CJ-ski Samba Member
Posted: Sun Jul 11, 2010 7:06 pm Post subject: Upgrade 1970 VW Beetle Fuse Box |
I am new to this site. I would like to upgrade the standard fuse box to a Blade Style Fuse block. The trick is I may have to jumper some of the connectors to mimick the standard fuse box. I am thinking about a 12 circuit fuse block for future wiring runs (like gauges). Do you know of any instructions / diagrams; any suggestions would be appreciated. Thanks |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Sun Jul 11, 2010 7:18 pm Post subject: |
I did this many years ago on my '74 Thing.
I'm not sure if it will work for you, but here it is:
Good luck, Mondshine |
CJ-ski Samba Member
Posted: Fri Jul 16, 2010 8:36 pm Post subject: Upgrade 1970 VW Fuse Box |
Thanx for the reply. I also found additional links for another aftermarket wiring harness and 12 circuit fuse box |
gcan Samba Member
Posted: Sat Jul 17, 2010 5:07 am Post subject: |
can you post what you found...I'm interested in a upgrade as well _________________ 73 vert |
CJ-ski Samba Member
Posted: Thu Jul 29, 2010 8:16 pm Post subject: |
gcan wrote: |
can you post what you found...I'm interested in a upgrade as well |
Sorry for the late reply. I searched the SAMBA and found tons of information throughout. If you have the money ($350) and want a pretty cool rewiring of your Beetle, check out this site http://www.watsons-streetworks.com./vw.beetle.wiring.html For a cheaper alternative I have used Summit racing 10 fuse kits but had to use jumpers to make it work. Does not look professional but at least it has the blade style fuses. |
wompninja Samba Member
Joined: July 06, 2008 Posts: 2147 Location: Salt Lake City
Posted: Fri Jul 30, 2010 11:59 am Post subject: |
I've got the Watson's kit and it is well worth the 350. It took a bit of work but I never have electrical issues and I can add on things without fear of melting the stock wiring. |
chbix Samba Member
Posted: Mon Mar 14, 2011 11:04 pm Post subject: |
I know the topic is old but im wanting to do this on a 65 bug that I just acquired.
Basically do a whole new wire harness with an upgraded fuse box to support some accessories and modernize the design.
Wompninja do you have any pics of your install? The kit seems pretty complete short of a few relays perhaps, did you need anything else to install? Was it difficult? |
fmartin_gila Samba Member
Joined: January 25, 2008 Posts: 397 Location: Globe, Az.
Posted: Tue Mar 15, 2011 7:45 am Post subject: |
I just did the Fuse panel upgrade mentioned at the start of this thread in my Thing. The ATO blade type fuses do make a very positive electrical and mechanical connection which seems to be much better than the standard VW setup.
Fred |
73vwtype1 Samba Member
Posted: Wed Nov 07, 2012 2:27 pm Post subject: |
Okay so I wanna do the blade fuse upgrade on my 73 bug. I noticed that on the stock fuse box there are three pins on a few fuses how would I wire that to a new blade fuse box? I tried to do it and wired the two together and the third to the other side of the fuse it wouldn't work. Any ideas or sites that have schematics to do this upgrade? Thank you for your time! |
lil DUC Samba Member
Posted: Tue Feb 04, 2014 10:44 am Post subject: Blade fuse box upgrade |
ok so i am new to the VW bug world and i just got a 73 beetle type 1. i am wanting to do the upgrade to a blade type fuse box, but i cannot find 8 and 16 amp blade fuses. am i going to burn stuff up if i go up to 10 and 20 amp fuses or is there something else i must do to do this upgrade. thanks in advance for any help. |
GArBa Samba Member
Joined: January 27, 2014 Posts: 2105 Location: Milano, Italy
Posted: Wed Feb 05, 2014 2:51 am Post subject: |
personally, I would not do that (you can still buy OG or equivalent fuse boxes and hundreds of bosch type fuses on the cheap; I just carry a dozen in my glove box for peace of mind). That said, blade fuses don't come in 8 or 16A. Using higher rating fuses you won't fry anything as long as your electrics are fine, but you will lose protection in case of any electrical fault. _________________ cars:
'97 type 1 1600i
'14 type AA Seat Mii (sadly dead after 270.000 km)
'22 type C1 T-Cross
'23 type AC3 Hyundai I10 (VW no longer makes small cars!)
moped:
'82 Benelli Magnum 3v |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15987 Location: North Florida, USA
Posted: Wed Feb 05, 2014 6:51 am Post subject: |
ATC/ATO fuses do come in 7.5A and 15A sizes. These should work nicely as replacements for 8A and 16A GBC fuses.
VW never pushed their circuits right to the edge. Typically you would see the 8A circuits only supporting 5A or less of actual current draw. There are a few exceptions in both directions.... for example, a 16A fuse to supply the 10W (0.8A) dome light?! Who came up with that one! (I know its a spare circuit, it was just amusing) _________________ AshMan40
Hyperspace Samba Member
Joined: January 03, 2013 Posts: 1166 Location: South Africa
texson Samba Member
Joined: June 13, 2009 Posts: 180 Location: Nacogdoches, Tx
Posted: Wed Feb 05, 2014 9:54 am Post subject: |
I did that to my 71 cause the PO had made a real mess by cutting and splicing making many of the paths hard to follow. Did the best I could and everything works now. But it is a time consuming task. A word of advise... jack the front end up as high as you can. It will save your back.
[/url] |
Posted: Wed Feb 05, 2014 5:14 pm Post subject: |
Thanks for all the input guys. I haven't decided what I want to do yet but I do want to make some upgrades to the electrical system. I'm an aircraft electrician and I wasn't sure if the components in my bug were as sensitive to changes as some of the circuits I'm use to working with.
Texson, that looks nice. Mine looks much like your before pic and it's driving me crazy! |
70vwsnork Samba Member
