werksberg Samba Member
Joined: February 08, 2005 Posts: 2151 Location: Prescott Valley, AZ
Posted: Mon Jun 07, 2010 7:49 pm Post subject: 1964 - ? Westy rear hatch panel with V cut out Q..? |
The same rear hatch panel fits 1964 - 1975 Buses and on '68 - '70 westy seems to have a V notch in them for a knob to open the hatch from the inside.
But what about '64 - '67 Westy Buses...did they all have the same V notch or not?
_________________ Werksberg Products....Products that work!
Follow my new products on my Facebook Werks Berg
Click the below ADs link for products & feedback.
Search "werksberg" on Photobucket for products photos & Please remember to buy "American made products!" |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Mon Jun 07, 2010 11:15 pm Post subject: |
67 also has the notch. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19672 Location: Land of Whine and Phonies
Posted: Tue Jun 08, 2010 7:38 am Post subject: |
Yep. My 65 has it. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
Posted: Tue Jun 08, 2010 7:13 pm Post subject: |
Thanks guys, it helps in nailing down the year range for my new products!
Hey Major and crofty....does that knob pull out or slides up or what to open the hatch?
I think it is a 5mm threaded knob on a shaft?
I think my billet alum dash knob with a long set screw might work for it. _________________ Werksberg Products....Products that work!
BarryL Samba Member
Joined: November 01, 2004 Posts: 14257 Location: Casa de Oro, California
Posted: Wed Jun 09, 2010 7:36 am Post subject: |
I've never seen that knob. To me it looks like it is a lock from the inside. The cam rotates down to block the u-lever from intruding? When the outside is locked you can still open the u-lever from inside. The ones with a hole in them are '66 and newer, I think. VW suggested putting a wire loop and stem into that hole on a regular hatch to open it from the inside. |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2036 Location: Philly, PA
Posted: Wed Jun 09, 2010 7:38 am Post subject: |
werksberg wrote: |
slides.
my65vert Samba Member
Joined: November 09, 2003 Posts: 6186 Location: Middleburg, Florida
Posted: Wed Jun 09, 2010 7:57 am Post subject: |
yes it is meant to be an inside lock.
that way when you are camping you do not have to lock the hatch with the key from the outside. you just close the hatch and slide that lever to block the opening mechanism, in the morning you can just slide the lever the other way and pull the latch assembly from the inside and open the hatch. _________________ OGJHC
Kombisutra;
I'm starting to get little wafts of bus stink coming from the north. Something about the unique scent of drivers seat padding when it's glued together with mouse piss and shit that really gets me going... and I'm smelling it! Oh yeah! Time to start loading up the equipment. |
Posted: Wed Jun 09, 2010 8:06 am Post subject: |
Those are baywindow locks. I don't remember seeing a split with the knob. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jun 09, 2010 9:35 am Post subject: |
Matt, does that knob unscrew at all? Or is it a fixed? I think the '70 Westy I looked at the owner said it screws in but what about the early ones?
Crofty, the early ones...what did they use to open the latch then?
Thank you to everyone that has posted. It helps to understand these old vehicles by sharing information!
JM _________________ Werksberg Products....Products that work!
Posted: Wed Jun 09, 2010 9:52 am Post subject: |
mine does not have a knob, it is just a straight pin and no it does not unscrew. _________________ OGJHC
Kombisutra;
You pull the catch with your finger. They lock, at least on a Westy, with a brass slider. _________________ Your Vanagon sucks, Stop waving at me.
Posted: Wed Jun 09, 2010 10:43 am Post subject: |
my65vert wrote: |
mine does not have a knob, it is just a straight pin and no it does not unscrew. |
What size shaft as I make the billet knobs for the radio (non threaded) and like my seat knobs...I could drill and tap for a set screw on the side. _________________ Werksberg Products....Products that work!
Posted: Wed Jun 09, 2010 11:46 am Post subject: |
Im not wanting a knob for it, I like it without it and Im nut sure it ever had one on it? _________________ OGJHC
Kombisutra;
Posted: Wed Jun 09, 2010 12:17 pm Post subject: |
I was just wonder what the shaft size was so if someone else wanted them....I could make a small run of them. _________________ Werksberg Products....Products that work!
