scottjk Samba Member
Joined: May 31, 2006 Posts: 485 Location: Salt Lake City, UT
Posted: Sat Jul 17, 2010 11:13 am Post subject: Fuse Panel Layout - 1985 Westfalia? |
I've located what appears to be the circuit that is draining my battery. While digging through the Bentley pages 97.61 through 97.66 I don't see the panel layout like I do on page 97.67 for the 1986 and newer. Can someone point me to a fuse/relay panel diagram for the Digijet 1985 model?
The fuse in question is eight spaces from the left. I suppose tonight I can turn everything on and find out what isn't working with that fuse out but I'd really like a panel diagram.
Thanks
Scott _________________ 1985 Westfalia 2.5L EJ |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9797 Location: Mt Lemmon, AZ
Posted: Sat Jul 17, 2010 12:12 pm Post subject: |
The owners manual for my '84 shows fuse #8 as being for "interior lights, cigarette lighter, stop lights".
On an 84 the fuses are numbered 1-12 left to right.
Could be some other things on that circuit too, esp owner-added items such as a radio or additional interior accessories since that is a handy connection when you need an always-hot circuit. |
Posted: Sat Jul 17, 2010 12:37 pm Post subject: Owners Manual |
I actually just looked at my owners manual and it is the same. I forgot I had the doors open when I was taking my readings and it was the dome light that was causing the draw.
What type of drain are you guys experiencing with your vanagons. Looks like mine is around 100-200 milliamps if I'm reading my meter correctly. I need to go to digital meter reading school.
Jamos Samba Member
Joined: July 08, 2005 Posts: 762 Location: Lake Tahoe, CA
Posted: Sat Jul 17, 2010 1:45 pm Post subject: |
For a fuse panel layout for digijet and digifant, as well as lots of other info, check out:
http://vanagonparts.com/home.html
technical section > electrical _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
markj1693 Samba Member
Joined: February 08, 2014 Posts: 2 Location: Washington
Posted: Fri Jun 19, 2015 11:29 am Post subject: |
Where can i find a Relay layout for my 85? |
thatvwbusguy Samba Member
Joined: April 18, 2007 Posts: 1712 Location: Newmarket, New Hampshire
Posted: Sat Jun 20, 2015 4:24 am Post subject: |
Bentley 97.10
Left to right:
1) Turn signal / emergency flasher relay
2) Vacant
3) Load reduction relay
4) Key in buzzer
5) Intermittent wiper relay _________________ Jay Brown
'85 Zetec Westfalia
Newmarket, NH
If you want others to be happy, practice compassion.
If you want to be happy, practice compassion. |
