Bullet turn signal location?
rustfree1967bug
rustfree1967bug is offline
PostPosted: Tue Jul 13, 2010 9:57 pm    Post subject: Bullet turn signal location? Reply with quote
I bought a '70 ghia and the po had the turn signal holes welded closed because he was going to use pre-'69 round style turn signals. I am just wondering exactly where they should be located. I will be using euro style bumpers if that makes a difference. Thanks
'70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
IDA's...well... they talk dirty -MURZI
NOVA Airhead
NOVA Airhead is offline
PostPosted: Wed Jul 14, 2010 7:09 am    Post subject: Reply with quote
I did the conversion on my '71. If you can still see where the originals were I aligned my signals in the same location as where the old opening is directly under the center of the headlights.
This seemed to look best and was the easiest for me.
Be careful as to which bullets you use. As I recall they changed slightliy over the years. The late sixties version will fit best.
Ghia Owner Emeritus
rustfree1967bug
PostPosted: Wed Jul 14, 2010 3:44 pm    Post subject: Reply with quote
Well I kinda want to know exactly how far down from the headlights they should be a should they be centered with the headlight or?
'70 ghia
'69 ghia
'65 singlecab
'66 sunroof beetle
'74 bus
'67 so-42
NOVA Airhead
PostPosted: Thu Jul 15, 2010 8:24 am    Post subject: Reply with quote
Down from the headlight - where the old opening is (center it on the opening) and yes centered on the headlight.
Ghia Owner Emeritus
analogmax
analogmax is offline
PostPosted: Thu Jul 15, 2010 9:08 am    Post subject: Reply with quote
here is what mine look like
[/img]
Ghiaddict
Ghiaddict is offline
PostPosted: Thu Jul 15, 2010 10:15 am    Post subject: Reply with quote
Here's a thread from a couple years ago:
http://www.thesamba.com/vw/forum/viewtopic.php?t=192060&highlight=bullet+conversion
And I wish I still owned that Olympic Blue '74. Crying or Very sad
Karmann Ghia & Beetle parts available.
Convertible tops installed.
NOVA Airhead
PostPosted: Thu Jul 15, 2010 12:27 pm    Post subject: Reply with quote
Here are mine. I also used the clear lenses.
Ghia Owner Emeritus
djkeev Premium Member
djkeev is offline
PostPosted: Thu Jul 15, 2010 4:51 pm    Post subject: Reply with quote
Ok, didn't take off the light but....
1969, I'm 3rd owner, I KNOW it is 100% original, unmolested.
I Removed the headlamp trim ring and it measures 1 1/8" from the center of the bezel screw hole to the TOP of the chrome bullet housing where it meets the rubber seal. This was an easy to measure exact dimension.
Hope this makes sense and helps you.
Dave
Ghia
Vanagon
Beetle
