jingram Samba Member
Joined: March 22, 2006 Posts: 157 Location: where the streets have no name
Posted: Thu Jul 15, 2010 8:34 am Post subject: Barn beam bearings and bushings... |
Hey folks,
Any one have any advice on replacing worn needle bearings and bushings on a barndoor beam? Any tutorials out there? I did a search and came up with a ton of lowering/narrowing info of course, but nothing on refurbishing the beam components.
Also, anyone know a source for needle bearings and bushings? Are they the same for later split window buses?
I've got the Bentley manual, but it's a little sparse in this area. As always, any help would be greatly appreciated.
Thanks. |
bubblehead Samba Member
Posted: Fri Jul 16, 2010 5:15 am Post subject: |
If you are referring to the link pin needle bearings and bushes, then yes, 55-62 parts will fit. You can take the spindles out and press the bushings on a real press or in situ with an improvised puller using a couple sockets, washers, threaded rod etc. The Bentley should cover this but using the
VW tools. Just did this yesterday and it was pretty straightforward |
Posted: Fri Jul 16, 2010 8:44 pm Post subject: |
Thanks for your reply. I guess I should have been a little more clear. I'm talking about the big bushings that fit into the beam tubes that the torsion arms slide into. I guess there are no needle bearings inside of the beam tubes, just the bushings. How do I pull the worn bushings out and install new ones? |
Posted: Sat Jul 17, 2010 4:48 am Post subject: |
Yeah, wasn't really sure what you were asking. As far as I know, the torsion
bushings are the same as 55 and up and the factory parts list supports this. Needle bearings came much later, like mid 60's? I think R&R is covered in some of the beam narrowing threads. I'll probably need to do this as well;not really looking forward to it. |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1867 Location: Clearwater Fl.
Posted: Sat Jul 17, 2010 8:19 pm Post subject: |
I couldn't ge the address to work but go to snapon.com and type in cj2003a and search...it is gonna be the best way to remove the Bakelite bushings...they will need to be pressed back in...there were factory press tubes but god luck finding them...improvise...then they will need to be fitted or reamed after install...the factory tool had cutters and shaved them to fit one bushings at a time...takes a good six hours to re set up a beam...no needle bearings in a barn door...the best way to find some bushings is start waving cash around..they will surface....not cheap or easy venture...trust me.. _________________ www.blastserv.com
wanted:
RHD Barndoor floor mat..reproduction is fine |
Posted: Sat Jul 17, 2010 9:39 pm Post subject: |
Well thanks for the replys guys. I guess all I need are some really expensive tools (that I'll only use once) and some reaaallllyyyy rare parts and I'm in business.
We'll see how this goes.... |
Posted: Sun Jul 18, 2010 6:30 am Post subject: |
gatorwyatt wrote: |
I couldn't ge the address to work but go to snapon.com and type in cj2003a and search...it is gonna be the best way to remove the Bakelite bushings...they will need to be pressed back in...there were factory press tubes but god luck finding them...improvise...then they will need to be fitted or reamed after install...the factory tool had cutters and shaved them to fit one bushings at a time...takes a good six hours to re set up a beam...no needle bearings in a barn door...the best way to find some bushings is start waving cash around..they will surface....not cheap or easy venture...trust me.. |
No way I'd pay 500 bucks for that tool from SnapOn but does give me some ideas. As for the bushings, are you saying the available replacements don't fit? Maybe my bushings aren't as bad as I thought LOL! |
Posted: Sun Jul 18, 2010 7:01 am Post subject: |
You don't have to buy the whole kit just the right size adapter and slide hammer...I can give the correct part numbers needed as I have them...there is an alternative made by otc and much cheaper BUT it is a super rinky dink slide hammer and I can tell you from exp. If the bushings are tight still you won't get them out with the OTC unit...
The replacement bushings are like any bushings...they have to be reamed to fit...they won't fit otherwise...I fit my first beam with a stone hone one at a time and it took me a week or more to do because if you can imagine the hone had to be collapsed with a long screwdriver to fit into the internal size of the inner bushings then honed then test fit....lots of work..
I just did my factory installed beam for sunroof kombi and it was a little smoother because I used all the right tools but still took forever...the guy in the dealer that got handed the repair order to replace those bushings BITD was most likely to loose his ass that period...lol _________________ www.blastserv.com
wanted:
Posted: Sun Jul 18, 2010 7:04 am Post subject: |
The bushings most likely still good...but if you want to restore the beam and need powder coat it the bushings will not stay put when you bring the beam up to temp in the oven....also leaves spots for grease to hide and it will ruin your paint job... _________________ www.blastserv.com
wanted:
joe56vw Samba Member
Joined: June 24, 2004 Posts: 3202 Location: Olympia wa
Posted: Sun Jul 18, 2010 2:33 pm Post subject: |
gatorwyatt wrote: |
The bushings most likely still good...but if you want to restore the beam and need powder coat it the bushings will not stay put when you bring the beam up to temp in the oven....also leaves spots for grease to hide and it will ruin your paint job... |
sounds like a easier way to pemove them to me _________________ '60 15 window walkthrough
why is there no sarcasism button on here? |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10198 Location: Petaluma, CA
Posted: Sun Jul 18, 2010 3:19 pm Post subject: |
If you want to send the beam to Washington state I have NOS bushings and the factory tools to do the job. |
runewo Samba Member
Posted: Thu Jul 22, 2010 2:09 pm Post subject: |
Could the later needle bearings be used in the barndoor beam?
If so you would save yourself from the reaming.. But they are maybe hard to get? _________________ 54 Barndoor panel
54 Oval window
49 Split window bug
73 Porsche 911 |
Rusting Hulk Samba Member
Joined: August 20, 2002 Posts: 646 Location: Malvern UK
Posted: Fri Oct 23, 2020 4:05 am Post subject: Re: Barn beam bearings and bushings... |
Rather than starting a new thread.....
Are there any stock barndoor repro beam bushes available anywhere? Has anybody had any made in a different material i.e. Delrin or Bronze? How does that work with the arms?... I'm thinking about getting some made, but if they are already out there?
Thanks for any info. _________________ 64 356 C Coupe |
Posted: Fri Oct 23, 2020 6:12 am Post subject: Re: Barn beam bearings and bushings... |
I believe that Nate @ Wagenswest has a new replacement bushing Made of a more modern material now. Barndoor is the same as early bus. _________________ www.blastserv.com
wanted:
Posted: Fri Oct 23, 2020 11:04 am Post subject: Re: Barn beam bearings and bushings... |
Thought about it...
I should have said, I’ll tell you wankers how to source beam bushings if you tell me where I can get a bloody floor mat _________________ www.blastserv.com
wanted:
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 878 Location: Cornwall, UK
Posted: Fri Oct 23, 2020 2:26 pm Post subject: Re: Barn beam bearings and bushings... |
I believe Matt Smith makes all year barndoor cab mats. Is that what your after? _________________ 1951 Samba 20-017894
1952 Samba 20-028952 |
Posted: Fri Oct 23, 2020 2:29 pm Post subject: Re: Barn beam bearings and bushings... |
PM sent _________________ www.blastserv.com
wanted:
Posted: Sat Oct 24, 2020 10:27 am Post subject: Re: Barn beam bearings and bushings... |
Todd, thanks for the info, i will contact Nate, i did see them on his website but wasn't sure they were the correct size.
If i see or hear of a mat will let you know.
Simon _________________ 64 356 C Coupe |
Posted: Sat Oct 24, 2020 3:22 pm Post subject: Re: Barn beam bearings and bushings... |
Of course, Simon!
The factory bushings or aftermarket ones I would think if pressing them in are going to need to be fitted to the trailing arm to have a non sloppy fit. I know nothing of the Wagenswest units and know Nate makes a nice product but the factory ones are available on here for sale right now. Reaming them is the biggest headache you face but it can be figured out.
Please shoot me a message if a mat floats by!! I’m 13 years deep into looking. _________________ www.blastserv.com
wanted:
Clara Samba Member
Posted: Mon Oct 26, 2020 5:02 pm Post subject: Re: Barn beam bearings and bushings... |
Rusting Hulk wrote: |
Thanks for any info. |
If you want to send the beam to Greg in California, he has NOS bushings and the factory tools to do the job.
contact campingbox |
