peecee69 Samba Member
Joined: January 27, 2005 Posts: 1572 Location: Annapolis, MD/Bloomfield Hills, MI
Posted: Mon May 24, 2010 6:54 pm Post subject: Throttle on carb not returning to original position |
I have a carb where the spring doesn't seem to be strong enough to return the throttle back to its original position. In order to get the throttle to return to a normal position, I had to add a really big spring to pull the throttle back into position. I've taken the carb off and cleaned the spring and checked it pretty well. It's fairly tight, and I don't think I could turn the spring another revolution tighter.
Am I doing something wrong? Do I just need to get a stronger spring for the throttle? Or should I just try to twist one more time? |
69 Jim Samba Member
Joined: September 27, 2004 Posts: 6264 Location: Chickengeorge's Neighbor
Posted: Mon May 24, 2010 6:57 pm Post subject: |
Disconnect the throttle cable and see if it the arm returns easily. |
alexnwolf Samba Member
Joined: July 31, 2009 Posts: 142 Location: Redondo Beach, CA
Posted: Mon May 24, 2010 7:00 pm Post subject: |
gunky cable guide tube? |
Posted: Mon May 24, 2010 7:15 pm Post subject: |
I thought it was a gunky cable guide tube, which gave me an excuse to install one of those fancy roller tubes (plus, my original one had a wear point in it). While I had the throttle cable disconnected, I cleaned up the whole area and tested it without the cable on, and it still doesn't fully return.
It's driving me nuts. |
jwagner Samba Member
Joined: July 15, 2008 Posts: 574 Location: chicago il
Posted: Mon May 24, 2010 7:17 pm Post subject: |
dude im having the same problem! _________________ -1973 Super Beetle DD in need of resto |
stevelangford Samba Member
Posted: Mon May 24, 2010 7:39 pm Post subject: |
carb bushings.
use a stronger spring and try to lubricate the bushings, it may help, if not, then time for a new carb or at least new bushings |
69 Jim Samba Member
Posted: Mon May 24, 2010 7:48 pm Post subject: |
Is the accelerator pump arm hitting the fan shroud? |
Posted: Mon May 24, 2010 7:54 pm Post subject: |
I don't think so, but I'll check in the morning.
Thanks for all the tips guys. Hopefully I can dump this secondary spring tomorrow! |
