Aftermarket A/C condensor replacement
Page: Previous  1, 2
purplepeopleeater
purplepeopleeater is offline
PostPosted: Thu Sep 13, 2012 5:30 pm    Post subject: Reply with quote
Are you guys changing the hoses this 16x22 condenser or are they the same?
JeffRobenolt
JeffRobenolt is offline
PostPosted: Thu Sep 13, 2012 6:14 pm    Post subject: Reply with quote
Used the same on my aftermarket condenser.
Just make sure the outlet are in the same spot as the old.
Jeff
**For Sale...Modified Subaru Wiring Harnesses**
www.facebook.com/jeffrobenolt
[quote="jfats808"]Most, some, few is not all. You can always learn something from everyone , even the fool.[/quote]
purplepeopleeater
PostPosted: Thu Sep 13, 2012 7:23 pm    Post subject: Reply with quote
Looks like the ports should be on the correct spot, larger on the top and smaller on the bottom...
http://www.nostalgicairparts.com/air-conditioning/16-x-22-superflow-r-134a-condenser-741.php
JeffRobenolt
PostPosted: Thu Sep 13, 2012 8:02 pm    Post subject: Reply with quote
I'm pretty sure that is the same one I put in.
Jeff
purplepeopleeater
PostPosted: Thu Sep 13, 2012 8:04 pm    Post subject: Reply with quote
Jeff
I ordered one, its the best deal going!
plus mine looked like stone (really...it did!) road salt and corrosion has eatin it up...it didn't leak but it also didn't keep my freon cool.
cellerdoor
cellerdoor is offline
PostPosted: Tue Nov 27, 2012 4:31 am    Post subject: Reply with quote
Im in the market for a replacement condenser for my 86 westy full camper.
Currently the condenser attaches to the radiator (which Im also replacing) and will be replacing the ac hoses leading to and from the condenser.
For my situation which size from nostalgic air would be desireable? (I can wait for the proper size)
Does it attach to the van or attach back onto the radiator?
Any insight would be appreciated.
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Nov 27, 2012 6:03 am    Post subject: Reply with quote
Does it attach to the van or attach back onto the radiator?...
I (and others) went with the 16x22, mostly on the theory that bigger is better.
You may find this thread useful as the person who did my A/C work had a simple but elegant way of attaching the lower corners of the condensor:
http://www.thesamba.com/vw/forum/viewtopic.php?t=533184&postdays=0&postorder=asc&start=0
cellerdoor
PostPosted: Tue Nov 27, 2012 6:57 am    Post subject: Reply with quote
Thanks for the link Alwahnee, explained a lot.
My current condensor has the fittings on the side, but to be safe when I make up the new hoses I may add an inch or two after I measure out the distances.
Looks like you put the condenser in first, then radiator/shroud/fan second. is this hard to maneuver or is there reasonable room to do it this way?
Ahwahnee
Ahwahnee is offline
PostPosted: Tue Nov 27, 2012 1:09 pm    Post subject: Reply with quote
All I did on that job was write the check but, yep I think that was the sequence.
montanasurfer
montanasurfer is offline
PostPosted: Thu Jan 21, 2021 5:15 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Hey Folks,
It looks like the links to the recommended condenser no longer work. Also, it looks like the same condenser that GoWesty uses in their kit (https://www.gowesty.com/product/air-conditioning/24380/high-efficiency-a-c-condenser-). Sadly they are out of stock. Does anyone have any recommendations for condensers that are currently available?
1987 Vanagon GL - Wolfsburg Edition
MarkWard
MarkWard is offline
PostPosted: Thu Jan 21, 2021 5:21 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Aircarsupply on eBay. 16 x 22 dual pass. Donít have the item number handy. $65 shipped.
1982 Vanagon Camper with ALH TDI.
In Car https://youtu.be/5hbfdUJR88Q
djkeev Premium Member
djkeev is offline
PostPosted: Thu Jan 21, 2021 5:31 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
montanasurfer wrote:
Hey Folks,
I just ordered one from nostalgic air last week.
I have it here in my hands.
Dave
Ghia
Vanagon
Beetle
MarkWard
MarkWard is offline
PostPosted: Thu Jan 21, 2021 5:38 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
montanasurfer
PostPosted: Thu Jan 21, 2021 6:06 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Hey Folks,
Dave
This is the one? https://nostalgicac.com/16-x-22-superflow-r-134a-condenser.html
If so, has anyone confirmed that Redtek works with this one?
djkeev is offline
PostPosted: Thu Jan 21, 2021 6:41 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Hey Folks,
Dave
I have used this unit with redtek, as have many others.....
It should be noted that NostalgicAir's website is hit or miss right now, best to call to order.
Dave
Ghia
Vanagon
Beetle
calfredson
calfredson is offline
PostPosted: Sun May 16, 2021 12:02 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Does anyone know where to get the 16x22 condenser in Canada? Shipping from Nostalgic Air is more expensive than the part itself, and I'm striking out on ebay.
Howesight
Howesight is offline
PostPosted: Sun May 16, 2021 12:59 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Try this one:
https://www.ebay.ca/itm/184130682614?hash=item2adf0b3ef6:g:EkwAAOSwTm1eIJ-Z
'86 Syncro Westy SVX
calfredson
PostPosted: Sun May 16, 2021 9:44 pm    Post subject: Re: Aftermarket A/C condensor replacement Reply with quote
Wouldn't 26" be too wide? Or does that not matter?
Page: Previous  1, 2
Page 2 of 2
