if the locating pins were omitted, the nose cone could shift a bit and that would cause a tight and true-running pinion shaft to wallow out the decoupler spline or guide bushing if it ends up being off-center. But there are so many bolts holding the cover on that I think it would stay where it was bolted even under heavy lateral loading, but without the locating pins how would you know it was installed on-center in the first place? Once again, though, the omission of guide pins would be an installer error, sorry to say. And so far as I know, yours were where they were supposed to be anyway. |
So, this is a good point. The bolts sleeves (2) were not omitted. As a sidenote, the bolts and sleeves worked well, so well in fact, the damage to the decoupler occurred on the INSIDE of the bolts. In other words, the edges held well, but something was torque-ing the center of the decoupler, the force essentially tearing from the connected base.
For those wondering about these sleeves, you will find them when you pull off your stock cap. Two simple tubular pieces about 3/4" in length, used to ensure the cap is perfectly aligned when re-installing.
If you did have loose front and center pinion shaft bearings, I would think you would have some whine in the top gears, 3 and 4, but the gears would probably still engage smoothly. When I sent my Syncro trans off to Daryl, with about 170k miles on the OEM build, the main gearcase had to be replaced because the shaft bearing housings had wallowed out. He says that is very common. But I don't know for sure whether it was the main or secondary bearing housing that had gotten beaten out, or both. I'm presuming it was the forward bearings because the spreading force is greatest between the taller gears as I understand it. But I'm not a trans guy so consider what I say with the appropriate skepticism, like the kind I have when dweebs go off about engines. |
I am going to monkey with that shaft tonight or tomorrow using your suggested technique. Thanks.
gfrank wrote: |
Just read this thread sorry for your loss.
But great info for those of us installing decouplers.
FWIW this bush looks replacable and the case is definetly weldable by a skilled TIG welder |
I agree, since the repair quote is just shy of $1k!
So, the seller and supplier say they have never seen anything like this. I am mentioning this because it may help in thinking about the possibilities.
The mystery continues! A little Sherlock Holmes to keep me on track here:
Sherlock Holmes wrote: |
...when you have eliminated the impossible, whatever remains, however improbable, must be the truth. |
gears Samba Member
Posted: Thu Jun 17, 2010 1:42 pm Post subject: |
Gee, I almost would have put money on those locating sleeves being absent. Oh well ...
Since the supplier and seller haven't ever seen anything like this, and since the seller's "bearing theory" doesn't really hold water, it sounds to me as though you're getting shafted (because of the high price you're being charged for replacement components).
Unless, of course, there was insufficient lubrication (low oil level), or the 1-way check valve was omitted. |
Posted: Thu Jun 17, 2010 3:45 pm Post subject: |
Just another idea, if you installed the de-coupler and to do so loosened the front diff mounts to allow the prop to drop, then forgot to re-tighten the three 17mm bolts and went for a drive, if you hit the brakes real hard would not the weight of that front diff pull on the decoupler, fracturing it? This would also cause the wear that the group refer to, as the de-coupler would be jarred to one side (it is not symmetrical). This would also explain why your old cone would work fine.
Just a thought. Perhaps a sliding yoke prop would eliminate this? It's more spendy though, but you got this far.
Simon. _________________ 1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
Posted: Thu Jun 17, 2010 3:47 pm Post subject: |
gears wrote: |
There are so many bolts it does not seem to wiggle around what-so-ever. I did not even see the recess around two of the bolts for them.
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12005 Location: Santa Cruz, CA
Posted: Thu Jun 17, 2010 5:01 pm Post subject: |
Quote: |
What is the point in spending x amount of $ on something that makes your van for those who actually go off road less capable |
A decoupler doesn't make a syncro any less capable off road.
Traveling to Arizona in the heat of the summer driving 125 KPH(75 MPH) for 12 hours you don't need AWD. Commuting on the freeways driving the same speeds for a hour you don't need AWD. When decoupled the van is much more nimble to park and steers faster(tighter turning radius). It helps take unnecessary pressure off the expensive syncro only parts when they are not needed. With a pull of a knob and you are back to the standard syncro abilities.
I have an agressive VC in my truck and the other syncro will soon have a straight shaft so I don't really have a choice but to run a decoupler. |
Posted: Fri Jun 18, 2010 12:23 am Post subject: |
Plus you can jack up a wheel and spin it, like for setting the hand brake, or for doing up those CV bolts and prop shaft bolts.
You can feel how much less stress there is in the system in 2wd. You just dont need 4wd on a dry freeway.
You can get towed by a regular tow-truck.
You can park so much easier, especially if you dont have power steering.
At the vehicle testers you can put the brakes on the rollers for the regular 2wd test.
The third knob on the dash looks cool.
It's about as expensive as a VC, and will make a good VC last many years longer.
Most modern vehicles will have some form of automatic de-coupler in the gearbox, as it is best to do it this way, and you dont need 4x4 to park your car at the Mall.
It does not matter what tyres you use, and can pick up a spare which would heat a VC on the motorway, if you have a puncture or two.
For high miler's de-couplers are essential. _________________ 1991 16" 2.1 DJ Syncro factory hightop ex Finnish Army Ambulance, now sold.
Posted: Tue Feb 01, 2011 5:35 pm Post subject: |
Hello all,
It seems that a group of us have come to a "most likely" scenario. To simplify what has happened:
1) Drove for a while on stock nose cone
2) Replaced stock with new decoupler
3) Did not couple because VC was shot
4) Driveline comes off, then on (removing for various reasons not related)
5) Within weeks, decoupler cracks around interior of bolts
6) Install stock cone and continue cruising without issue (with driveline attached) for weeks/months
7) Removed driveshaft for balancing
Driveshaft was indeed out of balance (January, 2011)
So from this scenario (which has been duplicated by a few others), we gathered that the difference between the two set ups is indeed the obvious...one was coupled and the other, not. It sounds like those who have reported the same incident noticed vibration or increased vibration when de-coupled.
I could ramble on about what I think is happening, but I just got an email from someone much more eloquent, saying the same thing (I removed his name because I didn't ask to copy his comments here. He will chime in I am sure if things get weird):
"As for decouplers breaking with bad drivelines..I have only seen 1 stock nose break and heard of several (like 5 guys) non-stock powered vans that have broken multiple decoupler housings. My theory is if coupled, they will not break them but if un-coupled there is the potential for the pinion and decup shaft to vibrate more with a driveline issue. Coupled, they have the slider internally keeping the 2 shafts in sync and de-coupled they are separate entities even though there is a sleeve of bearing to theoretically keep them lined up. No absolute proof, but seen too many recently to believe otherwise."
This fits the scenario well, and became my number one choice once I verified my drive line was whacky. There is still a chance I have another issue, but there is no doubt the driveline had a wobble to it. I should mention the U-joints felt fine. I did have one replaced, but in the end, the wobble was 99% due to a balance issue caused by inconsistencies in the metal skin.
Anyway, the "how things work" about metal shrinkage and expansion on your driveline may be good conversation for a different thread. All you need to know is, listen for a wobble and have your driveline checked periodically regardless (they don't all make noise!). This is a must for installing a de-coupler for the first time, and as for driving de-coupled, well, it seems your chances of failure may be greater than coupled driving. Cracks in your decoupler are not the end of the world because they can be welded fairly easily. The whole process just blows however, so keep your wobble to a min. Let me be clear, this is just a theory, but the physics of it all are there, and I cannot think of another (better) theory. There are smarter folks giving credence to this as well, so for now, I like it.
The worlds most expensive 2wd is about to get locked and loaded YO! I have actually never had a functioning AWD or 4wd on this thing (it took me a while to figure out my VC was jacked). I will install the straight shaft once I get my repaired decoupler back and then try my hand at rebuilding the VC (posting the experience here of course). _________________ On a mission, the destination is just an excuse.
