dan macmillan Samba Member
Joined: October 19, 2003 Posts: 3110 Location: Northern Ontario, Canada
Posted: Fri Jul 09, 2010 2:29 pm Post subject: 68 rear popouts |
68 rear popouts: is there anything that holds the alum channel {that is on the glass} to the "hinge post"? Mine has the rubber seal that goes from top to bottom, When I removed the popouts there was a caramel colored plastic like powder in the post channel. There is a groove in the aluminum window edge, 3 slots in the rubber seal and the threaded portion of a screw in these slots, pointing to the rear of the car. Were there some kind of clips in there? _________________ Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone |
Ghiaddict Samba Member
Joined: November 20, 2002 Posts: 2632 Location: Now in Honea Path, SC
Posted: Fri Jul 09, 2010 3:20 pm Post subject: |
The powder is what remains of the quarter window hinges.
They are plastic/nylon, 3 per side.
_________________ ****************************
Karmann Ghia & Beetle parts available.
Convertible tops installed. |
Posted: Fri Jul 09, 2010 3:31 pm Post subject: |
thanks _________________ Licensed Automotive Service Technician
Current projects:
