whirlpool Samba Member
Posted: Sat Jul 17, 2010 5:11 pm Post subject: Engine vs bodywork |
Novice advice needed please. (not sure if this is the right forum for this topic)
What is recommended, doing the bodywork or engine first?
Engine was in pieces and the car was stripped right down. I have a puzzle here that is going to require a lot of time to sort out.
Either way I have so much to learn.
Thanks |
coad Samba Scapegoat
Posted: Sat Jul 17, 2010 6:25 pm Post subject: |
Body first.
3 month body projects tend to turn into 6 month projects, then 9, then 12 and so on.
Why tie up money in an engine that's just going to sit there? |
Posted: Sat Jul 17, 2010 6:44 pm Post subject: |
Thanks Coad
truth is I was sure that was going to be the answer and the whole body work stage is intimidating me.
* edit* scratch question below! I need to learn how to search - ha!
this more than answers my own question
http://www.thesamba.com/vw/forum/viewtopic.php?t=161127&highlight=storing
Another novice question. (I did a search but after pg 9 of 121 and much digression I decided to ask )
what is the best way to store the engine items that will rust. I wanted to bag them in ziplock plastic bags with some oil but I am not sure what that could do to the parts in the longer 12+ month during the body work time. Also, what to do with the tin and larger parts like the fan housing etc.
again thanks |
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Sun Jul 18, 2010 7:36 am Post subject: |
CRC, makes a Cosmoline protectant in an aerosol can.
"Heavy Duty Corrosion Inhibitor" "Marine"
It is like a wax. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Sun Jul 18, 2010 8:04 am Post subject: |
Thats great thanks Russ. I will look out for it.
As my path is now set for body work, I guess it is going to be a while before I get around to the engine. |
PressureProjex Samba Member
Joined: August 07, 2008 Posts: 234 Location: tri-city michigan
Posted: Sun Jul 18, 2010 10:17 am Post subject: |
Also its nice to get the hard, messy part done and over with. Once your finished with the body its mostly just assembly. |
Posted: Sun Jul 18, 2010 10:23 am Post subject: |
"assembly" and money to buy the shiny bits
I just found a rattle! called rust in my fuel tank |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17968 Location: Eugene, OR
Posted: Sun Jul 18, 2010 12:06 pm Post subject: |
I would start on the engine/chassis in the garage. Put the body outside on sawhorses under a tarp or leave it on while you get it running/driving in the garage. Bodywork/paint comes Last in my Book. _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
sixty1ragtop Samba Member
Joined: August 11, 2008 Posts: 132 Location: Warrenton, VA
Posted: Sun Jul 18, 2010 12:38 pm Post subject: |
My .02 cents is to get any body work done that makes it unsafe to drive. Thats my plan. Floor pans and heat channels, then motor, then cosmetic body work. That way I can drive it safely while I tinker it back to its glory days. |
Posted: Sun Jul 18, 2010 1:20 pm Post subject: |
I am lucky... it is a "toy" and not required to become a daily driver just yet. I plan on having it as a daily driver for my younger sons in a few years. I am also hoping I can generate enough interest, to pull them away from that ruddy playstation!
Cosmoline and then body work and I hope I can finish in time |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32586 Location: Reading Pennsylvania
Desertbusman Samba Member
Posted: Sun Jul 18, 2010 3:00 pm Post subject: |
Only one way to do it. Pull the body off the pan. Then you have 2 projects. Get all the mechanicals done on a rolling pan. The very last step is putting the body back on once both are totally ready to go. It's by far the easiest way.
_________________ 71 Superbug
71 Westy |
Posted: Sun Jul 18, 2010 9:17 pm Post subject: |
Desertbusman wrote: |
that is a great way to rotate the chassis; I think I will asking you a few questions later.... |
kingd33 Samba Member
Joined: June 03, 2004 Posts: 467 Location: Grand Rapids Michigan
Posted: Mon Jul 19, 2010 2:49 am Post subject: |
I do the chassis first so I can sit the body on it if I need to for alignment purposes,engine is last. |
Bezzer Samba Member
Posted: Thu Jul 29, 2010 10:27 am Post subject: |
I always do all mechanical first, make sure everything is in place and working. THEN I do the body work.
I would rather drive a rat rod that runs than sit in a painted flower pot THAT WON'T WORK. |
