WHITEWESTY Samba Member
Joined: April 17, 2009 Posts: 90 Location: SPOKANE, WA
Posted: Mon May 31, 2010 8:27 am Post subject: Has anyone added shelves in rear closet? |
Has anyone added shelves to the rear closet of their van? I actually only need one or two. It looks like it would be fairly easy but the panel on the window side are thin and flexible and would probably need some sort of re-enforcement. I don't plan on putting anything too heavy and would like it to be removable if possible. |
campism Samba Member
Joined: September 07, 2007 Posts: 4485 Location: Richmond VA
Posted: Mon May 31, 2010 9:06 am Post subject: |
Yes, but I also enlarged the door opening, going from the single hinged door to dual sliders on the closet wall facing the mattress. For the shelves I used leftover door luan painted grey to match the Westy interior and for the shelf brackets used four vertical tracks with lots of little slots (two on the inner wall where the front closet door is, and two on the inner bulkhead) from Lowe's that use the little clips for setting the shelf height. The shelves are more useful for us than the hanging locker. I have pix somwhere.
A little later: I just took some detail pix that I'll post tomorrow. Per 1621's note below, it does take a lot of nerve to cut into a pristine cabinet just because you want to "improve" it.
MootPoint Samba Member
Joined: September 16, 2006 Posts: 862 Location: ABQ, NM
Posted: Mon May 31, 2010 9:29 am Post subject: |
Funny you should mention that. I was just going to begin that project today. I added a side door (a recycled Dometic door from Pick-n-Pull) a couple of years ago, but the project stopped there:
No, I don't have a shot with the door open, but you already know what the interior looks like.
My plan was to add some simple shelf hangers, probably the perforation-and-peg variety that you might find in your stereo cabinet with the attachment points being on the inside of the frame of the mirror door and on the opposite wall, the interior of the far closet. I wouldn't carry thunderously heavy stuff in there (Ms. MootPoint want to use the closet for "soft goods") but I do want to be able to adjust the shelves to fit, plus I carry the two multi-step plastic leveling blocks in the very bottom of that cabinet and they need enough open room to wrestle them out through the mirror door.
The shelves themselves will either be painted plywood with some of the plastic T-molding around the edge so they look OME or I might even have enough original kitchen laminate to make the shelves and add the T-molding.
I'll post some pix when it's done _________________ 1984 Westy with tencentlife power! |
vweggie Samba Member
Joined: May 01, 2007 Posts: 219 Location: End of the road, Vancouver Island
Posted: Mon May 31, 2010 9:37 am Post subject: |
My '90 Multivan came stock with removable shelves in both back closets. The used a combination of saw kerfs and plastic pins to mount the shelves. _________________ 1990 Multivan 2.1 AT |
1621 Samba Member
Posted: Mon May 31, 2010 11:29 am Post subject: |
I've thought about adding some simple vinyl coated wire shelving in the rear closet - like the stuff they carry at HD or Lowe's. I think the wire shelving would allow for more light (I've got a little dome light inside the closet), and it's less likely to collect a bunch of dust.
Still love Moot's extra closet door. I've collected the materials and even the detailed instructions from Mr. Moot himself. I'm just missing the balls necessary to cut into the pristine cabinet wall.
Thanks for bringing this one up again. _________________ '85 Westy |
Microbusdeluxe Samba Member
Joined: July 26, 2003 Posts: 977 Location: Bellingham, WA
Posted: Mon May 31, 2010 12:40 pm Post subject: |
Cut the hole for the side door. I did it and it was the best enhanced storage fix ever. Looking at Mootpoints I put my hinges for my new door to the rear of the van, making access from over the back seat easier. _________________ '69 Squareback RIP
'65 21 window deluxe sold before the price spike, damn it.
'70 rhd bay now a taxi in South Sudan
'81 Westy sold
'89 hightop Westy Joker syncro 16" now with Bostig! |
Posted: Mon May 31, 2010 12:57 pm Post subject: |
1621, go for it! Just breathe deeply before you reach for the sawzall.
(BTW, since I did the cupboard door, I've learned that a 3" dia. hole cutter gives exactly the right radius for the corners and is a (w)hole lot easier than trying to cut a smooth circle by hand.)
I had so much fun adding the back cabinet door that I just added another into the under-seat storage. Why? I rarely travel with more than one passenger so the bed it almost always down for storage of long stuff like a guitar or awning poles. But that means that getting into the under-seat storage is a PITA because you have to put the bed into the seat position before you can lift the seat for access. So...
I built a small separate compartment for the small stuff that is the most often needed such as Mr. Bentley and Mr. Haynes, some oil, some PS fluid, the simple-tools tool roll (the master kit - like I'm a master mechanic? - Right...) is under the main portion along with the big stuff that only comes out in emergencies or a major camping set up. I made the larger portion of the storage lockable a while back so when I need small stuff quick it's there without hassle.
I like the idea of the vinyl wire shelving. Hmmm.... _________________ 1984 Westy with tencentlife power! |
Posted: Mon May 31, 2010 1:02 pm Post subject: |
Microbusdeluxe wrote: |
I put my hinges for my new door to the rear of the van, making access from over the back seat easier. |
I planned to do that but I felt the hinge placement would be a bit weird because with the door flipped 180° the used-to-be-upper hinge was way low. The frame hinge part are screwed in; the door part is riveted in and looked like a hassle to change so I left it.
For that matter, I had the same issue with my under-seat storage (above) and I probably would have preferred to have it open toward the sliding door but it's OK the way it is. _________________ 1984 Westy with tencentlife power! |
DAIZEE Samba Member
Joined: January 26, 2010 Posts: 7552 Location: Greater Toronto Area Ontario West Side
Posted: Mon May 31, 2010 1:05 pm Post subject: |
I usually travel with the bed down. When we redid Scooby we took out the bulk head under the seat and now it it open. Thinking about what I'll do. Will most likely use a cargo net to stabilize stuff.
Having a Riviera now I have all kinds of cupboards on both sides. Have 2 doors into 2 hanging lockers. Removed the bulkhead between the 2 and now just one big area with 1/2 being over the wheel well and the aft half being much deeper. I will build a removeable false floor for the aft. It will be a good place to store dry goods. That window has a painted board covering the entire window which gives more width to the closet. I can remove the board easily anytime now that the partition is gone. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold) |
Posted: Mon May 31, 2010 1:10 pm Post subject: |
I ran into the same thing hinge-wise, at first I thought there were 2 different hinge styles (left hand/right hand) But actually drillling out the rivet, replace it with a small screw and driving out the pin, and then reverse it was very easy.
A bigger problem was edging material (ie T moulding). Used some from a cabinet supply house, brown color was good, but it is a bit wider that original. I just routed the kerf to let the moulding run wild on the inside of the opening and it looks fime. _________________ '69 Squareback RIP
'81 Westy sold
Posted: Mon May 31, 2010 6:34 pm Post subject: |
But actually drillling out the rivet, replace it with a small screw and driving out the pin, and then reverse it was very easy. |
You're more inventive than I. I got to the rivet and figured, to heck with it. Glad that worked.
A bigger problem was edging material (ie T moulding). Used some from a cabinet supply house, brown color was good, but it is a bit wider that original. I just routed the kerf to let the moulding run wild on the inside of the opening and it looks fime. |
I got my T-molding from Rockler, IIRC. It was indeed a tad wider than the laminate ply, but I just installed it and then sliced it to fit with a single edge razor blade on the outside so it was flush with the surface. Looks good to my ancient eyes. _________________ 1984 Westy with tencentlife power! |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 924 Location: Calgary, Canada
Posted: Mon May 31, 2010 7:45 pm Post subject: |
Another wardrobe rebuild story is here:
www.griffco.ca/interest/ and look for the Westfalia link then Wardrobe Doors. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Tue Jun 01, 2010 12:16 pm Post subject: |
I expanded the opening for better access and made new doors and shelves out of luan.
Sliders take up no room in the mattress area.
With doors off you can see the new space.
Hardware from Lowe’s or HoDepot does just fine here.
I reused the grey T-edging to finish the new opening.
DAIZEE Samba Member
Posted: Tue Jun 01, 2010 12:32 pm Post subject: |
Oh I like that sliding door and shelving unit. That is so neat and functional. Good job. _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
madspaniard Samba Member
Posted: Tue Jun 01, 2010 1:51 pm Post subject: |
man, those sliding doors look great, very practical, I would go that route instead of the two separate doors, great job. _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Keith Kiernicki Samba Member
Posted: Tue Jun 01, 2010 2:22 pm Post subject: |
I love those sliding doors! Where did you get most of the door material from? |
buildyourown Samba Member
Posted: Tue Jun 01, 2010 2:23 pm Post subject: |
The only problem I see with the sliding doors is getting to the stuff in the middle. ie, you can't get that blue rubbermade from either door without moving other stuff.
Good way to open up the space though.
Personally, that closet holds all my bedding and it just gets shoved in thru the side door. |
1621 Samba Member
Posted: Tue Jun 01, 2010 2:33 pm Post subject: |
Campism, that is beautifully executed! I love the craftsmanship that went into that one. It's also very nice to have doors that slide versus swing outs due to the other stuff that inevitably gets crammed in h back. nc ork!
Just returned from the hardware store and verified Mootpoint's hole saw tip. The 3" is good for the smaller doors, and 4" is what you want for the larger refrigerator door. It's nearly a perfect match. I'm now one step closer to starting this project. Soon... _________________ '85 Westy |
Posted: Tue Jun 01, 2010 4:09 pm Post subject: |
I stole the idea from a veteran Vanagon guy, Frank Condelli, who posts on the Yahoo Vanagon group and has a web page for his stuff, so props to him. I used luan for the door and shelves, available at any lumberyard or home improvement place. The doors could still be trimmed for better access (the blue tub); I just don't want to triim too much and have to do it over. Glad you like it. |
DAIZEE Samba Member
Posted: Tue Jun 01, 2010 4:11 pm Post subject: |
Perhaps things rarely used could be positioned there or a simple rearrangement of priority items. Good point but overcomeable
I have two access doors on that same bulkhead and wouldn't those sliding doors look GREAT there. hmm my talents don't go that far _________________ '09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
