60 Single Cab Build-Pics
Page: Previous  1, 2, 3 ... , 24, 25, 26  Next
TinCanFab
TinCanFab is offline
PostPosted: Fri Dec 11, 2015 1:47 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
I took a break from breathing gas fumes so I could breathe some paint fumes. The rest of the engine bolt ons got sprayed as well as my "new" used steering wheel. It's in fantastic shape for being unrestored. Thanks Campingbox
Check out my truck brought back from the dead... http://www.thesamba.com/vw/forum/viewtopic.php?t=420762&highlight=sprayed+blood
They're never really ever finished 58 rag build...
http://www.thesamba.com/vw/forum/viewtopic.php?t=658092
VeeDubWolf
VeeDubWolf is offline
PostPosted: Fri Dec 11, 2015 3:07 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Dang, looks like new now! Cool
Two Bugs-
'70 rust-bucket sunroof sedan
'69 PO hack-job special
-Plus a wide assortment of various parts'n'junk
TinCanFab
PostPosted: Sat Dec 12, 2015 11:57 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
TinCanFab
PostPosted: Tue Dec 15, 2015 2:51 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
I've got the engine installed now and my wiring harness fits pretty good behind the engine.
TinCanFab
PostPosted: Tue Dec 15, 2015 3:00 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Oil lines are ready to go. The gold fittings are quick disconnects. I made sure to offset the hose lengths so the in and outs can't be mixed up. Wether you are taking the engine out, removing the filter or just need to get the hoses out of the way they are handy. As soon as you unhook them, the flow is stopped and keeps from drizzling oil everywhere and keeps less air out of the system.
VeeDubWolf
PostPosted: Tue Dec 15, 2015 8:19 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
That's a nice practical and professional-looking setup! Cool
Two Bugs-
TinCanFab
PostPosted: Wed Dec 16, 2015 6:34 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Thanks! I had the hose and some of the fittings kicking around for a while from other projects I didn't finish. Years ago I saw the quick connect fittings for race cars and wondered why you don't see them on more of our full flow setups. Well, it's because they are pricey!! Buy when you look real close at the design you have to admit they are nice and shouldn't expect them to be $4 a piece.
TinCanFab
PostPosted: Sat Dec 19, 2015 11:03 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Here's my manifolds after paint. I made up some paint from a chip sample that was somewhat close to the gray of the carb bodies.
TinCanFab
PostPosted: Thu Dec 24, 2015 7:24 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Here's my "temporary" exhaust. 1 1/2" EMPI header, single quiet pack, CB high flow heater boxes and copper gaskets at all connections. I used the passenger side mudflap bracket to support the muffler with a rubber exhaust hanger-instead of the one on top of the muffler that is gauranteed to tear off later. I also fully welded the seams of the muffler that are only spot welded. I had to chop the 90 degree bend after the collector to clear my tow hitch, it's a very tight fit. Also, an oxygen sensor bung has been welded in. The only position it would fit is at the bottom. Normally, this is NOT a good idea as water can puddle into your sensor and ruin it over time. I only plan on leaving a wide band and sensor in place during tuning. I'm not interested in having gauges and extra wiring in the cab anyway. Wide bands can be sensitive to voltage spikes so disconnecting it when not in use will help prevent damage.
It's hard to tell, but a lot has been done to the exhaust. Re clocked and angled at the collector and also the tailpipe itself. The header has been converted to bolt on flanges at the heater box connections.
One day id like to either copy my design to a stainless system, or if I decide to turbo it, make a system from scratch.
TinCanFab
PostPosted: Thu Dec 31, 2015 7:50 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Almost ready for cam/lifter break in....
VeeDubWolf
PostPosted: Fri Jan 01, 2016 5:57 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Interesting belt tensioner, it's coming along nice!
Two Bugs-
1967250s
1967250s is offline
PostPosted: Sun Jan 03, 2016 12:10 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Video!??
'72 Elm Green Deluxe
TinCanFab
PostPosted: Mon Jan 04, 2016 11:32 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
I just realized I have no videos in my thread at all.... So I think I will post one up
brettsvw
brettsvw is offline
PostPosted: Mon Jan 04, 2016 7:49 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
All I can say is that your singlecab is lucky to have found you.
You have put your heart and soul into your ride. Very nice job.
My 59 kombi build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=635003&highlight=
My buggy build.
http://www.thesamba.com/vw/forum/viewtopic.php?t=558601&highlight=
http://www.thesamba.com/vw/forum/viewtopic.php?t=289807
TinCanFab
PostPosted: Wed Jan 06, 2016 1:35 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
https://youtu.be/QK7tHMmy2ko
Here's the second time I had the engine running. Oil has been changed but there's still a bunch of little things to do before driving. I need to check the valves again now that the cam and lifters have settled in. Timing is set pretty conservative ATM and running 91 octane. Carbs look to be in sync at 5.5 or soo on the snail gauge and I haven't set idle speed or mixtures. I'm pretty happy considering...... Without the turbo, I can hear the steel pushrods and straight cut cam gears a lot more. I think it sounds pretty good for a single quiet pack. I can't wait to switch it to EFI but it does pretty well with the MSD distributor with grey springs. It's idling at about 5 degrees and advances to about 28 at higher RPM. Timing is rock steady and is light years of an upgrade over the 009 that was in the 40 horse.
Thanks for the support guys, I've been pretty motivated- everything done on this page has been on two crutches except for lifting the engine.
Lingwendil
Location: Oakley, behind enemy lines in communist California
Lingwendil is offline
PostPosted: Sun Apr 10, 2016 9:39 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Awesome build!
Glad to see you building it up to be used as a truck, like it was made for!
Very clean install of EFI!
is that a purple serpentine setup you have? do you remember where you got it? i need one!
73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087!
TinCanFab
PostPosted: Mon Apr 11, 2016 5:51 pm    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
Lingwendil wrote:
Awesome build!
Lol! Many people have been asking about my "purple" pulleys! They used to be black and have very rapidly started fading in the last year or two. Most of my engine work was done at night and/or fluorescent lights and my color blindness did not pick up on it...... Wink it's a older kit from BMD
Tomorrow I button up the last of my mechanical upgrades and get to drive it for the first time with 2.0 power. Cool
After a season of shakedowns, I'll finish the EFI swap, but for now it's been 2 years since my 40hp crank broke and I can't wait anymore!
Like they say, "when one door closes, another opens". Thank you broken crank for the opportunity to make my truck a more enjoyable driver.
Rokseth
Rokseth is offline
PostPosted: Sun Apr 17, 2016 11:56 pm    Post subject: Reply with quote
roachdub58 wrote:
Seat warmers I robbed out of a 90's infinity
Love your build, and wondering about one thing. Did you install those seatwarmers? Very Happy
TinCanFab
PostPosted: Sun May 01, 2016 11:02 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
I wanted to but I got a little paranoid about them catching on fire with the hair seat pads. Laughing
I didn't want to be the guy to do the experiment, because I've only seen the heaters used with foam
karl h
karl h is offline
PostPosted: Fri May 06, 2016 3:49 am    Post subject: Re: 60 Single Cab Build-Pics Reply with quote
awesome thread!
61 panel: http://www.thesamba.com/vw/forum/viewtopic.php?t=465022
68 ghia vert
arctic alice (63 on irs): http://cal-look.no/lounge/index.php/topic,27456.0.html
86 Caravelle
Page 25 of 26
