Dave Sale Samba Member
Joined: August 03, 2009 Posts: 39 Location: central Illinois
Posted: Fri May 21, 2010 5:15 pm Post subject: Stinking distributor installation problem. |
Can anyone help me out with a problem? I recently purchased a Richporter technoligies svda distributor for my 1600 thing engine. I did this to get rid of the stinking flat spot from my 009 dizzy I've been using. It has electronic ignition in it as well. There were no directions with this thing, so I did the normal , put the engine at tdc. ,made sure the rotor was pointing at #1 cylinder wire. I put the starter wire, choke wire ,etc. on the red wire. nothing is on the other terminal. I have the plug wires all on the proper firing order. Turn the key and....nothing! Put the old coil and dizzy back on and instant start. Any ideas? |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15303 Location: Deep in the 405
Posted: Fri May 21, 2010 6:03 pm Post subject: |
Call the manufacture and ask them. If they can't help ask for a refund.
The dreaded flat spot blamed on the 009 is a carb tuning issue not a distributor problem. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Featured in Dec. 2001 HOT VW's Magazine page 63
Watch my racing video's http://www.youtube.com/user/okvwracer/videos |
Posted: Fri May 21, 2010 7:07 pm Post subject: |
I keep hearing conflicting ideas on this subject, but at any rate I've got a problem with this thing. Why would you not put instructions in with the product? Seems dumb to me. |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat May 22, 2010 5:40 am Post subject: |
vwracerdave wrote: |
The dreaded flat spot blamed on the 009 is a carb tuning issue not a distributor problem. |
Not when using it with a 34 PICT 3.
The red wire goes to the (+) positive side of the coil and the black wire goes to the (-) negative side of the coil. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
Posted: Wed May 26, 2010 10:30 am Post subject: distributor problem |
Let me be more specific on my Richporter dizzy problem...there are no markings on the coil (+,-) there is a red wire on one coil terminal and two toned wire on the other . I hooked the ignition wire to the red side. I just hear a click when turning the key. Put the old dizzy and coil back on and she starts rite up. The coil came with the vw10 Richporter and is already wired to the electronic ignition . Any suggestions? |
Desertbusman Samba Member
Posted: Wed May 26, 2010 11:43 am Post subject: |
So didn't you call them yet? _________________ 71 Superbug
71 Westy |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Wed May 26, 2010 12:23 pm Post subject: |
Someone let the magic electrical smoke out of the ignition module.
Only take a fraction of a second hooked up wrong to fry a ignition module. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Yeh, I've called and emailed their tech support .They have not responded..nice huh? |
Posted: Wed May 26, 2010 2:57 pm Post subject: |
Joey wrote: |
It can be but some of us have had no flat spot. _________________ 71 Superbug
71 Westy |
Posted: Wed May 26, 2010 3:58 pm Post subject: |
When I pull the ignition wire off the coil , the engine turns over fine. reinstall and nuttin'. I just chatted with a guy who has one and he says I've wired it properly. Maybe a bad coil? I was checking voltages and left the ignition key on for about one minute.. the coil terminal/ignition wire was hot to the touch. |
Posted: Wed May 26, 2010 4:13 pm Post subject: |
What do you mean by turns over fine, or nuttin'?
Are you talking about the starter which cranks or turns over the engine? OR are you talking about the engine not firing or running? Two totally different topics. Starter or ignition, which one? _________________ 71 Superbug
71 Westy |
Posted: Wed May 26, 2010 4:17 pm Post subject: |
yes, the starter turns over the engine, but since the ignition wire is off the coil ,it will not fire. |
bugbyte Samba Member
Joined: November 12, 2005 Posts: 500 Location: Palm Bay, Florida
Posted: Fri Jul 30, 2010 6:49 pm Post subject: |
Dave Sale,
Well, the same thing just happened to me today. - Received my new distributor (VW10) today. What? No instructions! I too called left a message, and spoke to some girl in customer service that promised that "Paul" would call me back right away. Still waiting.
Everything with the install went smooth until I had to connect to the coil.
I guessed that the larger terminal would be for the hot wires (choke, etc.)
- Nothing! - Tried it the other way. Nothing!
Dave, did you ever get yours resolved?
...Rich |
Posted: Sat Jul 31, 2010 11:50 am Post subject: |
Guessing isn't foolproof. It's like picking a lotto number. _________________ 71 Superbug
71 Westy |
Posted: Mon Aug 02, 2010 11:53 am Post subject: stinking distributer |
No, I even tried a 2nd one with the same results. I sent both back and was refunded my money. My advice is to get the aircoolin net dizzy (that has the proper curve) and pay a little more for something that actually works! Hope this helps. |
Posted: Mon Aug 02, 2010 1:24 pm Post subject: |
Thanks for the update!
...Rich |
Posted: Thu Aug 05, 2010 9:25 pm Post subject: Re: stinking distributer |
and we supply extensive instructions. What a shocker. _________________ It's just advice, do whatever you want with it!
"Like" our Facebook page at
and get a 5% off code for use on one order for VW Parts ON OUR PARTS STORE WEBSITE, vwparts.aircooled.net |
Posted: Fri Aug 06, 2010 12:34 pm Post subject: |
John, I ordered your ACN SVDA the other day and it's on the way to my garage this very moment. Can't wait.
.....Rich |
Posted: Fri Aug 06, 2010 12:41 pm Post subject: |
In my 45 years of working on VW's, I have never had a problem installing distributors with stock points. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76909 Location: Sneaking up behind you
Posted: Fri Aug 06, 2010 12:43 pm Post subject: |
It's not rocket science. If you understand how they work, it's easy. _________________ Glenn
Member #1009
#BlueSquare |
