stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Sun Jun 13, 2010 1:55 pm Post subject: Two tone using BC/CC |
Should I spray on the first color and them put masking tape over it then spray the second color, followed by the clear coat ? or clear the first color before spraying on the second ? _________________ Steve
87 Westfalia full camper 4 speed |
66buggie Samba Member
Posted: Sun Jun 13, 2010 3:06 pm Post subject: |
shoot both colors then clear it |
spook Samba Member
Joined: December 30, 2003 Posts: 2038 Location: in the shop 35750
Posted: Mon Jun 14, 2010 3:24 am Post subject: |
pay att to your flash times,If you are an inexperienced painter
then I would recommend doing the top (of the car) color, then put one
coat of clear, let cure over night ,mask shoot lower color, demask and shoot clear on entire car _________________ www.airkooledkustoms.com
SBS US #10
feedback on the shop : http://tinyurl.com/yc7jgkl
Welcome to he darkside, its lower here. |
Posted: Mon Jun 14, 2010 7:58 am Post subject: |
Thanks for the replies. Yes, I am inexperienced, painted only four cars in my life and the last one was over ten years ago. What I have is time so waiting for the first coat to dry first is not a problem. Would wait a day before masking the first coat OK or the safe bet is to clear the first coat first ? Playing it safe may lead to less work later for an inexperience guy like me ? _________________ Steve
Posted: Mon Jun 14, 2010 9:22 pm Post subject: |
spook wrote: |
coat of clear, let cure over night ,mask shoot lower color, demask and shoot clear on entire car |
alot of extra work there ...and its very important that u scuff the clear if you leave it let dry overnite with 3m white scothbrite cuz you gotta have a bit bite for the new clear. |
Posted: Tue Jun 15, 2010 6:50 am Post subject: |
Are you talking about the 3M Scotch-Brite Light Duty Cleansing Pad ( P/N 7445 ) in white that you scuff the clear by hand ?
I am worried that if I don't clear the first color first and tape over it to spray the second color, the first color may come off when I remove the masking tape. _________________ Steve
Posted: Tue Jun 15, 2010 7:13 am Post subject: |
stevey88 wrote: |
I am worried that if I don't clear the first color first and tape over it to spray the second color, the first color may come off when I remove the masking tape. |
yea scuff by hand...u know what ...do what ur comfortable with. goodluck |
spook Samba Member
Posted: Wed Jun 16, 2010 5:23 pm Post subject: |
you can use a hardner in your bases, but you will have to
scuff if you miss your window _________________ www.airkooledkustoms.com
SBS US #10
mcem2001 Samba Member
Posted: Thu Jun 17, 2010 7:28 pm Post subject: |
If you base the first color you should be able to mask on it within an hours time, then do your second color and unmask and clear the whole car at once. You wont peel up base unless its not prepped correctly in the first place. No need to scuff anything in between coats of base if you get to it all in one day. |
beetle98 Samba Member
Joined: May 09, 2009 Posts: 110 Location: Asheville, NC
Posted: Thu Jun 17, 2010 7:37 pm Post subject: |
stevey88, I did a 2 tone bc/cc as a rookie just a couple months ago. I didnt use the best paint you can buy but it was Limco Supreme and worked very well. They told me at the paint place i only had to wait 1 hour after painting first color. That is what I did and it worked perfect had one small spot that lifted. The one thing I didnt expect was the bottom color traveled up the cracks in the doors and came out at the top a little so tape up the door crack. I was a rookie also as this was my first paint job ever. It is not perfect but not to bad either. Chad
1st color white
2nd color started after an hour
Clear Coat another hour
Far from perfect but not to bad and learned alot for next time.
diablodesigns Samba Member
Posted: Thu Jun 17, 2010 8:07 pm Post subject: |
ok paint is wha i do for a living.
Each type of paint will have a different flash (dry) time before you can tape to it. If you get your prep work done properly you dont need to worry about the paint peeling up with the tape.
Now if you are going to paint the top then clear, I would recommend using a 800 grit wet sand the following day to allow for adhesion of the next coats of clear. as in
Cover thee bottom Base the top wait aprox 30 minutes then at least 2 good coats of clear on the top next day untape 800 grit wetsand the clear (removing any imperfections) then cover the top and base the bottom, wait aprox. 30 minutes untape then clear the entire vehicle. for the smoothest results without having to buff on the next day 800grit wetsand again removing any imperfections then mix some more clear, but this time add an extra 10% of the reducer. spray a nice evn coat (this should glass over almost instantly leaving an almost perfect finish). This is called flowcoating. good luck with the paint job if you need anymore advise dont hesitate to ask Im new to the site but ive been painting for 15+ years.
feel free to call if ya need to
580-647-2719 my name is Kit |
Posted: Fri Jun 18, 2010 9:41 am Post subject: |
Kit,
[quote=" next day untape 800 grit wet sand the clear (removing any imperfections) "/quote]
You mean leave the masking tape overnight after putting two coat of clear on the first base ? _________________ Steve
Posted: Fri Jun 18, 2010 6:28 pm Post subject: |
didnt know how new you are to taping and painting. its easier to untape the next day not having to worry about the tape hitting the fresh clear and causing an imperfection in it that is harder to sand out. It wont hurt anything. |
