bomberbaja Samba Member
Joined: January 18, 2010 Posts: 549 Location: Tri-Cities WA
Posted: Fri Jun 25, 2010 1:24 pm Post subject: |
i have a crazy idea.....buy a convertible and make that into a baja! |
shred625 Samba Member
Joined: October 10, 2007 Posts: 1328 Location: Huntington Beach Ca
Posted: Fri Jun 25, 2010 2:01 pm Post subject: |
bomberbaja wrote: |
Oh snap!
That is of course the easiest way but vert bugs are not easy to come by and you will pay for it. _________________ “It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey |
Posted: Fri Jun 25, 2010 2:38 pm Post subject: |
does anyonw know how hard it would to turn a standerd into a 'vert? |
kbwakesk8 Samba Member
Joined: December 08, 2005 Posts: 1499 Location: Hacienda Heights CA
Posted: Sat Jun 26, 2010 9:19 am Post subject: |
When i cut the roof off mine my friends wanted me to make a removable hard top. |
Posted: Sat Jun 26, 2010 10:08 am Post subject: |
i've thought around that too. like if i could cut a big sunroof in it, and then have a piecce i could insert in, but it would have to seal up really well. |
Wheel_Works Samba Member
Joined: August 05, 2009 Posts: 347 Location: Michigan
Posted: Sat Jun 26, 2010 4:31 pm Post subject: |
bomberbaja wrote: |
The car I have already has Full Chromoly cage from front to back, Beard seats that are mounted, rear Beard bench seat mounts, king/link pin conversion, +7 beam thats welded to the cage, Wright rack, Chromoly front arms and Chromoly 2X3 on the rear, full close ratio 3 rib on a 10* mount, strong 2180. Full CNC Hanging pedal set up, Wilwoods all the around it, 6 Fox shocks, etc........
When it was caged, it was setup to take the body off. It would be easier to just cut the top off at this point. |
Posted: Mon Jun 28, 2010 10:37 am Post subject: |
Sweet if its set up to take the body off you could have two of them
bodys are easy to find
i would find a body cut the top off do all the sheet metal work and drop it on your pan that way if you dont like it you can put yours right back on |
motorbreath53 Samba Member
Joined: September 08, 2005 Posts: 901 Location: POWAY
Posted: Mon Jun 28, 2010 3:06 pm Post subject: |
kbwakesk8 wrote: |
I second this idea.
THis would also limit the down time for your car...
Course'.. I wouldn't do it at all. I've had both. Sawzall Vert', and a full body... and I like the full body way better.
Especially with a car that looks as good as yours does. (in those pics anyway) _________________ Shameless buildthread plug:
..."cut n' turn in progress"... |
Posted: Mon Jun 28, 2010 6:23 pm Post subject: |
We'll see. I'll let you guys know what I decide. I'm thinking and it hurts to much right now. |
