djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
danfromsyr Samba Member
Posted: Sat Aug 03, 2019 5:09 am Post subject: Re: Portable Air Conditioner Unit |
an innovative AC company from Quebec, proof of global warming if there isn't one. _________________
Abscate wrote: |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22668 Location: NYC/Upstate/ROW
Posted: Sat Aug 03, 2019 5:41 am Post subject: Re: Portable Air Conditioner Unit |
Quote: |
That exhaust pipe, although leading most of the hot air outside through your window, still evaporates some heat inside your room. |
#engineeringcringe _________________ .ssS! |
Posted: Mon Dec 09, 2019 10:13 am Post subject: Re: Portable Air Conditioner Unit |
spotted on fleabay
Abscate wrote: |
depps74 Samba Member
Posted: Sat Mar 21, 2020 1:58 pm Post subject: |
SouthOlive wrote: |
I just bought a http://www.walmart.com/ip/Royal-Sovereign-ARP-9009TL-Portable-Air-Conditioner-9-000-BTU/10983097
I chose this model since the dimensions seem to fit my seldom used rear closet. I haven't finished yet, but the plan is to install a return air grill on the closet side, open the closet door for air discharge, and run the exhaust hose to the engine compartment with a backdraft damper. I'm in the process of removing the closet now, so I'll let you know how it goes. |
Did this work? |
Posted: Thu Jul 02, 2020 6:21 pm Post subject: |
914 mike wrote: |
If someone would come up with a portable 12V ac unit that could be powered by a solar set up while people were camping, I would by stock in that company because they would sell the hell out of those things.
Any engineering type people know if it could even be done? |
https://www.zerobreeze.com/products/zero-breeze-ma...NwQAvD_BwE |
Posted: Thu Jul 02, 2020 6:25 pm Post subject: |
still selling on myths and desperation.
depps74 wrote: |
914 mike wrote: |
Abscate wrote: |
clamay Samba Member
Posted: Sun May 29, 2022 7:48 am Post subject: Re: Portable Air Conditioner Unit |
https://www.amazon.com/EENOUR-Portable-Conditioner...amp;sr=8-9
Has anyone purchased or used or seen one of these portable air conditioners?
I was thinking of restoring the air conditioning in my '91 carat but then I ran across this unit and thought that it might be better because it will work when the van is running or not. Any thoughts? _________________ 91 Carat, automatic, GW 2.2, GW EFI, Peloquin TBD
When you come to a fork in the road, take it. --Yogi Berra |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Sun May 29, 2022 10:18 am Post subject: Re: Portable Air Conditioner Unit |
All of those types of portable AC systems are a gimmic at best and certainly not worth $1000
The way I see it, the only real way to get electric AC in a van is by reconfiguring some home window units, buying one of the small mini-split systems or this setup https://undermountac.com/
All of these will require a pretty significant battery bank to be run for any length of time without a generator or the van running.
and even with the van running you will likely need an alternator upgrade.
I have installed one of the Undermount AC systems in a Sprinter and it works pretty well but the condenser fans mounted outside are super loud.
I spoke to the company about it and they just told me it is what it is but I think the fans could be downsized for some quieter units. _________________ Pretty normal daily driver build
https://www.thesamba.com/vw/forum/viewtopic.php?t=708418&highlight=
4x4 build
https://www.expeditionportal.com/forum/threads/volkswagen-vanagon-4x4-conversion.162055/ |
Posted: Sun May 29, 2022 10:48 am Post subject: Re: Portable Air Conditioner Unit |
The next poster of magical AC gets hit over the head with a shovel. _________________ .ssS! |
VdubVanner Samba Member
Joined: August 03, 2017 Posts: 734 Location: Cowtown AB
Tobias Duncan Samba Member
Joined: January 15, 2013 Posts: 1391 Location: Taos NM
Posted: Sun May 29, 2022 2:33 pm Post subject: Re: Portable Air Conditioner Unit |
Abscate wrote: |
The next poster of magical AC gets hit over the head with a shovel. |
At least this one isnt using magical math
It consumes 850 watts and produces 2900 BTUs of cooling which are real world numbers.
Its up to you to power the thing.
Ever try to pull 850 watts through the cigarette lighter? |
clamay Samba Member
Posted: Sun May 29, 2022 4:19 pm Post subject: Re: Portable Air Conditioner Unit |
Did I misread the advertisement? I read that it uses 210 watts of power not 850. 210 watts is consistent with 5000 btu window units that use 410 watts. This unit doesn't seem mystical or magical it is just a smaller more portable air conditioner than others I have seen. 2900 BTUs should be enough to keep the inside of a vanagon cool. And yes, $1000 is a lot to pay but I could easily spend that restoring my old vanagon system. _________________ 91 Carat, automatic, GW 2.2, GW EFI, Peloquin TBD
Posted: Sun May 29, 2022 5:56 pm Post subject: Re: Portable Air Conditioner Unit |
clamay wrote: |
Did I misread the advertisement? I read that it uses 210 watts of power not 850. 210 watts is consistent with 5000 btu window units that use 410 watts. This unit doesn't seem mystical or magical it is just a smaller more portable air conditioner than others I have seen. 2900 BTUs should be enough to keep the inside of a vanagon cool. And yes, $1000 is a lot to pay but I could easily spend that restoring my old vanagon system. |
A 5000 btu/hr AC won’t cool a Vanagon in motion and will be feeble rest
You would need a group 24 battery for each 30 minutes of desired operation _________________ .ssS! |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16504 Location: Brookeville, MD
82westyrabbit Samba Member
Posted: Mon May 30, 2022 4:00 pm Post subject: Re: Portable Air Conditioner Unit |
Just for a point of reference I was in Dallas the last few summers with out AC in my van. My only vehicle when I was there. I hung a 5000 btu AC unit out the driver’s side middle window and ran a generator to power it. Just like everyone says it just won’t keep the van cool driving on a hot day. Sometimes better than nothing sometimes not. It worked fine when camping. I tried bigger portable AC units and those didn’t work at all. I am back in Massachusetts now and don’t care about AC. I prefer driving with the windows (that’s just me). There is just to much heat that comes in the windshield. John |
Posted: Mon May 30, 2022 4:40 pm Post subject: Re: Portable Air Conditioner Unit |
82westyrabbit wrote: |
This is exactly why the popular front A/C mod known as the Small Car one simply struggles to do any more than the front cab.
If you’ve ever pulled a rear Evaporator coil it will quickly become obvious way it struggles.
That VW rear Evaporator coil is HUGE!!
Far bigger than most (if not all) residential window units.
That Evaporator is then paired with an equally large Condenser in front of the radiator.
Add to that the teenie tiny compressor installed in a window unit.
Ghia
Vanagon
Beetle
pushkick Samba Member
Posted: Mon May 30, 2022 8:01 pm Post subject: Re: Portable Air Conditioner Unit |
I tried a portable 8000btu unit but it couldnt keep the camper cool. I am now looking @ a 14,000btu portable unit
DeLonghi PACEX390UVcare-6AL PACEX290UVcare-6AL WH 14000 BTU Portable Air Conditioner, Dehumidifier, Fan & UV-Carelight, White https://www.amazon.com/dp/B08XGK4ZTV/ref=cm_sw_r_awdo_1HK70CHSKP1CT7F0XPV0
https://www.delonghi.com/en-us/pac-ex390uvcare-700...CARE-6ALWH
Now this thing says it pulls 11.9amps @110vac which is ok for my 2k inverter & i have 200ah worth of batteries + solar ,so while im driving load should be ok given altenator should be able handle load with ease. Battery should last around 15 hrs.
Or a roof top unit _________________ i see said the blind man to his deaf dog
i am going to quit smoking and drinking and die a healthy man. gotta laugh
there is no deed to the planet earth
1990 vw automatic camper |
jimf909 Samba Member
Posted: Mon May 30, 2022 8:55 pm Post subject: Re: Portable Air Conditioner Unit |
pushkick wrote: |
Or a roof top unit |
11.9 amps x 110VAC = 1,309 watts / 12 volts = 109 amps which means the 200ah of batteries will run the a/c unit less than 2 hours. If those are FLA running the a/c unit 1 hour will deplete their SOC to less than 50% shortening the life of your battery bank.
https://www.rvtravel.com/inverters-101-amps-and-volts/ _________________ - Jim
Abscate wrote: |
