cbcarch Samba Member
Joined: November 03, 2006 Posts: 224 Location: St. Louis, MO
Posted: Tue Jul 06, 2010 8:24 pm Post subject: Stainless steel heater hoses |
Anyone installed the "german stainless steel heater hoses" ?
I got tired of fighting the stock paper/aluminum type and ordered
the SS ones. I even tried the orange "aircraft" type with the coiled copper wire inside--major hassles trying to install these down under the apron tin to the heater boxes. I've seen these on ac Porsches and even Lycoming boxer helicopter engines. ( Now THERE'S one heck of a flat 4!!! 5,000 cc!!)
I digress...........
Of course I don't have the stock fittings under the apron to the heater boxes. ( I rarely see anyone who actually has this put together correctly).
So the hoses go thru the flat apron down to the heater box inlet. ( shows this on the Samba Classified ad for SS hoses ). Bought 2, as it says.
Setup is Type 1 2110 in my '69 Westy with dual ceramic coated
exhaust and heater boxes.
Just wanted to know if anyone has experience good or bad?
cheers _________________ '69 Westy Camper
'59 Beetle
'64 Ghia
'70 Ghia
Street legal rail buggy
'70 Beetle Cabriolet
2014 Porsche Boxster S |
hagermanfolley Samba Member
Joined: August 03, 2005 Posts: 235 Location: Boise, ID
Posted: Tue Jul 06, 2010 8:51 pm Post subject: |
Take some pics I would love to see this when your done, also where did you get them, might order some for my '70 _________________ 1970 Westy |
volksterii Samba Member
Joined: December 01, 2006 Posts: 425 Location: San Diego CA
Posted: Wed Jul 07, 2010 6:06 am Post subject: |
I have done this. Here are a pics of them installed. I like these very much as they do not deteriorate at all. No more crushed hose.
_________________ 71 Westy Hardtop, 1915
2005 Touareg V8 air susp. |
static Samba Member
Joined: March 22, 2002 Posts: 1830 Location: The High Desert
Posted: Wed Jul 07, 2010 7:10 am Post subject: |
volksterii wrote: |
No more crushed hose. |
Are they more stout? At least, sturdier than the foil ones? |
Posted: Wed Jul 07, 2010 7:36 am Post subject: |
static wrote: |
volksterii wrote: |
They are much more stout. It would take a significant effort to dent them. _________________ 71 Westy Hardtop, 1915
ned Samba Member
Joined: June 28, 2004 Posts: 1574 Location: Arroyo Grande Ca.
Posted: Wed Jul 07, 2010 7:37 am Post subject: |
You can get those mentioned fittings made. I have a pair from A 1. It is the only way any of those hoses will really fit on so that they can be removed and reinstalled. |
Posted: Wed Jul 07, 2010 7:41 am Post subject: |
I actually did mine in two pieces each side so that removal was not hard. I used the stock coupler as you can see in my top pic (earlier post) on the left side. _________________ 71 Westy Hardtop, 1915
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4532 Location: Arizona Highways
Posted: Wed Jul 07, 2010 7:53 am Post subject: |
you should use a cut-off wheel to cut it.
if that tells you anything _________________ 71 Ghia A/S - 88 Van A/T - 13 JSW TDI 6M/T |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16926 Location: San Diego, California
Posted: Wed Jul 07, 2010 7:55 am Post subject: |
I put them on this engine
I like them and would use them again _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
pb24ss Samba Member
Joined: June 30, 2005 Posts: 1665 Location: sitting around the fire with the bluegrass band - colorado
Posted: Wed Jul 07, 2010 7:58 am Post subject: |
I replaced my tubes with some extra hot air tubing I had left over from my Airtronic install. It's available for cheap from Espar. I got mine through thermo king. They are still a metalic wrapped paper like product, but they are very very sturdy and were an excellent replacement choice. I suspect they will hold up nicely for years to come. The diameter was a perfect fit. |
Posted: Wed Jul 07, 2010 8:04 am Post subject: |
pb24ss wrote: |
I went to the Thermo King site but couldn't find the hoses. Can you supply a direct link please? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
pb24ss Samba Member
Posted: Wed Jul 07, 2010 9:20 am Post subject: |
aeromech wrote: |
pb24ss wrote: |
I went to the Thermo King site but couldn't find the hoses. Can you supply a direct link please? |
It's Espar part number 10 2114 31 00 00 (60mm), 10 2114 34 00 00 (75mm), or 10 2114 31 00 00 (90mm).
http://www.espar.com/tech_manuals/AIRTRONIC%202-4/Airtronic.pdf |
Posted: Wed Jul 07, 2010 7:18 pm Post subject: |
Thanks for the replies.
I ordered mine from VW Parts Unlimited thru the Samba ad
and I'll report back when installed and post some pics.
'59 Beetle
'64 Ghia
'70 Ghia
Posted: Tue Jul 13, 2010 7:16 pm Post subject: |
Here's some pics ( sorry a bit blurry )--just installed them.
Took about 1/2 hour--a bit tricky on the heater box ends,
started there, made some pre-bends, trial/error fit--went well.
I'd go for these on any other similar engine.
cheers
'59 Beetle
'64 Ghia
'70 Ghia
chabanais Samba Member
Joined: January 01, 2007 Posts: 16803 Location: sticksville, ct.
Posted: Fri Mar 20, 2015 2:16 pm Post subject: |
I have been using them for a few years now. I will never go back to the cheese dog paper/foil ones on my personal cars.
you need to buy 2 if using them with a header, and trim to fit _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Fri Mar 20, 2015 2:21 pm Post subject: |
Cool I think I'll get them.
I am sporting the stock heater boxes but have a Vintage Speed exhaust you think I need two of those puppies?
Was fitting them to the heater boxes rather fiddly? _________________ "I spud therefore I yam." |
