GreggK Samba Member
Joined: May 17, 2008 Posts: 897 Location: Colorado/Philidelphia
Posted: Sun Oct 11, 2020 7:01 pm Post subject: Re: Fix that Poptop push bar! |
So far I'm going the clevis pin route for the mounting brackets. I reused the bigger "stop" pin and found the correct new retaining ring. I went to https://www.mcmaster.com/
They have just about everything. There is an huge selection of pins but no the exact ones like the originals. Go browse that site but be careful, you'll find things you never thought you could buy. _________________ '86 2wd Poptop transplant
FAS TDi engine swap. Peloquin LSD
https://www.thesamba.com/vw/forum/viewtopic.php?t=692188&highlight=slow+but+steady
GreggK Samba Member
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Thu Oct 15, 2020 3:49 am Post subject: Re: Fix that Poptop push bar! |
Looks nice - did you end up getting them powdercoated? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
deadaheadub Samba Member
Joined: April 18, 2004 Posts: 787 Location: New Mexico
Posted: Sat Jan 30, 2021 6:44 pm Post subject: Re: Fix that Poptop push bar! |
I need to figure out a repair on my own. Sooner rather than later, methinks.
_________________ Grateful daily,
Ryan
______________________________________
Past loves: '65 Bug, '70 Westy poptop, '64 Squareback project, '76 Westy tintop "Loose Lucy", '76 Westy tintop "Sharee"
Current:'84 Westy poptop "Ramblin' Rose- Rosie" w/ 2003 Subaru EJ25 conversion |
Posted: Wed Jul 07, 2021 1:15 pm Post subject: Re: Fix that Poptop push bar! |
For those of you with experience disassembling this: does it make a difference as the repair progresses, if I remove the bar and mechanism by first popping the top completely and bracing it up with a 2x4 or whether instead I zip tie the two bars compressed together under full tension with the poptop in the closed position? thanks _________________ Grateful daily,
Ryan
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10369 Location: Sunshine Coast B.C.
Posted: Wed Jul 07, 2021 1:23 pm Post subject: Re: Fix that Poptop push bar! |
Assuming the cable at each side (each set of arms) still functions.....
Top down, arms strapped then removed, you need a way to safely release those straps.
1988 West DIY 50º ABA
VE7TBN |
Posted: Wed Jul 07, 2021 1:41 pm Post subject: Re: Fix that Poptop push bar! |
Vanagon Nut wrote: |
Neil. |
Yeah, so it would be easier to have the tension released before removal, since, if I need to get access to the wear points in the knee joints (not just the groove wearing through the push bar), that requires them be un-tensioned? Right?
thanks, Neil _________________ Grateful daily,
Ryan
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Wed Jul 07, 2021 3:29 pm Post subject: Re: Fix that Poptop push bar! |
When I did mine I reckoned it was far easier to remove it with the top open. You need the tension removed anyway to get it all apart, plus you can get at all the screws very easily. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Wed Jul 07, 2021 6:07 pm Post subject: Re: Fix that Poptop push bar! |
deadaheadub wrote: |
Yeah, so it would be easier to have the tension released before removal, |
Yes.
I braced a landscaping tie between metal latch part on pop top and floor at solid wood apron of rear bench seat. IIRC, the tie was a little short and required a 2x4 shim at bottom.
It occurred to me later that an "I" or maybe inverted "V" 2x4 brace could be placed between luggage rack and pop top. i.e. something that would spread out the pressure exerted on the luggage rack. Were I to do that job again, I might use a brace at both areas.
There might be a better way to brace the pop top open.
Whatever method you choose, be certain that it's stable. The top is heavier than it looks.
VE7TBN |
Posted: Wed Jul 28, 2021 11:01 am Post subject: Re: Fix that Poptop push bar! |
If I only want to remove the push bar without taking the whole assembly apart and off the van, is that possible to just unscrew the nuts and bolts attaching the bar to the assembly at both ends? Thanks
Ryan
Posted: Wed Jul 28, 2021 11:25 am Post subject: Re: Fix that Poptop push bar! |
I don't think so-
I believe you will find that the groove cut into your cross/push up bar is so deep, that it will prevent you from pulling the bar out - without a lot of wiggling jiggling and hammering (based on your photo). At least that is what was required of mine. _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Wed Jul 28, 2021 12:58 pm Post subject: Re: Fix that Poptop push bar! |
It is possible with forethought, 2 supports and 4 clamps, to center the upper and lower rods. It will be faster and safer to remove the entire assembly though.
Fully! raise and support the top. Remove the 4 pivot pins and it will fall off onto your head. If you do decide to remove the brackets, highly recommended, install 4 rivnuts so you do not need to remove the spice rack and trim again to gain access to the 4 loose nuts. Also a good time to install rivnuts for the upper bunk hinges as well as at least 1 or 2 are most likely stripped out. _________________ Schau in das Buch |
pnwkayaker Samba Member
Joined: April 01, 2008 Posts: 919 Location: Sammamish, WA
Posted: Wed Jul 28, 2021 1:06 pm Post subject: Re: Fix that Poptop push bar! |
I completely agree with this comment. I'm in the process of fixing this poptop issue and found that, even after removing the whole assembly, I was not able to push/pull one of the 2 ends out (the other went out immediately).
It took me almost 30 minutes of pulling/wiggling/cursing to remove the end of the bar from the mechanism (the grove was stuck in the cross-metal bracket due to the cut).
kguarnotta wrote: |
I don't think so-
I believe you will find that the groove cut into your cross/push up bar is so deep, that it will prevent you from pulling the bar out - without a lot of wiggling jiggling and hammering (based on your photo). At least that is what was required of mine. |
_________________ 87 Syncro Westy EJ25 ("Tardis")
Seattle Meetup at Marymoor (link)
A collection of Simple Useful Mods (SUM) (link) |
Posted: Wed Jul 28, 2021 1:07 pm Post subject: Re: Fix that Poptop push bar! |
Thanks, Kevin.
dgbeatty wrote: |
Fully! raise and support the top. Remove the 4 pivot pins and it will fall off onto your head. If you do decide to remove the brackets, highly recommended, install 4 rivnuts so you do not need to remove the spice rack and trim again to gain access to the 4 loose nuts. Also a good time to install rivnuts for the upper bunk hinges as well as at least 1 or 2 are most likely stripped out. |
Dgbeatty- sorry but what is a rivnut? I'm an idiot in some things. A nut that acts like a rivet? Thanks _________________ Grateful daily,
Ryan
Posted: Wed Jul 28, 2021 1:28 pm Post subject: Re: Fix that Poptop push bar! |
Rivnut is short for rivet nut - essentially a threaded insert that's installed in a similar manner to a rivet (needs a different tool though). There're multiple sizes to choose from.
https://en.wikipedia.org/wiki/Rivet_nut
There're multiple methods to install a rivnut, although I'm a firm believer of using the tool made specifically for it (a search in Youtube for "Installing rivnuts" shows you a sample of all the different methods).
https://www.youtube.com/results?search_query=installing+rivnuts
I've used rivnuts to install the truck mirrors and the ABS door panels in my Syncro, they're amazing; Dgbeatty comment just gave me a couple more targets. I believe they're easy to install, very strong and give lots of flexibility (to install/remove/customize any installation). _________________ 87 Syncro Westy EJ25 ("Tardis")
Posted: Wed Jul 28, 2021 1:47 pm Post subject: Re: Fix that Poptop push bar! |
Thank you!
pnwkayaker wrote: |
I've used rivnuts to install the truck mirrors and the ABS door panels in my Syncro, they're amazing; Dgbeatty comment just gave me a couple more targets. I believe they're easy to install, very strong and give lots of flexibility (to install/remove/customize any installation). |
Ryan
Posted: Fri Jul 30, 2021 2:36 pm Post subject: Re: Fix that Poptop push bar! |
Ok, update to the problem.
I was raising the top to start to remove the whole assembly when part way up, there was a *snap* and the bar was cut all the way through on the driver's side, so the cross bar doesn't go through the side mechanism any longer. (see top photo).
What's the best way to proceed now? Still try to remove the entire assembly, or do I now have a new problem that complicates this?
And is there a way to have something welded on to the end that sheared off to make the cross bar still functional? thanks
left side
right side
Ryan
Posted: Fri Jul 30, 2021 5:54 pm Post subject: Re: Fix that Poptop push bar! |
I wouldn't try to keep pushing the roof up at this point.
1 - use zip ties (or similar) around both arms so that when you remove it the cable will not try to expand. I'd also try to lock both arms together around the pivoting point so that things don't get out of wack
2 - remove the bottom arm from the bracket (leave the bracket in place, just remove the locking washer not he side of the tent)
3 - remove the top brackets from the roof
4 - I believe it's possible to fix it - see the post by kguarnotta in the previous page of this thread (don't know how to link directly to posts),
Good luck! _________________ 87 Syncro Westy EJ25 ("Tardis")
Posted: Fri Jul 30, 2021 6:21 pm Post subject: Re: Fix that Poptop push bar! |
pnwkayaker wrote: |
Thank you for your advice. I appreciate it as I'm new to the vanagon beast, lots to learn.
I did push the top up further at the time, not all the way, and it didn't seem to do anything bad, and it did go back down looking appropriately normal when I got it locked back down. What are you guessing would happen if I was to push it all the way up and brace it, to try to remove it all completely? Is something going to get out of whack with the wire pulley? _________________ Grateful daily,
Ryan
Posted: Fri Jul 30, 2021 8:05 pm Post subject: Re: Fix that Poptop push bar! |
Since you said that you were able to raise the roof with no problem, I think that if you get people to help pushing up on the roof while you're raising it up and immediately brace it, it would work.
As you raise the roof, you're actually reducing the tension in the wire (since it's fully extended). If you're able to fully raise it and brace it, then there shouldn't be a problem removing the assembly at that time.
I wouldn't' try to just pushing on the bar to raise it since most likely the other end is in a very similar situation - you might risk it to breaking in a similar manner and the roof to fall down (that's why I think you need one or 2 more people to help you push on the roof).
Have your brace ready before you start raising the roof, I used a piece of wood of aprx 42 inches long situated in the center (you can use 2 braces if you want to be double safe).
And it you want to be triple safe, get different braces lengths all the way to 42 (like 20, 30, 42 inches) so you can put intermediate braces as you raise it. _________________ 87 Syncro Westy EJ25 ("Tardis")
