ARPM Case - Head Bolts Torque ?
risk
risk is offline
PostPosted: Thu Jun 24, 2010 1:06 pm    Post subject: ARPM Case - Head Bolts Torque ? Reply with quote
I have a late ARPM two piece Aluminum case, 10mm chromoly studs with no case inserts..
Anyone know what a good torque value is to run the heads down at?
I know the stock recommendation for 10mm studs in a mag case with case savers is 23 ft lbs... any ideas?
