dgsaz Samba Member
Joined: November 04, 2008 Posts: 579 Location: Phoenix / San Diego
Posted: Mon Jun 14, 2010 10:47 am Post subject: San Diego Shops |
If you were short on time and had the $$$, who would use for a rebuild of your RGBs. Almost bone stock 66. Thanks for the recomendations.
dgsaz |
J Flare Samba Member
Joined: September 27, 2004 Posts: 309 Location: San Diego
Posted: Mon Jun 14, 2010 11:18 am Post subject: |
A guy by the name of Pat who works out of Peanuts Auto on Lake Murray Blvd. |
deepseeman Samba Member
Joined: January 13, 2004 Posts: 435 Location: san diego
Posted: Mon Jun 14, 2010 12:03 pm Post subject: |
Pat of ITS. as stated above. works out of peanuts. _________________ in the barn:
61' Double Cab-restored driver
91 SYNCRO |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2537 Location: Ocean Beach in Beautiful BLUE California
pyrOman Fire Master
Joined: July 21, 2003 Posts: 12408 Location: Over 2002 posts deleted!
Posted: Mon Jun 14, 2010 1:49 pm Post subject: |
Pat works for peanuts???
Watta deal!!! _________________ Some people are so busy being clever they don't have time enough to be wise. |
OB Bus Samba Member
tnc19 Samba Member
Joined: November 13, 2008 Posts: 246 Location: San Diego, CA
Posted: Mon Jun 14, 2010 8:51 pm Post subject: |
He definitely don't work for peanuts....but he works "OUT" of the peanuts shop...there and another shop vw/porsche down in national city.
He will work with you on what you need and within your budget. He does it the "right" way....He will give a free estimate of what it is...are you sure its your rgbs?
Anyway,....he is the man...call up 619-579-2601
tell him Jay sent you...he built my transaxle for me...for my 63 DD...
Tell him Pyro said he works for peanuts....lol! |
cbaucom1 Samba Member
Posted: Wed Jul 21, 2010 9:54 pm Post subject: |
Who would you guys recommend to have work on your bus in San Diego,
For mechanical work? I used to have Rich's in OB fix mine when I can't, but he closed shop! |
Braukuche Samba Member
Posted: Thu Jul 22, 2010 6:55 am Post subject: |
cbaucom1 wrote: |
All I hear is complaints about local shops or have personally seen shoddy work, My buddy takes his to Hans Meyer on University, I think it is called Hans Meyer Autowerkstatt, its about six blocks east of Fairmont. |
OB Bus Samba Member
Posted: Thu Jul 22, 2010 7:08 am Post subject: |
Mike's Foreign. 4347 Twain #C, San Diego, CA 619-280-8883.
Mike is great. Been repairing ACVWs for over 30 years. Extremely knowledgeable and helpful. His prices are reasonable considering the quality of work that he does. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14258 Location: Casa de Oro, California
Posted: Thu Jul 22, 2010 7:24 am Post subject: |
I've had good and bad from Mike as well as good and bad from Harloff's on University. I've had good and bad from myself. |
Posted: Thu Jul 22, 2010 4:55 pm Post subject: |
I've had nothing but good from Mike! |
Posted: Thu Jul 22, 2010 9:30 pm Post subject: |
Okay, I'll check Mike's out. Thanks for the input you guys:) |
Posted: Fri Jul 23, 2010 1:37 pm Post subject: |
BarryL wrote: |
A friend of mine had him build a 40hp and had nothing but problems with it. When he took it back they couldn't get it to run right. He ended up selling the car. Caveat emperator. |
dgsaz Samba Member
Posted: Fri Jul 23, 2010 8:11 pm Post subject: |
For the record, I ended up taking my bus to Hans Meyers for the RGB rebuild, plus a tranny re-build with a flipped ring and pinion set. I'll let you all know how the saa plays out.
I like this shop as I also can use them for the 912 and the t-5 Volvo wagon.
dgsaz |
mg6770 Samba Member
Joined: July 26, 2005 Posts: 843 Location: North Shore CamPbodia
Posted: Sat Jul 24, 2010 9:47 am Post subject: |
I always go to VW Paradise for stuff I cannot do on my own. They're a little pricey but I'm always satisfied. Plus it's only 2 miles from my house. The Lauffers can handle anything you take to them. |
OB Bus Samba Member
Posted: Sat Jul 24, 2010 10:54 am Post subject: |
Braukuche wrote: |
BarryL wrote: |
Who is "him"? Mike or Harloff? _________________ Larry in OB
Posted: Sat Jul 24, 2010 12:11 pm Post subject: |
OB Bus wrote: |
Braukuche wrote: |
BarryL wrote: |
Who is "him"? Mike or Harloff? |
Sorry for the confusion, it is Mike that built the 40hp.
I wouldn't let Paradise VW change my oil for that matter. |
dgsaz Samba Member
Posted: Mon Aug 09, 2010 12:15 pm Post subject: RGBs, Trannys and Stuffed Seats |
dgsaz wrote: |
dgsaz |
Well, I have the bus back. Things never turn out exactly like planned but the end result is positive.
What started out as a RGB rebuild worked up to a RGB rebuild, plus a tranny rebuild, new motor and tranny mounts, rotate the flywheel for better starter contact, new clutch disk and pressure plate, new brakes on the rear wheels. Wheeew!!
The ring and pinion gears were up graded one step. I don’t have the exact specs on what I had and what I have now but the end result is I roll along at 62 at the same sounds that I used to have at around 58. I have to hit the gas a bit harder on the approach to big rolling hills and on steep grades I go to 3rd gear sooner.
That said, for running north and south on the coast the extra 4-5 MPH extra is a fair trade off for the slight loss of power. The bill was under $3000 for the entire process.
Off the subject, has anyone ever had their seats re-padded? My seat covers are perfect, but the padding is not long distance comfortable and does not fit the covers very well. Any San Diego suggestions?
dgsaz |
Posted: Mon Aug 09, 2010 1:28 pm Post subject: |
Lindy's in La Mesa does great upholstery work. ask for Armondo and tell him Eddie referred you. he gives me a good deal to referrals. _________________ in the barn:
91 SYNCRO |
