bbbjim Samba Member
Posted: Tue Jun 01, 2010 7:37 am Post subject: What does this hose do? |
Hi all, staring at my engine (don't we all), I am wondering what the expensive coolant hose that runs from the left head on the #4 spark plug side, steps down in size, and connects to the coolant rail that runs around the engine compartment does? I've had a persistant leak where it attaches to the rail as I don't think the hose steps down quite enough to seal well (even with two clamps) to the rail. Also I notice that hose doesn't seem to heat up like the other hoses attached to the rail. Bentley is no help and one of the parts dealers refers to it as for Vans with A/C. Thanks, puzzling Jim _________________ 1987 Westy aka Moon Shadow
1966 Delux aka Cloud Woman |
BillM Samba Member
Joined: June 18, 2004 Posts: 1381 Location: Stonington,CT
Posted: Tue Jun 01, 2010 8:07 am Post subject: |
If your talking about the hose I am thinking your are it looks kinda like
a pipe with a really long stem?? It is part of the system that the 2.1 uses to "self" bleed the coolant system. Do you have enough length on the hose where you could snip off a small section so you will have fresh rubber to clamp to? I have also found for a leaking hose is to put a bit of hylomar on the hose and then clamp it. Let it set up for an hour or so before adding coolant. This has worked where I have had a water outlet that was pitted up and I couldn't get a seal. Is your coolant ring plastic or metal? If its the plastic one too much clamping pressure will cause distortion that may make it leak. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10075 Location: Abiquiu, NM, USA
Posted: Tue Jun 01, 2010 8:32 am Post subject: |
Right, it's just an air purge hose, and that one typically runs cool. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
bbbjim Samba Member
Posted: Tue Jun 01, 2010 3:31 pm Post subject: |
Thanks for the replys, it's good to know there is a coolant hose that should run cool. No longer puzzled Jim. _________________ 1987 Westy aka Moon Shadow
r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 591 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Thu May 05, 2011 6:27 pm Post subject: |
if the hose is still serviceable after a little trim and the mating surface sanded/cleaned up with possible use of hylomar or curil. i always prefer to use oem style clamps. ive seen very few leak when the hose and clamp were in good condition. In the vanagon oem spring clamps design prevents the overtightening you were concerned about.
before anybody wants to make this thread a debate about clamps be aware you wont be saying anything that hasn't already been posted many many times already. |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10248 Location: N. Idaho
Posted: Thu May 05, 2011 6:30 pm Post subject: |
Um, regarding hose clamps, can I just say I hate the OEM spring clamps with the little tongue thing that prevents me from opening them enough to get off swollen old hoses. Hate would be the operative word........
Back to regular programming.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
Posted: Thu May 05, 2011 7:13 pm Post subject: |
IdahoDoug wrote: |
Um, regarding hose clamps, can I just say I hate the OEM spring clamps with the little tongue thing that prevents me from opening them enough to get off swollen old hoses. |
i know what you mean. the tab is there though to prevent over opening. some people grind off the tab. ive always been able to get them off with lots of silicone spray a little patience and a variety of hose clamp pliers. se tools make my favorite. |
teej Samba Member
Joined: November 26, 2010 Posts: 897 Location: Seattle
Posted: Fri May 06, 2011 7:36 am Post subject: |
I agree with both of the above posters, having just gone through 40 clamps or so. I kept and re-used the handful of spring clamps I had, re-installing them in the hard to access spots where future tightening would be difficult, (front heater valve, for example), or on plastic nipples when I could (heater cores). I like that they can self-adjust with thermal/seasonal changes. I found a spring clamp pliers at Sears that uses a cable. Yep they were still a pain to wiggle off swollen hoses because of the limiting tab, I too used silicone lube.
Back on topic, I'm relieved to learn that it is normal for that hose to run cool. It seems whatever the question, eventually there will be an answer on the samba. _________________ 1986+ Wolfsburg Weekender Pop-Top 2.3 WBX Manual Trans |
floodwood Samba Member
Joined: October 22, 2017 Posts: 163 Location: Cambridge, MA
Posted: Wed May 12, 2021 9:28 am Post subject: Re: What does this hose do? |
I was wondering if anyone had any more information about the "peace pipe", cooling hose 025-121-058M which connects from the 3/4 cylinder side up to the bleeder ring. Pic from a similar thread below:
https://www.thesamba.com/vw/forum/viewtopic.php?t=462973&highlight=peace+pipe
I recently had an issue where the fitting for this hose broke apart and leaked coolant all over the road. Although my mechanic was able to isolate the leak to here (thankfully not the waterjacket seals which are close by), it appears from this thread that the hose usually runs cool (arrow in diagram below)
I am unsure if this hose running cool means no coolant flow or simply cool flowing coolant. Can anyone help confirm that I have normal function in my cooling system if there is in fact coolant flowing through this hose? |
SCM Samba Member
Joined: January 26, 2011 Posts: 3114 Location: Bozeman MT
Posted: Wed May 12, 2021 10:08 am Post subject: Re: What does this hose do? |
Yeah, it's normal for all of the coolant hoses to have coolant running from them.
The purpose of the peace pipe hose (along with the other ones that connect to the ring that runs around the top of the engine compartment) is to deliver any air bubbles in the coolant to the expansion tank. From there, they exit through the blue pressure cap to the overflow tank where they vent to the atmosphere. This keeps you from having air in your coolant system. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Wed May 12, 2021 1:45 pm Post subject: Re: What does this hose do? |
Thank you SCM! |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32574 Location: Reading Pennsylvania
