syncroserge Samba Member
Joined: November 26, 2005 Posts: 553 Location: Okotos, Alberta, Canada
Posted: Sun Jun 27, 2010 4:46 pm Post subject: |
dbeierl wrote: |
That silly thing was designed to fail... |
Couldn't put it more simply ! A friend is thinking of fixing his with heim
joints, mostly for the fun of over doing it ! |
dbeierl Samba Member
Joined: April 22, 2009 Posts: 164 Location: Providence, Rhode Island, USA
Posted: Sun Jun 27, 2010 5:01 pm Post subject: |
syncroserge wrote: |
The roof felt a little harder to push up. Not that much though. And the inner
part of the joint looked out of center with the outer part but again nothing
dramatic. That was on the bad side. |
Be grateful. Mine pushed one end of the roof fitting up through the Fiberglas a full year before I realized what was going on, and it wasn't the offset you folks have been talking about that clued me in, it was the way the bars lay at a different angle when stowed.
Mine was much worse, though -- it was working on the inside of the far wall of the tube!
Yours,
David |
randywebb Samba Member
Posted: Sun Jun 27, 2010 5:05 pm Post subject: |
BTW - VW says to lube the hinges at the rear, but says nothing about maint. on these things.
This IS an opportunity for an aftermarket fab. operation.... _________________ 1986 2.1L Westy 2wd Auto Trans. |
Posted: Sun Jun 27, 2010 6:55 pm Post subject: |
randywebb wrote: |
This IS an opportunity for an aftermarket fab. operation.... |
That's what my wife said but knowing her manual habilities I'd say
it's up to you |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9810 Location: Mt Lemmon, AZ
Posted: Tue Jun 29, 2010 1:08 pm Post subject: Fix that Poptop push bar ! -- The Repair |
My push bar had worn to the point where it was slotted half way thru (photos in a prior post, this thread). I now have the repair done:
Ace hardware has some steel bushings that fit snugly in the ends of the push bar:
These were welded in and the slot that had worn in the bar welded up & ground down:
On the inner hub a pair of bearings for each side were fashioned from slices of iron pipe that had an i.d. of 13/16". These were welded on each side of that skinny hub that was cutting thru the push bar like a saw:
Those bushings give a lot of width to the bearing surface and will also allow lube to stay in place.
Haven't assembled yet beyond a trial fit but everything clears and moves well -- looks like a 100-year fix to me.
BTW -- Wish I could claim full credit here but it was Samba member Serge who was the inspiration and a local friend with welding skills who made it possible. |
Posted: Wed Jun 30, 2010 3:41 pm Post subject: |
The previous described mods to the pop top 'knee-joint' have solved my lifting woes completely. With the corrected joints (and Mark's gas shock kit) the top goes up & down with almost no effort.
One problem with this wear point (apart from the fact that there is no way to lube it w/o disassembly) is that there is also no way to look at it. The inner hub of the knee joint can be cutting thru the pushbar and you may never suspect a problem until it is pretty far gone.
That said, looking at before and after photos of the area show there was a clear indication of the problem.
Before: The hub has cut halfway thru the push bar allowing the inner portion of the joint to project forward of the outer portion:
After: A correct fit with no inner damage will have the inner portion of the joint concealed w/i the outer portion.
Hopefully this will let some (esp anyone who thinks their pop top is getting harder to raise & lower) do a quick check to see if the hinge alignment indicates internal wear. |
rocket j squirrel Samba Member
Posted: Sat Jun 04, 2011 7:11 am Post subject: |
Awansee -- your Before and After photos have gone missing. Can you re-post them? |
Posted: Sat Jun 04, 2011 7:58 am Post subject: |
rocket j squirrel wrote: |
Can't edit an old post so here is a redux:
Ahwahnee wrote: |
...That said, looking at before and after photos of the area show there was a clear indication of the problem.
offroad. Samba Member
Joined: January 01, 2009 Posts: 211 Location: llanelli, s wales
Posted: Sat Jun 04, 2011 12:08 pm Post subject: |
i welded mine up and turned them back down to standard |
Noganav T3 Samba Member
Joined: August 11, 2010 Posts: 101 Location: California
Posted: Sat Jun 04, 2011 2:56 pm Post subject: |
Great thread, thanks for posting, I have a pop top that I recently purchased and the left side was acting really weird. I thought it just needed lube but I could see the hub was sticking well past the edge of the plate and trying to figure out what was wrong. Now I know what is going on and will pull it down and make the repair. |
Mike Robinson Samba Member
Joined: June 18, 2010 Posts: 386 Location: Nanaimo BC Canada
Posted: Sun Feb 05, 2012 7:19 pm Post subject: |
I took apart my push bar today as I suspected mine would be as worn as the original poster - and it was.
So I have a couple of thoughts. I can find a welder to fill the wear and grind it back to 'round' or I thought I could swap the bar around so the wear would be on the other side of the bar, and fill the worn side with JB Weld.
The JB Weld would be easier and less spendy - do you think it would work ie improve the strength/integrity some/enough.
Mike
'82 Westy |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2723 Location: Eastern Idaho
Posted: Sun Feb 05, 2012 7:52 pm Post subject: |
Looks like a "normal" wear issue to me. |
My van sure had it pretty bad, the only way you could tell was if you looked carefully the 2 parts of the knee joint did not rotate concentrically when you raised the top, well that and the top was pretty hard to lift, but I had never been in a westy besides mine back then so I wasn't sure how easy it was supposed to be.
Vanagon Nut wrote: |
Just a guess, but would 1/2" copper pipe fit?
I guess the Jackbombay lift assist struts would also help the wear issue by
relieving most of the pressure on the affected area. |
1/2" PEX (plastic watter supply line) fits pretty well inside the cross bar. I hammered a piece in each end of mine, and since the pop-top shocks take a notable amount of weight off the crossbar the PEX should last very long, PEX is some really tough stuff.
Ahwahnee's solution is certainly the best way to fix it and never have to touch it again. I imagine that these tops were notably easier to lift when these vans were new and this issue contributes more than a bit to a "heavy top". _________________
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies
Samba ad here.
DIY artificial rain gutters (ARGs) |
rubbachicken Samba Member
Posted: Mon Feb 06, 2012 5:02 am Post subject: |
Ahwahnee wrote: |
Wellsir, I took my push bar apart and indeed it looks quite similar to the one shown in Serge's post:
I see no point in sourcing a used one (unless I can see that the bar is not worn) as I suspect most, if not all, are to one degree or another showing a similar wear pattern.
Thinking at the moment is to fit a short length of steel rod or pipe into the end of the tube, tack weld it in place, then weld up the worn groove. Then I'll dress it down to the correct shape. Should be good for another 20 years. |
this is how i would fix it, make the end of the bar solid, it'll never wear out _________________ lucy our westy
lucy's BIG adventure
meet 'burni'
619 201 0310 or 617 935 4182 |
dixoncj Samba Member
Joined: June 17, 2004 Posts: 1083 Location: Charleston, SC
Posted: Mon Feb 06, 2012 6:32 am Post subject: |
So for a van that doesn't yet have this wear would it work to take a can of white lithium with the little red tube on the sprayer and try to get the grease way down in there w/o disassembly? |
Posted: Mon Feb 06, 2012 8:32 am Post subject: |
dixoncj wrote: |
That would certainly help, hit it with grease before each road trip and it would probably never need to be taken apart and fixed. _________________
Samba ad here.
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Mon Feb 06, 2012 10:37 am Post subject: |
Glad to see this revived. I forgot all about this wear point. Something to look at on ours. JB weld has a lots of uses, but does not have the abrasion resistance of steel. In other words, you can sand it, so probably not the best solution unless you can add a bushing to the other half to spread the wear load. Bad design.
Question, I had my top off to replace the canvas. I don't recall, Is this thing going to jump apart like a wind up clock or is it pretty tame to work with? _________________ ☮️ |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Mon Feb 06, 2012 10:45 am Post subject: |
jackbombay wrote: |
dixoncj wrote: |
That would certainly help, hit it with grease before each road trip and it would probably never need to be taken apart and fixed. |
Good advice. Another job to add to the regular maintenance. _________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Mon Feb 06, 2012 2:40 pm Post subject: |
Spring loaded BEWARE!!
I would not recommend trying to take it off with the roof in a down position as the springs are in the loaded position. I though because of the weight of the roof that the springs were insignificant - nope - lots of force.
Put the roof up. Hold the roof up with a pole and undo the bar system - it is still a bit of a PITA, but safely unloaded (mostly).
Hopefully getting my grooves welded up this weekend. Then getting the Bombay lift help.
Mike |
Posted: Mon Feb 06, 2012 3:31 pm Post subject: |
Just what I needed to know. Thanks. _________________ ☮️ |
