joescoolcustoms Samba Member
Posted: Mon Jan 30, 2012 11:02 pm Post subject: |
Been awhile, but I have gotten some things done on this '69 white baja.
I have done a lot of East Coast rust repair underneath to this body. The front lower pan head, rear cross member, rear rocker caps, rear package trey and re constructed the heat tubes that come from the heat exchangers into the interior. All PITA work that I do not enjoy.
So, now back to the actual build.
I pulled the front beam off the body to perform a classic 1/4 inch "cut-and-turn" to raise it up a little.
Next step is to clean the beam tubes and mark a straight line for reference to how much turn is put in the beam.
NOTE: I am doing this with the torsions and trailing arms attached to save time. I have already installed new ball joints, bearings, brakes and wheel cylinders, then decided to perform the cut and turn. This can be difficult because the beam torsions do have some pre-load on them and can make getting it back correctly difficult.
Next it is helpful to mark the place you intend to cut the beam. I use painters tape as a guide.
Then take a deep breath and cut the beam. If you do this without taking the beam apart, be careful not to cut deep into the beam tube and cut into the torsion leaves inside. I used a sawzall. Note that because the torsion leaves are pre loaded, the tube turned backwards as you can see from the lines that do not line up.
Now comes the challanging part, getting it back, straight and welded. I use a 3 foot pipe wrench to help me get it where I need it. A 3 foot wrench is not needed, but it does make it easier for me to twist, measure, line up the cut piece and weld by myself, all at once. A helper is nice for this.
So, the tube has to be turned at least back to the starting point and then an additional 1/4 inch and welded. You can now see the turn I put in the beam. I used the radiator clamp on one side straddled over the cut to get the tubes lined up while I am twisting with the pipe wrench, measuring and spot welding.
Next, just finish weld the cut and you are ready to go to the next tube.
The 1/4 inch turn is not set in stone. Some turn 3/8 inch, some 3/16 inch. But once you do it, it is done. Excluding pulling the beam from the car, the top tube took me about 45 minutes to cut, turn and weld back. This can be done on a Saturday with ease and get about 1 1/2 inch increase in height. Which allows for taller tires. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Tue Jan 31, 2012 9:52 pm Post subject: |
Process completed this evening for the lower tube. The reference marks show the 1/4 inch turn on both tubes.
thext94 Samba Member
Joined: April 11, 2010 Posts: 1003 Location: Manhattan Beach, CA
Posted: Tue Jan 31, 2012 11:00 pm Post subject: |
Great write up, makes it easy to understand. Do you grind down the weld after to keep it flush? |
Posted: Tue Jan 31, 2012 11:09 pm Post subject: |
thext94 wrote: |
Thanks. I wrote it like that so in the future when someone asks what is a cut and turn, I can reference them to this.
I will grind it a little just to dress it up. The area that is welded does not touch the pan, so the weld does not have to be smooth. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
pafree Samba Member
Joined: August 16, 2005 Posts: 2298 Location: dayton, the one in texas
Posted: Wed Feb 01, 2012 6:57 am Post subject: |
i like the pipe wrench technique. getting the spindles back on after turning is a PITA. when you turn with the center piece does it stayed lined up pretty good with the rest of the beam? seems like the pressure would move the center down out of alingment.
did you remove the center grub bolt/nut before the process? i would not think you would but just not see it on the pictures. |
Posted: Wed Feb 01, 2012 7:41 am Post subject: |
Getting the spindles back on is a PITA after a cut and turn, that is one of the reasons I left them on. The other two reasons for leaving it together is I had not done it before and wanted to see if I could and the last reason is I am lazy.
Once cut, the tube stayed lined up fairly well just hanging there with no pressure. Lining it back up while twisting it does require a little finesse. Depending on how I used the pipe wrench, force applied wise, it would be close or way off. So how you pull/push on the pipe wrench makes a hugh difference. I added a radiator hose clamp on one side straddeling the cut and that made all the difference to get it lined up. I tacked one side, then removed the radiator clamp and tacked the other.
Did not need to remove the center hub grub nut/screw. Since the beam is together, the only thing it does is to center the leaves in the beam side-to-side. It is not under pressure. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
pafree Samba Member
Posted: Wed Feb 01, 2012 8:08 am Post subject: |
joescoolcustoms wrote: |
[ I added a radiator hose clamp on one side straddeling the cut and that made all the difference to get it lined up. I tacked one side, then removed the radiator clamp and tacked the other.
do you think if a person put a piece of angle iron on the beam with a couple of hose clamps on the center section and then turned the center section and angle with the wrench then it would stayed lined up better?
example from my cut and turn but i did not have the spindles on and used clamps to hold then angle iron:
Posted: Wed Feb 01, 2012 8:25 am Post subject: |
That is another good way pafree. I have used the angle technique before too.
It should also be noted to only cut one tube and weld it at a time. If both tubes are cut at the same time, it can be very difficult to line everything back up to keep the suspension beam straight. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Wed Feb 22, 2012 8:08 pm Post subject: |
I finished off the front beam and it is ready to go back on. I welded the bumper on a litle better than the PO had done.
Before it goes back on, I will change out the Master Cylinder for a new TRW unit. That is the only old brake system part left. Now the complete brake system is new.
It is painted with rattle can Truck Bed Liner. Should last a little better than just paint.
I have set a goal date of March 17, 2012 to have this baja driving. That is the next get together of my VW club. I would like to drive it to the dinner. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
24HOURSOFNEVADA Samba Member
Posted: Thu Feb 23, 2012 12:42 am Post subject: |
You can add me to the list of naysayers about building a baja out of an oval... Until I saw the amount of rust that you're dealing with. I have no doubt that would have ended up at the scrapper.
Awesome build with great period details. It's going to be "New, old school." the NOS Baja! |
Posted: Thu Feb 23, 2012 1:18 am Post subject: |
There are varied reactions to building a baja out of a Oval. Even with the fact that this body I started with was just days away from being cut up, I still get nasty PM's from people that cannot agree with the route I took with it. I am OK with it because once I am long gone, this body could still be returned back to a full body car in near stock condition, but not without me saving it from the sawsaw and scrap yard first.
Most every one I know in the VW community knows that I am building this '56 baja. One lady in our club has a beautiful, original paint '56 that is still 36 horse and 6 volt. The only thing changed is the tranny was updated to a tunnel type. We were at a show last summer in Columbus Ohio and she was having problems with the engine and had not driven it in 2 years (turned out to be dropping a valve). She was getting depressed about it. I have been know to hoard parts and VW's, and buy them on a whim. So I told her that if she was to ever decide to sell that oval, I would interested in it because it is so nice. Then I told her it would save me a lot of time in making a baja because I would not have to do any rust repair or paint.
She kicked me in the shin. And she knew I was joking. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Fri Feb 24, 2012 9:23 pm Post subject: |
I meant it as a sincere compliment. You're a very talented fabricator and I'm really enjoying the build. |
EMPIImp69 Samba Member
Joined: April 17, 2006 Posts: 3374 Location: Dirty Jersey
Posted: Sat Feb 25, 2012 7:39 am Post subject: |
Joe, I'm just seeing your thread now and finished reading thru it. Awesome work! _________________ 1963 Ragtop Bug |
Posted: Sat Feb 25, 2012 2:15 pm Post subject: |
Thanks for the props guys!
Just wish I was faster at it. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Posted: Mon Mar 05, 2012 9:20 pm Post subject: |
Got it back to roller status! It has been close to a year since it has been on jack stands.
Also put the engine in it for the first time. If memory serves correctly, it has not had a engine in it since Spring '10. The air cleaner hits the rear valance, so I will modify it to lower it down about 2 inches.
The engine in it is short lived though, it has to come back out. Something is not right with the tranny. Sucks. Just put in new tranny oil. I was trying to avoid building a tranny, but just may have to happen.
Anyway, now I can get a good feel for how it will set with some weight on the rear. I will pull the torsions and re-index them for a little more height. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Mar 06, 2012 10:29 am Post subject: |
Anyway, now I can get a good feel for how it will set with some weight on the rear. I will pull the torsions and re-index them for a little more height. |
Looks good, but that aint an oval |
Posted: Tue Mar 06, 2012 11:13 am Post subject: |
Very observant Grasshopper.
It is in silent wait with a dust camouflage.
Dave24 Samba Hack Purist
Joined: April 14, 2004 Posts: 7442 Location: Hablamos Ingles, So. Cal.
Posted: Tue Mar 06, 2012 12:18 pm Post subject: |
Just wish I was faster at it. |
lookin' good. Fast or right?, I'll take right everytime. |
Posted: Tue Mar 06, 2012 11:32 pm Post subject: |
Wow!
Working too much and not focusing on what I am doing on the White Baja.
The tranny was not bad. It was a severe brain fart.
As soon as I stuck the engine in, I thought to put it in a gear so it would not free roll in the garage (haven't hooked up the E-brake yet). So in a gear it went and then I gave a little push to see the engine hold the baja back. It just free rolled. I tried ever gear, pulled the inspection cover off over the shift rod coupler to make sure, worked on the clutch cable adjustment, adjusted the peddles (needed that anyway) and nothing made the tranny work.
So, no big deal, just pull it apart and rebuild it. The engine was only in with 4 bolts, no wires, no fuel line, no accel cable, no rear cage/bumper. So I pulled the engine out this evening. Manually put the tranny in gear, rolled the baja just a little and no input shaft movement. Grabbed my input crank and slipped it on the input shaft and gave it a whirl. Nothing.
So I looked at the CV flanges while I spun the input shaft with my crank. They were spinning, but the baja did not roll.
Then it hit me, I had not yet installed the axles and CV's.
I think I will drink a beer and go to bed now. _________________ Bad News Racing 2018 NORRA 1000 3rd in Class
dirtkeeper Samba Member
Joined: February 19, 2008 Posts: 3200 Location: Left of everywhere
Posted: Wed Mar 07, 2012 8:26 am Post subject: |
I think I will drink a beer and go to bed now. |
Good solution |
