Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sun Jun 13, 2010 6:07 am Post subject: Heater cables to late heat exchangers |
I have a 1600 in my '56 and I want to have heat. The heater cables ends don't come anywhere near where the control flaps are on the 1600 heat exchangers. Has anyone come up with a way to do this? Thanks. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16757 Location: State College, PA
Posted: Sun Jun 13, 2010 9:25 am Post subject: |
There are cables available in different lengths - if you know what yours are and know how short they are you should be able to get it to work. But the problem that I had with the 61 was that the new cable ends (thick part) were too big to make the bends, so I had to cut them off and then splice the ends. Was a pain in the butt. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Joey Samba Member
Posted: Sun Jun 13, 2010 4:49 pm Post subject: |
I had the same problem getting the drivers side cable through the tube. Once I cut the end off it slid right through. I'll find some same size diameter wire and make my own longer cables. Thanks. _________________ Joey
Joey Samba Member
Posted: Thu Aug 12, 2010 5:35 am Post subject: |
Okay, the problem was the heat exchangers were off a bus engine. The part where the cable connects to was on top lever/hinge of the heat exchanger. I bought these and got everything hooked up. _________________ Joey
54bugn Samba Member
Joined: April 28, 2005 Posts: 493 Location: Parksville BC, Canada
Posted: Thu Aug 12, 2010 9:19 am Post subject: |
Its going down to 12 degrees tonight, you may need that heat...lol.
Good work Joey.
Cheers,
Mike _________________ "Schwing wrote:
You either have to be too cheap to hire a pro or determined to do it yourself, but it helps to be both!"
54 European Sedan deluxe
Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=414940 |
Joey Samba Member
Posted: Thu Aug 12, 2010 9:54 am Post subject: |
Don't believe what those crazy weather forecasters say... it was suppose to rain all day yesterday and it was sunny. _________________ Joey
