RIOMX Samba Member
Joined: September 30, 2005 Posts: 1234 Location: La Crosse, WI
Posted: Tue May 25, 2010 7:22 am Post subject: 12v Power Outlet Behind-Dash Installation Photos |
I have a huge favor to ask of anyone that has a 12v Power Outlet in their dash - could you post a photo of how you wired it to the auxiliary fuse?
I've searched threads going back to 2005 and while everyone has described different methods and places where they installed it, no one has posted photos of wiring going to the auxiliary fuse.
I'm about 2 days away from leaving on a road trip, so I'm going to try to do this in the last few hours before we take off. I haven't done much wiring, so I'm trying to research as much as possible so as to not screw anything up right before we leave.
Thanks in advance,
- Joe |
sped372 Samba Member
Joined: March 30, 2006 Posts: 653 Location: Waunakee, WI
Posted: Tue May 25, 2010 7:29 am Post subject: Re: 12v Power Outlet Behind-Dash Installation Photos |
RIOMX wrote: |
Thanks in advance,
- Joe |
In my experience it isn't wise to mess with stuff in the last few hours before you leave. I replaced our dash pad once and spent an hour diagnosing why the bus would no longer start... with ice in the icebox as we were planning to head out. I inadvertently knocked the "hot" ignition wire out of the fusebox.
Projects always seem to take longer than you'd expect... if it were me I'd try to make your trip without the socket and install something once you're back. That way you have ample time and no pressure to troubleshoot, especially if you haven't tackled many wiring projects before.
Really though, all you need to do is tap into +12 of your choice. Either something that's hot with the key on, or something that's hot all the time. Make sure you go to the correct side of the fuse or your new 'circuit' will not be protected in the event of a short.
Just my $0.02. _________________ 1971 Karmann Ghia - 1600 DP
1984 Westfalia - 1.9 WBX |
ChuxBus Samba Member
Joined: March 19, 2005 Posts: 297 Location: East Atlanta, GA
Posted: Tue May 25, 2010 7:37 am Post subject: |
"accessory" fuse? Number 7? Or are you talking about an aux fuse panel?
I'd attach the pos lead to the spade above the #7 fuse and ground the neg lead to the body. _________________ -Chuck
1978 Bus & 1969 Bug
"Don't make a fuss, just get on the bus" -Frank Zappa |
RIOMX Samba Member
Posted: Tue May 25, 2010 7:41 am Post subject: Re: 12v Power Outlet Behind-Dash Installation Photos |
sped372 wrote: |
Just my $0.02. |
I hear ya. A friend of mine was helping me with fixing my dash heat levers recently and we bumped a wire behind the dash. I smelled a burning wire and my hazards no longer work - I'm fixing this before I leave, but with help.
The biggest reason I need the power outlet is because we need to keep our phones charged for navigation as well as making calls in the event of an emergency.
Though Android phones are awesome, they also use tons of battery power and need to be constantly charged. I just don't want us to be stranded without a way to call for towing or help. |
RIOMX Samba Member
Posted: Tue May 25, 2010 7:42 am Post subject: |
ChuxBus wrote: |
I'd attach the pos lead to the spade above the #7 fuse and ground the neg lead to the body. |
Yes - the number 7 fuse for accessories.
Thanks for the info - sounds like it might be simpler than I thought. |
Randy in Maine Samba Member
RIOMX Samba Member
Posted: Tue May 25, 2010 8:12 am Post subject: |
Unfortunately not. A previous owner punched a hole next to the defrost. No big deal - the dash isn't perfect. Plus, I don't have to feel bad about making a hole.
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1399 Location: Cambridge, MA
Posted: Tue May 25, 2010 8:21 am Post subject: |
If your rear defrost doesn't work (which most don't) just re-purpose that wire. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51145 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Tue May 25, 2010 8:30 am Post subject: |
That's an excellent option if you don't mind the power shutting off with the key, if you want it on all the time run a new red wire to the empty spade terminal on the back (front actually) of the fuse box above fuse #7, 12ga if possible. You shouldn't have to disturb too much to hook it up but disconnect your battery first anyways. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
blitz18qb Samba Member
Joined: April 21, 2010 Posts: 138 Location: Sacramento
Posted: Tue May 25, 2010 8:48 am Post subject: |
I usually splice into the wires from the stereo (to me that looks like a modern stereo with the facia off?) although I haven't had my coffee yet and my eyes are a bit 'off target'.
In the modern stereos, I would splice into the red wire if you want power all the time, and yellow wire for turn key power. Usually, there's plenty of working room on stereo's as most leave a bit of extra slack to play with once its installed.
These wiring colors have been true of every stereo I have installed and that is 7 - so I am guessing they are all similar!
Of course, your set up might be different _________________ Wilma - 1979 Adventurewagen - 2.0 Automatic |
RIOMX Samba Member
Posted: Tue May 25, 2010 9:44 am Post subject: |
busdaddy wrote: |
That's an excellent option if you don't mind the power shutting off with the key, if you want it on all the time run a new red wire to the empty spade terminal on the back (front actually) of the fuse box above fuse #7, 12ga if possible. You shouldn't have to disturb too much to hook it up but disconnect your battery first anyways. |
I'll have to think about it. I wouldn't be too bothered if they turned off when I took the key out.
Thanks for the tip on gauge. I'll have to see what comes with the kit I buy. |
RIOMX Samba Member
blitz18qb wrote: |
Of course, your set up might be different |
It is a modern stereo, but I'm not messing with it |
Desertbusman Samba Member
Posted: Tue May 25, 2010 10:02 am Post subject: |
Consider both the advantages and problems with having it keyed or not keyed. My bug is keyed and when I use the air compressor or anything else the ignition is also turned on which can burn out electronic ignition. (although it never has). If you have it unkeyed there is the chance of leaving something running and running down the battery. With my bus I have it keyed to the ignition switch with an accessory position so I can't harm the ignition. However when camping and leaving a fan, the cooler, or something plugged in and running I also have to have the key in the ignition. So if some jerk came along while I stepped away from it he could steal the bus.
Also consider that your cigarette lighter socket is apt to be used with big current draw items. So don't wire it into some little circuit that should be protected with a little fuse. So only connect it to a big capacity circuit and also give it it's own inline fuse. _________________ 71 Superbug
71 Westy
Last edited by Desertbusman on Tue May 25, 2010 10:08 am; edited 2 times in total |
Posted: Tue May 25, 2010 10:27 am Post subject: |
In my bus I have the cigarette lighter up front wired to the defrost wire (on and off with key)
I have another outlet in the back hooked up directly to the aux battery for items that want to be on while parked. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Posted: Tue May 25, 2010 10:35 am Post subject: |
If you wanted to just rig something up without messing with your wiring to achieve what you desire, I often hook one of these:
To a spare battery I have laying around...
Should do the job nicely in the short term, and there should be plenty of juice in a battery to deal will cell phones...
Just an idea (those sockets are available at all good auto stores - and some rubbish ones) _________________ Wilma - 1979 Adventurewagen - 2.0 Automatic |
