Wiring gauge to use in engine compartment
maddriverman
maddriverman is offline
PostPosted: Wed May 26, 2010 6:01 pm    Post subject: Reply with quote
Can anybody tell what a good guage wire would work for the engine sect,
including the oilsend. unit everything I need seems to be the real thin wire.
the generator wires are great its just the other 2 or three wires goin to the carb and coil.
PostPosted: Wed May 26, 2010 6:11 pm    Post subject: Reply with quote
Here's what I do.
Look at the '63 wiring diagram,
http://www.thesamba.com/vw/archives/info/wiring/bus_63_USA.jpg
The gauge used for the oil light wire is 0,5
According to this page in the Wiring section of this site:
http://www.thesamba.com/vw/archives/info/wireconversion.php
0,5 = 20 gauge
So you should be fine with 20 gauge. From hacked Buses I have seen, a lot of people use 16 though, I think because it's commonly on hand.
Emeritusx
Emeritusx is offline
PostPosted: Wed May 26, 2010 6:30 pm    Post subject: Reply with quote
Better to go a little big than too small...
82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠
campingbox
campingbox is offline
PostPosted: Wed May 26, 2010 6:55 pm    Post subject: Reply with quote
If you have a parts bus you could cut up the wiring harness, usually the stuff in the middle of the long PVC tube is in great shape and is ideal for making repairs. I like to solder, shrinkwrap, and then cover the repairs with fresh pieces of PVC tubing. It takes a little bit more time but the repairs are pretty much invisible.
hitest
hitest is offline
PostPosted: Wed May 26, 2010 7:39 pm    Post subject: Reply with quote
Greg said it best. Find a bay in a junkyard (where you'll find most bays anyway)- and liberate its harness. My engine bay now looks exactly as it should- and I have spare 'coils' of color coded wire for every future need.
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '68 L30k 141, '71 L12 113, '74 ORG 181
FU#5
maddriverman
PostPosted: Wed May 26, 2010 11:22 pm    Post subject: Reply with quote
Im sure not everyones a fan of this idea...But,is there a size or gauge of wire that will work for the carb,coil & oil send. unit?..
maddriverman
PostPosted: Thu May 27, 2010 7:46 am    Post subject: Reply with quote
From your post everett,16 gauge will work in the engine compartment?
At least for a hack job.
PostPosted: Thu May 27, 2010 9:04 am    Post subject: Reply with quote
If you look at the wiring diagram above, it looks like the largest size used is 1,5 which equates to about 15 gauge but I think 16 gauge will be ok for those wires.
I've had 16 gauge for some of those wires on various Buses and not had any issues.
maddriverman
PostPosted: Thu May 27, 2010 9:27 am    Post subject: Reply with quote
Thank you!!
Alexmobil
Alexmobil is offline
PostPosted: Tue Aug 25, 2015 3:46 pm    Post subject: Reply with quote
Zombie thread warning =)
Hello Everybody. Im about to rewire the Double Cab.
Printed and studied the wiring diagram, conversion chart and I bought/ repaired most of the switchs and electrical related stuff.
The question is: The AWG 20 wire for the tail light circuit seems to be too thin
Is it a deliberate way to underpower the tail light circuit to make noticeable the brake light brightness? ( circuit with AWG 16 wire)
Im using the wiring diagram vw transporter from aug 1966.
Thanks in advance.
Eric&Barb
Eric&Barb is offline
PostPosted: Tue Aug 25, 2015 7:42 pm    Post subject: Reply with quote
If it was too small the wire would run hot. No problem with that for us.
We likey zombies!
In Stereo, Where Available!
