Correct idle jets on 32pdsit carbs on 67 westy?
Saggs
Saggs is offline
PostPosted: Sun Jul 11, 2010 5:53 pm    Post subject: Correct idle jets on 32pdsit carbs on 67 westy? Reply with quote
I converted a set of 32 PDSIT carbs to fit the single port heads on my 67 westy motor.
Question is: one carb has an idle jet stamped .50, the other one has a jet stamped .950. They look pretty darn similar as far as orifice and passageways. I found another jet marked .945 off a pict 30. I removed the .50 and am now using the .950 and .945 and the motor seems to carburate alot cleaner but I may need to go leaner? I also have moved the accelerator pump adjustment to the middle hole ( one hole leaner).
Any help or insight? Thx PS, I am running a rebuilt 019 distributer
"One man can make a difference...Jesus did."
trainwreck
trainwreck is offline
PostPosted: Sun Jul 11, 2010 6:19 pm    Post subject: Reply with quote
.50 is what I had on one pair of 32 pdsits, .45 on another. Believe .50 is correct. Youre gonna have to do some calculations compensating for the modifications I'd think
Single minded to my detriment
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sun Jul 11, 2010 7:06 pm    Post subject: Reply with quote
Here is what the 1600 carbs were jeted at originally.
Note that the left and the right carbs are not jetted the same.
Gary: OK. Ima poop.
notchboy
notchboy is offline
PostPosted: Sun Jul 11, 2010 8:27 pm    Post subject: Reply with quote
Show me a pic of a jet stamped .9?? what ever. Please.
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
Russ Wolfe
PostPosted: Sun Jul 11, 2010 10:25 pm    Post subject: Reply with quote
You have O jets that are supposed to flow fuel one direction, and X jets that are supposed to flow fuel the other direction.
Gary: OK. Ima poop.
Saggs
Saggs is offline
PostPosted: Mon Jul 12, 2010 3:10 pm    Post subject: Reply with quote
After I took these pics maybe the 9 I was seeing was really a "G" ? The .960 or G60 I believe has the smaller of the three side holes.
PostPosted: Mon Jul 12, 2010 6:10 pm    Post subject: Re: Correct idle jets on 32pdsit carbs on 67 westy? Reply with quote
A bit off the topic of your question but can you post what you did to install them on your Bus engine? Linkage used, air cleaners used, and any other modifications needed.
Saggs
Saggs is offline
PostPosted: Mon Jul 12, 2010 6:13 pm    Post subject: Reply with quote
Anything for you Everett Wink Ya, I'll get some detailed pics and an explanation of what I did. Any idea about what size or type of jets I'm looking at here?
PostPosted: Mon Jul 12, 2010 6:23 pm    Post subject: Reply with quote
I would duplicate the jets used in the page Russ Wolfe posted above.
That was my plan if I wanted to try the Type 3 dual carbs. on my Bus 1500cc engine... using the 1500cc Type 3 specs.
PostPosted: Mon Jul 12, 2010 6:26 pm    Post subject: Reply with quote
Those are "G"s.
I wouldn't count on looking at the size of the holes in the pic. For the carb. on my '63 Bus I had to go through about 10 parts carbs, to find an idle jet that wasn't either worn or drilled out. I picked one that looked undamaged.
The one on the left looks jacked up to me? It looks worn around the hole. The one of the right looks nice.
I can't proclaim to know that my selection method makes sense but it made sense to me and the carb. idled nicer and I could set the idle speed correctly (really low) & idle mixture afterward.
Saggs
Saggs is offline
PostPosted: Tue Jul 13, 2010 1:35 am    Post subject: Reply with quote
I agree that the one on the left is different. Do you think the holes are supposed to be bigger or has it worn over time? Would Russ be the man to set me up w/ some good jets?
Russ Wolfe
PostPosted: Tue Jul 13, 2010 8:17 am    Post subject: Reply with quote
Keifernet would be the one to see about the jets. Those are the same in a bug carb.
I sent him almost all of my bug cores, and I would not want to rob any of my good T-3 carbs.
Most T-3 carbs, those were electric cut off jets.
Gary: OK. Ima poop.
PostPosted: Tue Jul 13, 2010 10:03 am    Post subject: Reply with quote
I would be interested to hear keifernet's opinion on the holes.
I have never asked him about that.
Snoop Bob
Snoop Bob is offline
PostPosted: Tue Jul 13, 2010 4:24 pm    Post subject: Reply with quote
In reference to Everett's off topic mention...This is Shane6's dual Vanguard carb set up on his 62 vert. I can not remember if this used dual 28's or not.
BarryL wrote:
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Wed Jul 14, 2010 7:26 am    Post subject: Reply with quote
Those are "G"s.
My observation on these jets is:
Yes it's a "g" not a 9 before what ever size is stamped. For the most part only original Solex jets have the "g" on them.
The older original 45 and 50 and some 55 jets I have inspected have the larger "two holes" in the sides.
The newer jets seem to have changed to 4 smaller holes but I am not sure when. Perhaps in the early 70's. I am not sure why the change... perhaps it flows or mixes the fuel better from idle through the low end progression/transition is my best guess. Although I can't say I can tell that much difference.
I agree with Ev that you have to carefully examine these jets to see if the tiny hole in the tip has been drilled or the jet butchered up in some manner. I see it a lot.
As stated these carbs came with electric idle solenoid cut offs but over time they may have been replaced with the plain ol idle pilots when the electric ones "failed" or if converted from 6 to 12V.
I prefer to get rid of the electric ones and just run plain brass jets.
The electric solenoids also had a tendency to "waller out" the threaded hole in the carb bodies when they vibrated loose and it's quite common to find them fit very loose and sloppy which required tightening them into the carb body and created another malady. The overtightened jet syndrome makes the carb(s) not want to idle or tune properly unless the pilot jet is backed out a bit and loctite used on the threads to keep it in the position it allows the carb to run best.
( I now have the proper insert set up to repair this and am now able to save carb bodies that might otherwise be trashed.)
I agree the original poster should source two of the same jets. I'd run the 50's and see and depending on elevation or engine condition it might like the leaner 45's. He just needs to experiment.
