steph27 Samba Member
Posted: Sun Mar 25, 2018 11:48 am Post subject: Re: 1974 Westfalia Weekender |
I'm really happy with his condition.
The interior needs a lot of cleaning, but the conditions are good.
There were mousse, and there is a very strong smell !!
And discovered under the bench, it is equipped with a compressor for the cooler
I have the original curtains, that of the cabin too, and even the mosquito net.
By cons I do not have the gas
I beguan washing the carpette, and he's in good condition |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sun Mar 25, 2018 12:11 pm Post subject: Re: 1974 Westfalia Weekender |
Very good! Love to see it.
I would take everything out of the bus, clean the bus inside then clean everything before going back.
Yes the read bed is big
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
sneakyjack Samba Member
Joined: January 14, 2010 Posts: 560 Location: SOuthern VT
Posted: Thu Jul 05, 2018 8:56 pm Post subject: Re: 1974 Westfalia Weekender |
Notch!
just sayin _________________ Nothin left to do....
www.idolmakerfilms.com |
Posted: Mon Jul 23, 2018 11:41 pm Post subject: Re: 1974 Westfalia Weekender |
Ok,
Did some real fiddly shit last couple days. This small detail stuff is a pain. Especially when the after market stuff is close but not right.
Got 99% of the driver door guts in. Just need the inner scraper. What a PITA these are I forgot the joy involved in putting a torn apart door back together.
Got working on these nice aftermarket curtains - see you need to put the snaps on them. The little ones for the curtain to curtain are too small and flimsy. I found spot on OG ones at Michaels.
Now I can get all the cabs in! Yeah.
Compared to OG material, several light changes to see.
Missing a part for the Jail bar.
t3kg wrote: |
1964 1500 S
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Mon Jul 23, 2018 11:51 pm Post subject: Re: 1974 Westfalia Weekender |
…Please tell me you saved the inner metal structure of the inner scraper, and you're only using the new rubber? New metal is teh pits.
Thanks 70crew for this reminder! It's saved me and some customers over the last two years!
www.airschooled.com |
Posted: Tue Jul 24, 2018 12:26 am Post subject: Re: 1974 Westfalia Weekender |
Pshhhh what? Of course man. That's a rookie error. I'm no newb I used the OG clips for the outer as well. _________________
t3kg wrote: |
1964 1500 S
Posted: Tue Jul 24, 2018 12:30 am Post subject: Re: 1974 Westfalia Weekender |
notchboy wrote: |
Pshhhh what? Of course man. That's a rookie error. I'm no newb I used the OG clips for the outer as well. |
Nice! Now just go read your crystal ball and get Xevin's Eberspacher working……
Posted: Tue Jul 24, 2018 12:48 am Post subject: Re: 1974 Westfalia Weekender |
asiab3 wrote: |
notchboy wrote: |
Robbie |
I thought it was? Didnt Stew swap out the restored one I did? I have his old one here and it works fine. His plug was bad in the old one. _________________
t3kg wrote: |
1964 1500 S
Stuartzickefoose Samba Post Whore
Joined: February 07, 2008 Posts: 10350 Location: SoCal for now...
Posted: Wed Jul 25, 2018 10:13 am Post subject: Re: 1974 Westfalia Weekender |
notchboy wrote: |
asiab3 wrote: |
notchboy wrote: |
Robbie |
I thought it was? Didnt Stew swap out the restored one I did? I have his old one here and it works fine. His plug was bad in the old one. |
Some shithead must have decided to hook wires up wrong on the coil. Maybe he should drive his bus back and fix it himself as an apology...
And no it wasn’t me. _________________ Stuart Zickefoose
206-841-7324
[email protected] |
white74westy Samba Member
Posted: Wed Jul 25, 2018 11:41 am Post subject: Re: 1974 Westfalia Weekender |
Looking good bro! Keep at it! |
Posted: Sat Jul 28, 2018 12:01 pm Post subject: Re: 1974 Westfalia Weekender |
Just finished some more install to the interior. Got the headbanger in, long side soffit, and finished the curtains. When putting the headbanger in - I failed to reinstall its pass side mounting brackets. They install under the headliner, under the soffit mounting bar
So off came the rear headliner board. Once that was in I figured the headbanger was a sinch. I think it might have been if I had another set of hands but I didn't and had to get clever on install.
So I went nuts and posted to FB and now here, on a mostly complete, new interior.
Blue Plaid Overload.
t3kg wrote: |
1964 1500 S
Posted: Sat Jul 28, 2018 6:03 pm Post subject: Re: 1974 Westfalia Weekender |
A special part of the build where I once again alter a completely pristine surviving part of the bus to fit accessories. I already cut the steel firewall to the motor for the Eberspacher BN4 ducting to enter the cabin of the bus. I now had to finalize the destruction to the base of the Westy seat laminate. An 80mm hole was needed to place the final ducting collar to enter at the foot of the back bench. Just as Carl Frimmer, Certified VW Mechanic of Olympic Motors Inc would have done in 1976. This after Mr. Zimski of Port Angeles brought his Camper in to be fitted with a BN4, since Mrs. Zimski would not camp unless she could get warm when needed.
Now at the twist of a knob, the cabin of the 74 Westfalia can now be warmed quickly to 80-85 degrees Fahrenheit.
I did a test cut first to get the feel of the mighty blade, then just basically went at it based on two other fitted heaters I had pics of.
Balls or stupidity? I had a beer after.
As seen in other "factory fitted" set ups.
Ok lets do it! Practice and application.
t3kg wrote: |
1964 1500 S
67ctbug Samba Member
Posted: Sat Jul 28, 2018 6:41 pm Post subject: Re: 1974 Westfalia Weekender |
notchboy wrote: |
That’s not a thing _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
wcfvw69 Samba Purist
Posted: Sat Jul 28, 2018 7:00 pm Post subject: Re: 1974 Westfalia Weekender |
I don't think installing that factory heater does any harm to the VW at all. Your clean installation looks like it was done at the factory. If anything to me, it would add value to the bus if you sell it down the road.
Overall, the interior is looking amazing. Well plaid, oops, I mean well played. _________________ Contact me at [email protected]
The Samba member since 2004.
Posted: Sat Jul 28, 2018 7:23 pm Post subject: Re: 1974 Westfalia Weekender |
wcfvw69 wrote: |
Overall, the interior is looking amazing. Well plaid, oops, I mean well played. |
Thanks guys.
I agree with the accessory installation. Im going to enjoy them when I can People always complain when you use a NOS accessory, those that complain you cut into a pristine car and even those that say because of all that its not original.
Its cool. They are the same ones that later when scanning the web say how cool that accessory is and how they wish they had one. Thats the funny part with people. My comments on cutting into stuff is purely tongue and cheek. If Im anything its an accessory whore ready for a night out.
Im installing jail bars next. _________________
t3kg wrote: |
1964 1500 S
pittwagen Samba Member
Joined: November 08, 2005 Posts: 766 Location: North of the 49th parallel
Posted: Sat Jul 28, 2018 9:18 pm Post subject: Re: 1974 Westfalia Weekender |
On my 74 P21 the BN4 was factory installed as were the fresh air fans.
How did the JK sliders go in. Sure wish there was a bug screen option. |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22671 Location: NYC/Upstate/ROW
Posted: Sun Jul 29, 2018 3:58 am Post subject: Re: 1974 Westfalia Weekender |
Nice.
I learned a trick with those hole saws on boats. You can stop,splitting by scoring the work surface by running it backwards to start, once you have the line set in a mm or so, reverse and make the cut.
And don’t try to make the hole cut in stages. Yes, I really did this once, in my youth..doh! _________________ .ssS! |
