was the bus going under or over 100mph |
under 100mph |
57% |
[ 29 ] |
over 100mph |
20% |
[ 10 ] |
see it, but still don't believe it |
22% |
[ 11 ] |
Total Votes : 50 |
vw76westy Samba Member
Posted: Sun Jul 18, 2010 2:34 am Post subject: 100 mph yes or no |
So when I tell people that I have reached 100mph
In my 76 westy with a stock 2.0 engine & stock 091 tranny
They think im full of it
So one day while driving I pulled out my phone & got the proof
http://www.youtube.com/watch?v=mm8X0djmswk
the question is if the needle only goes to 90
do you think i was going just under 100 or just over 100mph _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
quote from bay window bus buyers guide........
The Type 4 engine is considered by many to be VW's finest air-cooled motor, |
Randy in Maine Samba Member
Posted: Sun Jul 18, 2010 2:44 am Post subject: |
What size tires? |
Posted: Sun Jul 18, 2010 2:52 am Post subject: |
at the time 195-70-14 _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
WestyPop Samba Member
Joined: February 08, 2005 Posts: 1732 Location: SoCal
Posted: Sun Jul 18, 2010 3:49 am Post subject: |
Really... the "typical" 195/70-14 would be turning about 3% more revs per mile than the oem-sized Vanco 185R14. Add to that the tendency of a lot of buses (& other vehicles, too) to be 2-3% optimistic, and it's anyone's guess... somewhere between 90 and 100mph.
In the interest of public safety, and your own, please don't feel you have to post a back-up video of your speedo reading an apparent 110mph, unless it's on a race track. (I'll be driving through that same section of I-10 today in a car that can easily break 150mph... but we'll be on cruise control @ 70mph. It's safer, I can't afford the ticket, and my wife won't divorce me!) _________________ Never underestimate the power of stupid people in large groups.
______________________________________
J.R.
68 Westy
(+ others) |
Posted: Sun Jul 18, 2010 3:53 am Post subject: |
A lot faster than I would want to be driving on substandard car tires.
Last edited by Randy in Maine on Sun Jul 18, 2010 8:17 am; edited 1 time in total |
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Sun Jul 18, 2010 4:34 am Post subject: |
Let's see, my speedometer was calibrated by a speedometer shop as I knew it was off by 5 miles because of my tires size. Went out one day and did 109 mph at Thunder Valley. The Bus was still accelerating when I decided to let off the throttle. _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
Posted: Sun Jul 18, 2010 4:56 am Post subject: |
Comparing your speed to that of the trucks and other traffic, I would say about 75 mph. |
Derek Cobb Annoying
I occasionally hit the high 90's in my 74 (according to my speedo) so I have little doubt that you could break 100 mph in your 2.0.
It never felt unsafe or squirrely, but I still wouldn't make a habit of doing it. |
fusername Samba Member
Joined: March 15, 2006 Posts: 2897 Location: Boston MA
Posted: Sun Jul 18, 2010 6:31 am Post subject: |
with my high output 2.0, in a full westy, it takes a full head of steam and a hill to hit 90, and at that point i am turning 5k. I have larger tires so the speedo is actually dead accurate, if it says 80 im doing 80, as checked by GPS. with smaller tires you would be closer to 6k to hit 100mph. thats pretty loud. and do you have a tach _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Mal evolent Samba Member
Joined: March 31, 2009 Posts: 2912 Location: San Antonio, Nuevo Mexico
Posted: Sun Jul 18, 2010 7:14 am Post subject: |
Speed in MPH = RPM X LRTR / GR X 168
Where LRTR = Loaded Rear Tire Radius and GR = Gear Ratio ( 4th gear X R&P )
Diameter of a 195-70 R14 = 24.75"; radius is half of diameter
Speed in MPH = RPM X 12.375 / 4.56 X 168
Speed in MPH = RPM X 12.375 / 766.08
Speed in MPH = RPM X .01615367
Therefore
RPM = MPH X 61.905455 ( 1/.01615367)
So RPM would be 6190 at 100, with a 1:1 4th gear ratio.
A 76 should have a .889 4th gear ratio. If 4th gear is .889, it would be 5503 RPM at 100 MPH _________________ 73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index |
Posted: Sun Jul 18, 2010 7:18 am Post subject: |
however those calculators I have discovered are WAAAAAY off all the time, they go off of ideal tire diameter, mfr always specks about .3 inches smaller than the actual size, and then you have shrinkage from the weight of the car flattening the tire. basicly those calculatos are useless. Ihave been trying to design a new trans based on my current tires and new ones, and it has always been off by HUGE amounts. _________________ [email protected]
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21513 Location: Oklahoma City
Posted: Sun Jul 18, 2010 7:43 am Post subject: |
So I'm just looking at this. You need to post your 4th gear and final drive ratio.....and your rpm at 100 mph.
Your 195/70-14's have a circumference of 6.479' in diameter. With 5,280 feet per mile that would be 814.9 rear wheel revs per miles...at best with no sidewall crush or slippage. That means at 60 miles per hour your rear wheels ate turning at 814.9 revs per minute.
At 100 mph....thats 1.666 miles per minute at 1303.84 wheel revs per minute.
I have no idea what your 4th and final is. Just pulling out of my haynes for 73 and later bus....lets call it for the moment a .89 4th and a 1:4.85 final drive?
So for every 1 rev of the wheel it takes 4.85 revs of the engine. Before 4th gear reduction it would mean .....at 100 mph your engine is turning 6,323.6 rpm. Reduce input by the .89 = your engien was turning at 5,628 rpm.
Being that the 2.0 bus engine put out marginally more ...and possibly less...hp than the 1.7L in my 412....and the bus has 2.3 times the weight, 12 times the surface area and the aerodynamics of a brick......I doubt you are at 100 mph with a stock engine.
Is it possible to be at 100 mph in a VW bus?...easily! They have been doing it on the autobahn for ages.
There was an article years ago about the fleet of vanagons Porsche had in their stable with 6 cylinder engines that they used to shuttle their execs to group meetings at 100+ mph.
It is actually common for speedos like we use in VW's to read way off as they get toward the end of their scale. I'm betting from the video that you are at about 80 mph. Ray |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3566 Location: viroqua wi.
Posted: Sun Jul 18, 2010 8:14 am Post subject: |
From looking at the video it looks like your tach. is reading under 4000, that makes no sense. But looking at the speed that your overtaking people, except the guy in front of you I'd say your doing close to 90 |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4536 Location: Arizona Highways
Posted: Sun Jul 18, 2010 8:15 am Post subject: |
"i ain't got no crystal ball" either. but i don't envision your engine lasting very long. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Sun Jul 18, 2010 10:32 am Post subject: |
well anybody who drives on the 10fwy threw the
palm springs area of CA
knows that the avaverge car speed is 75-80 mph
and that most cars in the fast lane are going 85-90mph
(i ask anyone from the palm springs area to confirm or deny this)
my speedo has been checked a few times at speeds up 55mph
& it was dead on every time
twice it was compared to the speedo of a friends car at 75 mph
while driving on the freeway & it was spot on
Quote: |
If you want to play race car go to a race track |
do you mean like this
top speed was 48 mph, running 14.20sec in the 1/8th mile (not 1/4mile)
the speedo has been spot on compared to my top speed at these events
Quote: |
So I'm just looking at this. You need to post your 4th gear and final drive ratio |
the tranny currently in my bus is a used tranny that came from
a doner bus,so i assume that its stock,as it does not feel any differant
from the tranny before it
the rpm's does leave a question mark for me
at all my shift points the highest my rpm's get is 3k (1st@10mph,2nd@30mph,3rd@50mph)
but when i first started driving my 75 auto & i saw the rpm's go to4k
i was blown away that that the rpm's can go that high
after alittle reading it seems that 4k is normal
but after 70k miles of driving 2 engines & 2 tranny later
the tach wont reach 4k rpms even at these 100mph speeds
can anyone explain this to me.... _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Derek Cobb Annoying
Posted: Sun Jul 18, 2010 10:46 am Post subject: |
Get a GPS and use that to settle this bickering contest. Most of them will give a MPH output independant of the tire size, final drive ratio, speedo inaccuracies, tachometer miscalculations, aerodynamic anomolies or ego satisfying inflations.
You don't actually have to try and crack that 100 mph barrier again to prove or disprove anything, just roll it up to 80 or 90 and compare the readings. Either they are the same or they aren't. |
Posted: Sun Jul 18, 2010 11:07 am Post subject: |
My original reason for starting the thread was
to discuss how accurate the Speedo is past 90mph
if the needle moves 3/4 of an inch for every 10mph (more or less)
then that would mean that when the needle is pointing to the vdo
im going more than 100mph
I believe my Speedo is accurate up to 75-80mph
as I compare it to friends & family cars on every road trip
& on the track at fontana & irwindale speedways
im used to this denial from people
(Especially my non-vw family & friends)
until they get in & we go somewhere _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
Posted: Sun Jul 18, 2010 11:29 am Post subject: |
Derek Cobb wrote: |
Most GPS...unless they are specifically set up and corrected to read out ground speed as one of their major functions.....are not accurate. I know mine reads about 4 mph slow as checked between set road marks with a stop watch.
Ray |
Derek Cobb Annoying
Posted: Sun Jul 18, 2010 11:37 am Post subject: |
raygreenwood wrote: |
Derek Cobb wrote: |
Ray |
Then I suppose we'll just have to wait until he gets a ticket.
I'm satisfied that it's entirely possible to hit these speeds in a Westy from my own experiances. Once I reviewed the video I did notice the wind turbines pumping away, so the possibility of a favorable tail-wind lends even more creedance to this claim, in my humble estimation. |
Posted: Sun Jul 18, 2010 11:58 am Post subject: |
on any given day i can reach 90 mph on a flat highway
& i did take several video clips from LA to palm springs
going 90 & flying past 65-70 mph traffic
(if you want to diesect the video's for more clues of my speed
ill post these clips later)
but every time im on this piece of highway
im able to make the needle point to the vdo
going east only
when im going to LA on this part of the 10fwy
my top speed is 65-70 & it feels like im going up hill
i know that the wind is helping & that the road has to be
at a slight (unnoticable) down hill
because 85-90 is my average top speed _________________ order your BAY WINDOW T-SHIRT here http://www.thesamba.com/vw/classifieds/detail.php?id=1526918
