Barn Find '57 Oval
Page: Previous  1, 2, 3 ... 44, 45, 46 ... 74, 75, 76  Next
Last Triumph
Last Triumph is offline
PostPosted: Wed Jan 19, 2011 2:02 pm    Post subject: Reply with quote
Right then - bit more progress for you...
Please forgive this rather dull and photo hungry post, it's just that often, step by step, component by component pictures of a procedure can be very helpful so here goes...
With the brakes now built up on the backing plates, it was now time to build up the rear hubs and bearings and here's how I chose to do it.
First up was to give all the original components a thorough clean, especially the bearing. This was done in a pot of brake cleaner. The rear bearings were in perfect condition with no slop, play or grittiness.
Another extremely convenient find from the NOS abyss was a pair of rear axle and hub seal kits. Splendid!
Here are all the components laid out in the order they will be fitted with the outside on the left.
First assembly part is to fit the new outer seal into the bearing carrier. It is essential that the bearing goes in to the correct depth and most importantly to prevent leaks, it must be 'square' and true in the housing. Pounding this in with a hammer is not an option, and as I didn't have access to the press in work, I had to be inventive.
A rather fortunate discovery was that the outer race of one of the front wheel bearings is the exact same size as the seal...
Which means that with careful planning, I could use this as a 'press' with my vice to insert the seal. To prevent damage to the bearing carrier, I faced it with a black of wood and using the front bearing race, carefully and slowly eased it into position. I found this a very satisfying and controlled way to do it. Make sure the seal is well oiled before you try and insert it as it's a tight fit.
This seal fits at a precise depth in the carrier and Bentley specify it must be within 4.75mm and 5.00mm of the top of the shoulder. Now - the worst thing you can ever give me is a tolerance like that, as I then spent..... lets just say, 'far too long' making sure that it was absolutely bang in the middle all the way round the seal, but not one to give up, I got it just about perfectly in the middle.... Just can't help it.
And there it is, ready for the next stage. Gotta love original blue VW seals.
And so - to the rear axle area which is bear, thoroughly clean and hungry for parts.
At this point we'll assume that every part fitted is perfectly clean and oiled when fitted. First on the shaft is the inner spacer who's curved side butts up against the machined radius on the axle.
Followed by the first paper gasket to seal the axle tube to the back of the backing plate. I coated it with Curil K2 sealant to be extra secure.
Followed by the bearing...
Then the bearing washer...
Followed by the inner O-ring seal...
Which sits in the chamfered recess on the main outer spacer...
Which allows the main brake backing plate to be offered up in to position, but is just resting in place...
Then the larger outer O ring seal fits in the space between a machined recess between the backing plate and the axle tube housing...
Which now allows it all to be held in place by bolting on the main seal and bearing housing, which also has a gasket...
Torque these four 14mm bolts up in a criss cross pattern to gently ease the inner lip of the seal over the outer spacer ring to form the main oil seal. These get torqued to 30 ft lbs.
At this point I quickly flipped the shoes downwards to fit the handbrake cable to the lever arm and secured the support bracket for the handbrake in place leaving us with a finished rear brake!
The cleaned drum went on perfectly and all is well!
The other side is just the same and is also all complete now.
Like I say, sorry for the dullness, but it might just be a help to anyone who is maybe a little intimidated about how this lot all fits together.
As long as you take your time, make sure everything is clean and oiled and goes on straight, it's really not a difficult job.
That's all for now folks!
Wiggy
Wiggy is offline
PostPosted: Wed Jan 19, 2011 2:16 pm    Post subject: Reply with quote
Pure Porn. Nice job.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
Erik G
Erik G is offline
PostPosted: Wed Jan 19, 2011 3:12 pm    Post subject: Reply with quote
I've been through leaks and such regarding the rear bearings and seals. excellent step by step photo's, it will help a great many people
MODIFIER
MODIFIER is offline
PostPosted: Wed Jan 19, 2011 4:44 pm    Post subject: Reply with quote
So your wheel cylinder is on the bottom of the backing plate?
I guess they swapped them to the top for later models.
Happyasshell
USC USMC DAD OORAH!
ASE MASTER TECH BODY/PAINT and MECHANICAL
62 Beetle
63 Vert
64 Beetle
https://www.facebook.com/SmartFarmServices
BlueJayScout
BlueJayScout is offline
PostPosted: Wed Jan 19, 2011 6:09 pm    Post subject: Reply with quote
Great work as always.
surewriting
surewriting is offline
PostPosted: Wed Jan 19, 2011 9:21 pm    Post subject: Reply with quote
Please keep it up with the photo-heavy posts! They are an extremely helpful reference tool, not to mention pure heaven to view. Excellent job, as always.
silvertonguedevil
silvertonguedevil is offline
PostPosted: Thu Jan 20, 2011 7:38 am    Post subject: Reply with quote
X2!! I will be at this step soon and this was by far the best step-by-step I've seen. Keep the photo-heavy posts coming!!
-Greg
bunkington
bunkington is offline
PostPosted: Thu Jan 20, 2011 9:17 am    Post subject: Reply with quote
Ignorant question - isn't that bearing supposed to be packed with grease?
jvulich
jvulich is offline
PostPosted: Thu Jan 20, 2011 9:20 am    Post subject: Reply with quote
On the later IRS cars yes, but on the early swing axle cars they are fed with gear oil from the transaxle through the axle tube.
Flavio
Flavio is offline
PostPosted: Thu Jan 20, 2011 10:46 am    Post subject: Reply with quote
Hello LT
Amazing and shared job. Thanks for your service to us.
One question: regarding the rear brakes and that long and retangular piece of metal where the bottom horizontal spring sits, it has a long concavity for the spring. In your case is facing down. Right ? In the right side brakes does the spring "uses" that concavity or is it reversed ?
Thanks in advance
Last Triumph
PostPosted: Thu Jan 20, 2011 12:21 pm    Post subject: Reply with quote
Flavio wrote:
Hello LT
Thanks in advance
Yes, spring sits in the concavity on both sides facing downwards, held in place with a spring clip.
On another note - the steering box seal is leaking at the top where the steering column shaft comes out so I guess you'll see a step by step early steering box rebuild soon!
Where can I get a top shaft seal from then as they are different from the '61> seals....?
Please, can we keep the proposed use of grease out of this discussion, as it ain't happenin'..... Laughing
vwrides.com
vwrides.com is offline
PostPosted: Thu Jan 20, 2011 12:26 pm    Post subject: Reply with quote
Great Stuff. Keep the photos coming.
([email protected])
FOR SALE www.VWOVAL.com domain name:
http://www.thesamba.com/vw/classifieds/detail.php?id=1602771
FOR SALE 1968 VW Resto/Parts VAN:
http://www.thesamba.com/vw/classifieds/detail.php?id=1585662
Last Triumph
PostPosted: Fri Jan 21, 2011 2:12 pm    Post subject: Reply with quote
You want photos? I got photo's for ya, so buckle up for a treat of a trip into automotive astonishment.... in the mean time, here's an update!
I noticed the other day a nice a damp patch of oil on the floor under the steering box and thought it might be a good idea to fix this before everything goes back on the car.
The Bentley manual says it is wise to bolt the steering box to a tube similar in diameter to the front beam to allow it to be worked on easily.
This sounded like a great idea, so in the absence of a tube of the correct diameter, I tried to 'think outside the box' for a moment and came up with this idea....
This next picture shows where the oil was seeping from. You'll notice a damp and shiny patch under where the steering column input shaft sticks out.
First up is to remove the top cover. I removed the 19mm drain plug. For reference, when bolted in the car and on level ground, the level should be filled to the bottom of the threads with EP90 transmission oil only.
Followed by the four 14mm bolts that hold the top cover in place.... The gasket is in perfect condition which was a nice surprise.
I was delighted with how clean and un-worn everything looked in there!
I then removed the pre load spring and pin from the main shaft....
Which leaves a nice hole at the top of the shaft...
I then released the pinch bolt that secures the adjustable input shaft and seal carrier - 17mm for the record.
To release and remove the main shaft, you must first release the pitman arm from the bottom. It won't come off due to the lower beam tube being in the way, but is released when you pull the shaft up from above. Slackening the box clamps to the top tube and rotating it on the tube would allow it to come off, but as the shaft is coming out anyway, I decided to leave the box in it's pre-aligned position.
Lifting the shaft up releases the ball jointed upper part of the worm drive which is an interesting piece of kit....
The arm just pulls out at this point.
Note the recessed section half way down it's length? This is to allow oil to surround the shaft which drains to the shaft via a hole in the lower side wall of the main reservoir. You can see this hole half way down the tube on second and third pic in this sequence...
At this point I wanted to be 100% sure of exactly where the leak was coming from, so I tilted the axle back to level the steering box and force the now low oil level up the input shaft to the seal and see what happened.
After a few turns lock to lock, it was pretty clear that the input seal was the culprit...
The seal is housed in an intermediate housing with a helically machined groove that the pinch bolt sits in. By turning this shaft with a large 27mm spanner, you actually push it in or out of the box to keep it firmly against the bearing which sits within the box.
Waggling it back and forth also helps to release it and pull it clear. These next two pictures are of it sitting on the end of the shaft as if I'd just removed it, but you'll notice that it's clean as I'd already cleaned it up to inspect it and the bearing before I'd remembered to take these two shots.
Here, you can just make out the position of the bearing at the end of the main housing.
And here it is....
The seal in the end is a very disappointing affair being a basic pressed tin cup with a felt 'bush' in to act as a seal. No wonder they are prone to leaking. I guess they didn't make lip seals that small back in the day? It is pressed into the end of the shaft and just pops out with a drift.
Having phoned all the specialists I could think of and being told that the seal is no longer available and that I should 'upgrade' to the later '61> steering box, I decided that I'd accept the challenge and find one.
A morning spent on the phone to all my old engineering contacts plus a few new ones seemed like it was going nowhere - maybe they were right - maybe you just can't get this seal any more? After a bit of a wild goose chase I eventually found a supplier who, after checking in their stores came up with the perfect sized nitrile NBR lip seal!!!
Result!!!
And yes - I bought them all!
Early steering boxes are safe now boys and girls!
As soon as they arrive in the post, I'll put it all back together and report my findings.
That is all.
Kjell Roar
Kjell Roar is offline
PostPosted: Fri Jan 21, 2011 3:16 pm    Post subject: Reply with quote
Do you have the dimension for the seal? (outer/inner/wide).
The seal is probably easy to get from specialists/industry suppliers. I have sold a lot of different seals and o-rings on my former work.
I got a historic car, every scratch got a history...
My car, Aug. 4th, 1955 / an early 56: http://www.thesamba.com/vw/forum/album_page.php?pic_id=610438
Seb67
Seb67 is offline
PostPosted: Fri Jan 21, 2011 6:09 pm    Post subject: Reply with quote
I wonder if that material is related to the stuff found in the oil bath air cleaners? Or perhaps the same felt found in Distributors? Seems like you could find the correct replacement material and re-use the metal bit. Anyhow -- this thread is chuffing brilliant!
1964 Type 1
3foldfolly
3foldfolly is offline
PostPosted: Fri Jan 21, 2011 6:18 pm    Post subject: Reply with quote
Most excellent LT. Thanks for the guided tour through vintage beetle no mans land. I need one of those seals too. Please keep us updated. Thanks
Last Triumph
PostPosted: Sat Jan 22, 2011 1:12 am    Post subject: Reply with quote
The problem with the felt seal is that it is intrinsically a poor design for this purpose - sooner or later it is going to leak.
If these new seals I've bought actually fit and work when they arrive, I'll sell the remaining items and we can go from there.
Let's see that they are suitable before we get too excited.
nick696
nick696 is offline
PostPosted: Sat Jan 22, 2011 3:26 am    Post subject: Reply with quote
Had the same problem and fixed it the same way by buying a NBR lip seal, they do the job Very Happy
3foldfolly
PostPosted: Sat Jan 22, 2011 7:57 am    Post subject: Reply with quote
Ok, I'll just simmer down and wait for the verdict. What type of seal is used to seal the bottom of the main shaft by the pitman arm?
Last Triumph
PostPosted: Sat Jan 22, 2011 10:38 am    Post subject: Reply with quote
A proper lip seal...
The bag of seals arrived and I was duly impressed with them so headed on out to the garage with success on my mind...
It was a nice but not overly tight press fit in the shaft and only needed a drift for the final stage of insertion. I used some Curil K2 engine sealant as a belt and braces approach.
18mm Socket was a perfect diameter 'press' to get it in.
There is a perfect 'shelf' for the seal to sit against a little further in than the original seal which makes sure that it is sitting square.
You can see the sealant squishing out from the rear view picture.
After giving the input shaft a good polish to help the seal do it;s job, I greased everything up and slid the adjustment sleeve into position.
I then drained the remaining fluid out of the box, remounted the top cover with sealant and added exactly 125ml as per the manual which amazingly filled it to precisely the bottom of the filler plug threads.
And there it is, all done....
Once I'd adjusted the shaft clearance I turned it lock to lock many times and waited to see what happened. two hours later and it was still bone dry...
Result Very Happy
This topic is locked: you cannot edit posts or make replies.    Forum Index -> Beetle - Oval-Window - 1953-57 All times are Mountain Standard Time/Pacific Daylight Savings Time
Page 45 of 76
