BL3Manx Samba Member
Joined: August 29, 2006 Posts: 6767 Location: Northern California
Posted: Thu Apr 24, 2014 6:31 pm Post subject: Another Buggy Wiring Harness |
Someone has made some labeled wiring harnesses tailored for a standard buggy and is selling them on ebuy. He calls it, VW Dune buggy Wiring harness FINISHED! "Plug and play" . They look fairly good but an ATC fuse block would have been better.
jspbtown Samba Member
Posted: Fri Apr 25, 2014 6:12 am Post subject: |
It also seems like it is designed for a pretty stock VW system (ie: VW speedo). Might not be worth all the mods in case you wanted to run real gauges.
Still need a ground system as well. |
Posted: Fri Apr 25, 2014 6:18 am Post subject: |
The picture threw me, I said it didn't have an ATC fuse block but reading down in the description I was wrong. It has a 6 circuit ATC/ATO type fuse block.
Reading the description, it sounds to be really well done. Believe it has grounds and a Tach wire at least.
The description says You get a finished plug and play VW dune buggy harness for:High beam, low beam, front and rear turn signals, horn, rear running lights, stop lights, reverse lights, reverse lead in, lisence plate light. Ignition switch, headlight switch, dimmer switch (floor mounted), wiper switch/ motor, turn signal switch, flasher, Tach, speedometer, high beam indicator, oil pressure indicator, Turn signal indicator, coil indicator and heavy accessory lead. Also starter and alternator leads. All with respective grounds for a fiber-glass bodied vw car. Also, a modern, sealed, 6 circuit Fuse box. ATC/ATO type. All with labels. No guessing anywhere. |
Posted: Fri Apr 25, 2014 6:54 am Post subject: |
Seems awfully lean to have enough grounds. |
Posted: Fri Apr 25, 2014 9:28 pm Post subject: |
That's true but I always like to run the ground wire separate from the harness, it makes for shorter wire runs. In back I just run a wire from one of the screws on the fan shroud straight up to one light then across to the license light then to the other light, in series.
In front I run one wire from each shock towers up to each headlight and turn signal. I also run one wire from the left front shock tower through a hole in the body to the rear of the dash and the gas tank. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Sat Apr 26, 2014 7:48 am Post subject: |
BL3Manx wrote: |
YES!.... KISS.... (Keep It Simple Stupid)
Posted: Sat Apr 26, 2014 10:44 am Post subject: |
I personally like them inside the passenger compartment and have one continuous wire per item back to one central grounding area.
Its much easier to chase gremlins and they are out of the elements. |
joescoolcustoms Samba Member
Posted: Sat Apr 26, 2014 11:44 am Post subject: |
That is a nice looking harness, and having the ends already fixed saves time, expense getting them. But, wrapped up like that limits the custom options unless additional wires are run along with the harness, and what if your lights on the rear are unique and need a little bit more wire.
I build two ground spots in the system. One in the rear, and one in the front. Usually a stud welded to the chassis before painting. I do not like to run the ground from the rear to the front, (vice-versa), seems redundant when the entire chassis is a ground. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
SBD Samba Member
Joined: October 24, 2012 Posts: 3269 Location: SOUTH DAKOTA
Posted: Sun Apr 27, 2014 10:59 pm Post subject: |
joescoolcustoms wrote: |
That is a nice looking harness, and having the ends already fixed saves time, expense getting them. But, wrapped up like that limits the custom options unless additional wires are run along with the harness, and what if your lights on the rear are unique and need a little bit more wire. |
If you read the description the guy has on eBay it sounds like he will work with you to make sure the harness will fit with the lights, etc. that you're using. Even extra length if necessary. The harnesses are custom made for each application. It looks fairly basic but could be good for a buggy. Maybe not quite as complete as needed for a kit car? |
claimjumper Samba Member
Joined: May 02, 2014 Posts: 1 Location: Barrie Ontario
Posted: Fri May 02, 2014 1:15 pm Post subject: |
I need a Harness complete for my Buggy and read the other day in a search about this guy making them , but cant find him now and can't find him on E-bay.. Help? |
Posted: Fri May 02, 2014 1:20 pm Post subject: |
http://www.ebay.com/itm/VW-Dune-buggy-Wiring-harne...mp;vxp=mtr
I typed in "buggy wiring harness" _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
HillBuggy Samba Member
Joined: August 17, 2013 Posts: 55 Location: Georgetown Ca
Posted: Sat May 03, 2014 10:36 am Post subject: |
HillBuggy wrote: |
hard to beat for 160 bucks IMO |
Yes, that seems to be the market price point
A friend has ordered a plug and play one off ebay and also asked that it be set up for the turn lever mounted dimmer switch and relay instead of a floor mounted switch. Don't know what the answer was but looking forward to seeing it when he gets it. |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun May 04, 2014 6:57 am Post subject: |
No mention of which grade wire he's using? And I'd prefer crimp instead of soldered connections...
bnc _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Sun May 04, 2014 7:51 pm Post subject: |
I don't see how it would fit a personalized buggy.
The 1967 VW bug wiring diagram is so simple even a caveman could do it.
Just get some 100 ft rolls of different colored wire most of which can be 16 ga and build your own harness.
It is one way to get very intimate with your buggy build and you will learn a lot about how the wiring system works. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
BIGMIKEY Samba Member
Joined: September 24, 2007 Posts: 1105 Location: North East Pennsylvania
patc Samba Member
Joined: October 29, 2013 Posts: 5 Location: PORT ALBERNI BC CANADA
Posted: Wed May 21, 2014 12:32 pm Post subject: finished wiring harness |
i have been looking on ebay but have not found the posting of the Finished wiring harness, where on ebay can i find it, i am in the process of wiring my 1974 and have loads of diagrams but the seem to be contradictory of each other in many cases and do not show how to wire in the relays, do you run the wires to the fuse box first then on to the relay then the switches, sorry my first buggy build |
MOON BUGGY Samba Member
patc Samba Member
Posted: Wed May 21, 2014 2:12 pm Post subject: wire harness |
thank you for the link and taking the time to reply i work slowly on the buggy as i am disabled but it is a real stress release and i love it thanks again for the help |
truckdude Samba Member
Joined: May 01, 2014 Posts: 148 Location: Beverly Hills baybee
Posted: Wed May 21, 2014 9:47 pm Post subject: |
I plan to buy the long wheelbase version of this harness for $175. Has anyone on here bought one from this guy yet ?
I'm also starting to wire up a Model T touring hot rod with a flathead engine and 53 Merc overdrive trans. The trans will be one of the more complex wiring tasks, solenoids, governor, throttle switch, and a couple more things I'm trying not to think of.
Plug and play sounds good for my hopefully fast buggy resto . |
