vwsb74 Samba Member
Posted: Tue May 25, 2010 9:18 pm Post subject: Which flame thrower? |
Hi, which flame thrower to use for svda with pertronix ignition 1, is it 1.5 ohm or the 3.0 ohm? _________________ 74 super beetle
2011 ford explorer traded
2010 mazda 3 hatchback
2014 Honda odyssey
2180cc 48IDA clone
Xr310 cam =171hp@6k rpm sold so as the car😢 |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Tue May 25, 2010 9:38 pm Post subject: |
3 ohm is what you want.
the 1.5 is mainly for V8 apps I believe. |
vwsb74 Samba Member
Posted: Tue May 25, 2010 9:58 pm Post subject: |
[quote="modok"]3 ohm is what you want.
the 1.5 is mainly for V8 apps I believe.[/quote
thanks a lot I buy the 3.0 _________________ 74 super beetle
2014 Honda odyssey
2180cc 48IDA clone
DerrickfromNC1 Samba Member
Joined: October 24, 2008 Posts: 1302 Location: North Carolina
Posted: Thu Nov 17, 2022 3:31 pm Post subject: |
modok wrote: |
I just purchased a Flame Thrower(1.5ohm) thru Amazon. Reading this I should have purchased the 3.0ohm version.
What concerns should I have? If it makes a difference I have an 009 with a pertronix ignition 1
Thanks |
74 Thing Samba Member
Posted: Thu Nov 17, 2022 3:53 pm Post subject: |
DerrickfromNC1 wrote: |
modok wrote: |
Thanks |
Unless you are running an ignition box like a CDI, then with the Pertronix Ignitor 1 module you should be running at least a 3 ohm coil or you may burn out the Ignitor:
https://pertronixbrands.com/collections/flame-thrower-canister-coils |
Posted: Sun Jan 29, 2023 8:47 am Post subject: Re: Which flame thrower? |
I have a MSD distributor….can I run the 1.5ohm Flame Thrower?
Thanks |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3466 Location: Paradise, Ca
Posted: Sun Jan 29, 2023 11:57 am Post subject: Re: Which flame thrower? |
Thanks |
Which CDI box are you using? |
Posted: Thu Feb 02, 2023 3:16 am Post subject: Re: Which flame thrower? |
jpaull wrote: |
Thanks |
I feel a little stupid responding back to this question but I was under the impression that the MSD distributor was similar to the CB Magnaspark dizzys in that all I needed to do was to hook a coil straight to it.
Don’t Laugh! |
madmike Samba Member
Joined: July 11, 2005 Posts: 5292 Location: Atlanta,Michigan
Posted: Thu Feb 02, 2023 5:09 am Post subject: Re: Which flame thrower? |
Yep, You have to have a CDI box to run the MSD Diz. _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Posted: Thu Feb 02, 2023 7:58 am Post subject: Re: Which flame thrower? |
madmike wrote: |
Yep, You have to have a CDI box to run the MSD Diz. |
Yep I’m going to have to rethink my next move as I get closer to getting my car back on the road. I can get a new ready to run MagnaSpark dizzy for a little more than the price of a used CDI box & sell my new MSD & use those dollars on a Blackbox. I will need to reread the 38 pages of JPaull “MSD dizzy tips & tricks” to determine which direction I go.
For what it’s worth the motor currently is a 2332 shortblock with an 86b with a set of NOS 48dells in my parts bin. Looking at purchasing possibly a set of CB Ultra Mag, MiniWedges, or WedgePorts and dial in a cr around 8.75-9.0 with plans to go carbureted blowthru turbo with a water/methane injection as needed dependent on boost.
Last edited by DerrickfromNC1 on Thu Feb 02, 2023 8:32 am; edited 1 time in total |
Posted: Thu Feb 02, 2023 8:08 am Post subject: Re: Which flame thrower? |
Wasn't it the Megaspark they were having some issues with?
I've had my MSD Diz. in a few different set ups & Cars, always reliable ,,Yes re read Jeffs post's (I just saw a Mallory box in the classifides a few days ago for $175 Kafer mike's)Cheers,Mike _________________ 'Black Ice'Drag Buggy 'Turbo'
Posted: Thu Feb 02, 2023 8:30 am Post subject: Re: Which flame thrower? |
madmike wrote: |
I think it was the programmable(Digital) MagnaSpark that had issues and is no longer available on CBs website. Don’t remember exactly what the issue was but I actually have that version with the programming disc in my parts bin that I purchased many yrs ago used on samba b4 I read about some users having problems. I may give it a try.…..it has 4 preprogrammed ignition curves that can be set with internal toggle switches……2 for N/A and 2 for Turbo. I will have to go back thru those threads to see if the problems was with the users or the dizzy.
Here’s one in the classified now:
https://www.thesamba.com/vw/classifieds/detail.php?id=2583598 |
