Fix that Poptop push bar!
Wasted youth
Wasted youth is offline
PostPosted: Mon Apr 29, 2019 7:28 am    Post subject: Re: Fix that Poptop push bar! Reply with quote
Evil or Very Mad This thread is riddled with dead photo links~ making an otherwise useful source of information a stumbling, inefficient affair...
Please remember to upload your photos to the Samba Photo Gallery!
Arrow Photobucket won't host your photos unless you keep the membership active, same with ImageShack. Google+ closed their service, etc.
This is how we do it: https://www.thesamba.com/vw/forum/viewtopic.php?t=6
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
Paulbeard
Paulbeard is offline
PostPosted: Mon Apr 29, 2019 7:18 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
+1000
It's not that hard to do and it makes your work writing this stuff, as well as doing the work you're sharing, worth it. Fercryinoutloud, I have done it from my phone…
Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
Git 'r DONE!
— dhaavers
jimf909 Premium Member
jimf909 is offline
PostPosted: Mon Apr 29, 2019 8:19 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
Paulbeard wrote:
+1000
I'm guessing I've uploaded 98% of my 470 photos on my phone. It's easy.
Current: 1990 Westy Camper - Bostig RG4, 2wd, manual trans w/Peloquin, NAHT high-top, Flash Silver, seam rust, bondo, etc., etc.
westyventures
westyventures is offline
PostPosted: Sun Jun 02, 2019 6:15 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
A friend was here with new canvas to install today, until I realized how badly the linkage was worn. Not having time or quick access to bushings, I welded up the grooves worn into the tube and ground it down, then filed the tube back to the original surface. On reassembly we used red sticky grease. The plate that causes the wear is harder than the tube, so no real wear in that, the above process worked out fine. Should last at least as well as the original, since the weld is slightly harder.
Karl Mullendore
MoreTorque starter adaptors
www.westyventures.com
michaelasnider
michaelasnider is offline
PostPosted: Tue Nov 12, 2019 12:55 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
Is it possible to remove the cross bar without pulling the whole mechanism out? Obviously as long as the top is supported in the raised position separately.
westyventures
PostPosted: Tue Nov 12, 2019 1:09 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
Why? It's far easier to prop the top up and remove the mechanism. Four bolts each side.
Karl Mullendore
michaelasnider
PostPosted: Tue Nov 12, 2019 1:26 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
Because one bolt each side and no toothed clip on the pins on the bottom would be easier, and I could take it out in the van with the propex running.
koubiak
koubiak is offline
PostPosted: Sun Nov 24, 2019 12:51 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
Super useful thread (apart from broken pictures. Protip go on page 4 and 5 there are valid one)
I don't have access to a welder so I am planning to do the everyman solution and epoxy the crack with an inside sleeve support.
One question I cant figure out is : Can I close the poptop without the mechanism in place. Meaning After releasing the pushbar from the lifter mechanism with the top up and supported with 4x2s. Can I safely close the poptop again? So if the repair takes longer I don't have to worry.
THanks
Koubiak
vanis13
vanis13 is offline
PostPosted: Sun Nov 24, 2019 1:48 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
yes you can , and it will seem heavy
I can send you the capacitor to Fix/prevent Vanagon Syndrome and/or smooth out idle - See here - http://www.thesamba.com/vw/forum/viewtopic.php?p=5445671#5445671
westyventures
PostPosted: Sun Nov 24, 2019 2:03 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
THanks
Koubiak
I'd advise against epoxy unless you like doing things twice. Surely there must be a welder who can fill in the groove?
If you close the top w/o the lift mechanism in place, I'd recommend having another person there to assist, a strong one!
Karl Mullendore
kguarnotta Premium Member
kguarnotta is offline
PostPosted: Sun Nov 24, 2019 2:17 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
I just got a new syncro, well new to me - that has had a pop-top installed on it. It is a bit of a bear to open and close - this thread is helpful - and think shows what some of the problem is.
Thanks to all who posted info and especially the pics - so I can understand it. Hopefully I get a dry day or two - so I can work on this.
If I understand correctly - I can open the top top, prop it up with a 2x4, then remove the bar mechanism for repair. I can close the top manually, and latch - so I can drive around while waiting/searching for a welder to fix this. It will be a real bear to open again afterward, but it is possible. Then when I have the repaired bar - I just need to get someone to help lift the top while I re-install. I am also assuming you don't lift the top all the way when you do this work.
Do I have all that right?
-Kevin
Jamaica Plain, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper
syncroserge
syncroserge is offline
PostPosted: Sun Nov 24, 2019 4:53 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
Yup..that's the basic idea..but..
If you are thinking of driving the van without the bar I would recommend:
undo the bar from the brackets but leave the brackets attached to the van, then Magiver some bungy setup from bracket to bracket.
I have noticed that in high wind the bar does provide additional clamping to the center pin.
I have added some quick connect straps I position on the bars near the brackets especially when carrying the kayaks on top.
Not at home now but I will add the worth-a-thousand-word pic later.
newt3
newt3 is offline
PostPosted: Tue Nov 26, 2019 7:08 am    Post subject: Re: Fix that Poptop push bar! Reply with quote
you can buy a baering solution in germany:
https://www.werk-4.com/vw-t3-westfalia/
https://www.werk-4.com/referenzen/
here some installations:
http://gruenerbulli.de/aufstelldachmechanik/
https://www.willithebus.de/neue-aufstellmechanik-dach/
i also found an installation video (on youtube ore somewhere) but i didn't have the link already.
don'd know if its also possible with this bearings. perhaps someone tries:
https://www.google.com/search?q=flanschlager&source=lnms&tbm=isch
perhaps with a 3 dimensions ball bearing:
https://encrypted-tbn0.gstatic.com/images?q=tbn:AN...oxcr&s
availiable with 2 oder 4 srew holes
https://www.igus.com/info/spherical-bearings-flange-bearing-efsm-ca
i you translate gruenerbullis text you will find out that he does not only have the new bearings. he also got negativ(?) gas springs in the tubes for easier opening/liftung process! (installed by werk4)
i asked him but he doesn have pictures of that and doesn't know whats really inside. you have to ask at werk4 for this special solution, is guess it won't be cheap (and it does have the power of external rear gas springs) but maybe it's worth (original look. it's hidden ins the tubes)
i guess those (negativ) springs here:
https://www.google.com/search?q=gaszugfeder&source=lnms&tbm=isch
koubiak
koubiak is offline
PostPosted: Tue Nov 26, 2019 8:30 am    Post subject: Re: Fix that Poptop push bar! Reply with quote
Fantastic!
Is this a drop in bearing system https://www.werk-4.com/vw-t3-westfalia/umr%C3%BCstkit-auf-lagerb%C3%B6cke/#cc-m-product-10189924952 ?
I have not try to read the full thing yet but i am unsure if the bearing fits with the original cross bar but.
newt3
newt3 is offline
PostPosted: Tue Nov 26, 2019 12:01 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
here the installation video https://www.youtube.com/watch?v=-Ixv1z-faks&feature=youtu.be
in the bottom of the product site
you find the installation instruction in german an in english as pdf-file:
https://www.werk-4.com/app/download/10529936952/Assembly_Instructions.pdf?t=1519109443
koubiak
koubiak is offline
PostPosted: Tue Nov 26, 2019 7:08 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
I just watch the video. This is great (I understand german). Interesting how he shows how to do with the roof down which seems very manageable.
I guess I should get a dremel type tool to be sure I can grind the excess as soon as my bus come out of the shop I will start this project.
Vielen Dank
PostPosted: Mon Dec 09, 2019 6:00 am    Post subject: Re: Fix that Poptop push bar! Reply with quote
for those watching the video who don't know german, there is an option in youtube to turn on close captioning, and translate.
It isn't a perfect translation - far from it - but it helps.
-Kevin
Jamaica Plain, MA
'78 Westy
'69 Single Cab
Sodo
Sodo is offline
PostPosted: Mon Dec 09, 2019 2:00 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
That bearing kit is a neat idea, but is it noticeably easier to operate than a greased H-bar pivot? Maybe they simply go dry after 30 years and is asking for grease?
Or maybe I don't understand the problem. Does the bearing kit restore a worn out (due to dry) pivot?
OK I looked at the instructions (the english download) and yes the hole wears out, most likely due to lack of grease.
I'd better go inspect (and grease?) mine....
Or more....
The poptop won't be "a bear" to open for this step of the repair process.
Unless you have lots of heavy stuff ontop.
The spring mechanism assists normal opening, but the top is still just a fiberglas shell that two people can easily carry around, flip over etc.
You might consider purchasing the jackbombay gas strut kit, which is a super-nice upgrade anyway. AND pre-installing would make your H-bar project a little easier as it would hold the top up tight against the canvas. https://poptopshocks.blogspot.com
Verify that your poptop latch engages "positively".
Most do.
It's very rare that I hear of the latch releasing on the highway, and I bet its almost 100% operator error. Or maybe a malfunctioning latch. But they are reliable and you can feel it click in with "positive" engagement.
EJ25, Peloquin diff, locker, transaxle oil cooler/filtration system
....KTMs, GasGas, and a Stumpjumper
One apple every 8 hours will keep 3 doctors away - B Kliban
PostPosted: Mon Dec 09, 2019 2:43 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
My pop-top has had the strut assist installed. It was not originally a pop-top. I just got it a few weeks ago - and the top was kind of a bear to deal with. I was going to take those assists off - as it is super hard to close. But after reading this thread, and looking at the hinge point - I think the issue is the pull up/push up bar looks as though it may be almost sheared through - in any case it is in bad shape.
So I figure I'll try to fix the pushup bar, then decide if I need the assists. I think the PO had the lift assists as he probably carried a lot of stuff on his roof. At this point, I don't think I'll be doing that, so I think those struts (along with bad hinges) make it super difficult to close and kind of difficult to open.
So this repair is on my list...it is a long list, that keeps growing Wink
-Kevin
Jamaica Plain, MA
'78 Westy
'69 Single Cab
Sodo
Sodo is offline
PostPosted: Mon Dec 09, 2019 3:24 pm    Post subject: Re: Fix that Poptop push bar! Reply with quote
There are several levels of "assist" struts.
You must have the "HD units".
Not sure how that would make it difficult to open, unless you mean you have to hold it back to prevent it from jumping open?
Maybe someone wants to trade normal struts for your HD units?
I hear ya on "the growing list".
Page 6 of 8
