rayzero Samba Member
Joined: July 14, 2010 Posts: 1 Location: Lake Elsinore
Posted: Wed Jul 14, 2010 9:12 am Post subject: 71 super fuel/carb |
Hello I'm new here so I thought I would give a little run down of were I'm at
I bought a 71 super beetle.
It's in great shape though the previous owner was a bit retarded when it comes to electrical
IE: used a bolt to join most power wires together and taped others on top of it.(all fixed now)
yesterday I had the engine out of it to do some cleaning and checking for missing bolts.
after I put it all back together there's air in the fuel filter and feels starved for fuel, does that mean I need to bleed the line or do I have a clogged line? it was running really well before I took it apart which makes me doubt the clogged line.
edit:
well I was checking out the bug i noticed there is now a big dime sized hole in the carb I think there's my problem, what used to be there? |
65tuxedo Samba Member
Joined: July 13, 2010 Posts: 30 Location: Grand Lake, Ok
Posted: Wed Jul 14, 2010 12:44 pm Post subject: |
You can usually see air in the clear filters. I've been reading lately that we should remove any filter between the fuel pump and carb because it is a fire hazard. Suggested was that the filter be put ahead of the pump for safety.
Good luck |
shanester Samba Member
Joined: November 15, 2009 Posts: 82 Location: florida
Posted: Fri Jul 16, 2010 10:17 pm Post subject: |
65tuxedo wrote: |
Good luck |
It's a good idea to route the choke wire under the carb also....it can short out and melt the fuel line.......
Also.. is your idle cutoff valve there? If it's missing the hole is about dime size or so.....pics of the hole may help too....good luck.. _________________ It's not a car... It's a cult. |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Sat Jul 17, 2010 5:42 am Post subject: Re: 71 super fuel/carb |
rayzero wrote: |
edit:
Is this what you are talking about (red arrow):
This is the pressure relief cover that blows out when the mixture ignites in the intake manifold (usually due to incorrect timing). If yours is missing, you will need to replace it or you will have a huge vacuum leak. Some have epoxied coins in there as a replacement... I'm not sure what the best solution is? _________________ AshMan40
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Cusser Samba Member
Joined: October 02, 2006 Posts: 31378 Location: Hot Arizona
Posted: Sat Jul 17, 2010 9:42 am Post subject: Re: 71 super fuel/carb |
rayzero wrote: |
There used to be a plug there. I had this happen once about 20 years ago, and jammed a rubber stopper from Ace Hardware in there. Others on this board were smarter and took that dime, and JB Weld-ed it to seal the hole. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
soundcatcher Samba Member
Joined: December 19, 2005 Posts: 162 Location: Horsham, England
Posted: Sun Jul 25, 2010 3:11 pm Post subject: |
I'm not sure what caused this fire damage.... But it's another reminder to take good care of your engine components. Fortunately the fire was extinguished before any real damage! I've since bought the car attached to this mess and the Malibu looks very different now!
