Mang Samba Member
Joined: November 19, 2011 Posts: 114 Location: Omaha, NE
Posted: Sun Apr 15, 2012 8:53 pm Post subject: |
Kiwi dye (not polish) on my upper & lower grill. Sanded down the silver paint first, and hit the whole thing with TSP.
I'm pretty happy, although I must admit the pics make them look better than they are - up close you they're still a bit blotchy. Another coat perhaps.
Went ahead and did the plastic bumper ends, those turned out good as well.
_________________ '87 Westy 2.1 WBX |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Sat May 11, 2013 8:04 am Post subject: |
For those who went the Forever Black (or similar non-paint) route, how did you remove the silver trim paint, or did you re-paint the silver?
I'm going to install a rd. headlight grill and I don't want the (faded) silver trim. Of course, if I paint the grill, it doesn't matter, but I was thinking of trying the Forever Black method to re-hab the grill instead. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 7757 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Sat May 11, 2013 9:08 am Post subject: |
vanagonjr wrote: |
... how did you remove the silver trim paint...? |
Mine was faded/worn enough that the remainder came off with just an old scotchbrite pad.
Any fine grit sandpaper would do (220 or smaller) and still finish up nicely. _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
syncroid Samba Member
Crankey Samba Member
Posted: Sat May 11, 2013 12:39 pm Post subject: |
vanagonjr wrote: |
I'm going to install a rd. headlight grill and I don't want the (faded) silver trim. Of course, if I paint the grill, it doesn't matter, but I was thinking of trying the Forever Black method to re-hab the grill instead. |
I think it's best to paint the grill. it's hard plastic so paint sticks to it fairly well.
to paint the grill I used Krylon primer and satin black paint. it looks fine after many years.
for the flexible air dam and bumper caps I used Forever Black and that worked well. obviously its not good forever, it gets dirt/dust and the dye fades after a couple years. but it's easy to put on and at 2 year intervals it's close enough to forever for me. I just don't like the idea of peeling paint on the air dam and I do think most paint will peel off that. [/img] |
Bman Samba Member
Joined: April 28, 2005 Posts: 895 Location: South Coast, Oregon
Posted: Mon May 20, 2013 9:13 am Post subject: |
So I tackled a small experiment project this weekend to test a product and learn what I need to do to do it better. My Wife's Bday is approaching this week and I wanted to do something for her and her 1989 T3 van. She is a Peace loving soul so I always wanted to get one of those GoWesty peace emblems for her van; however the GW peace emblem only fits a 86-87 square headlight grill the 88-91 has a LARGER emblem. OK so I got her a used one from a friend.
At first I was going to use the Krylon trim paint, but I stopped by my local auto paint store and they frowned on that and recommended this:
First I washed the grills with simple green
Then I spent about 2-3 hours over a few days dry sanding the grills, first with 400 grit.
I washed the grill with a degreaser solution, let dry
Then did a second sanding (about 2 hours) with 1000 grit, again washed with the degreaser
Then I was going to follow someone's advice on here to use ACETONE to do a final wash. STOP DO NOT USE ACETONE, IT WILL DISSOLVE YOUR PLASTIC!
A quick drying and re-sanding the test area I ruined with the acetone, degreaser wash again.
I then used a toothbrush and MINERAL SPIRITS to give the grills a final wash to get all the dirt and grime out of the corners.
Dry and then paint with the above product:
I am very happy with the results and think this Spray Max 1K trim paint is great stuff, the final finish feels like it is part of the plastic not a paint job.
Things I would do different:
Put a layer of primer on so I could see the imperfections and then sand again before placing finish paint on. _________________ ~Bryan
1990 Burgandy Tintop (Wife's Daily Driver)
1989 Tiico Westfalia "Taj"
2WD Doka build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=503578&highlight=
FaceHook:
https://www.facebook.com/pages/VW-T3-DokaSinka/129026087217120?ref=hl |
Posted: Mon May 20, 2013 9:30 am Post subject: |
Bman wrote: |
I see that is sold in Satin, Matt and Gloss (all with same P/N )
Which one did you use? _________________ John - 86 Wolfsburg Westfalia "Weekender"
Bman Samba Member
iiigoiii Samba Member
Joined: January 05, 2008 Posts: 307 Location: Bay Area, CA
Posted: Mon May 20, 2013 10:06 am Post subject: |
Bman wrote: |
Put a layer of primer on so I could see the imperfections and then sand again before placing finish paint on. |
remember though that the trim paint is probably formulated specifically to stick to plastic, not necessarily to primer. so - i'm thinking you did the right thing by not using primer.... _________________ 1984 Westfalia Wolfsburg Ed. w/ Subaru EJ22 power |
nemobuscaptain Samba Member
Posted: Mon May 20, 2013 12:40 pm Post subject: |
iiigoiii wrote: |
...remember though that the trim paint is probably formulated specifically to stick to plastic, not necessarily to primer. so - i'm thinking you did the right thing by not using primer.... |
Agree, just had a nightmare this weekend using primer on a product I've used many times w/o primer only to discover it was incompatible with primer!
Note that they do sell an adhesion promoter for plastic on their website. _________________ John - 86 Wolfsburg Westfalia "Weekender"
Bman Samba Member
Posted: Mon May 20, 2013 3:53 pm Post subject: |
^^^^^Good to know thanks. At one point I considered if I should do it, but after all that time on sanding and cleaning I thought: "Good Enough!"
The primer issue came up while talking to my neighbor after showing him the project and he went on how you can really see the imperfections on the object after priming it and how you can get a further 'finished" look.
However you bring up a real good point above whether it is necessary. _________________ ~Bryan
FaceHook:
fraggle00 Samba Member
Joined: October 19, 2011 Posts: 356 Location: Bristow, VA
Posted: Fri Nov 29, 2013 4:22 pm Post subject: |
If you want to skip painting, I've been using the Adams VRT. It's a lot better than the back to black, and actually smells nice! _________________ '91 Vanagon Carat
'87 Porsche 928S4 DOWN
'12 Fiat 500 Abarth |
canasync Samba Member
Posted: Fri Nov 29, 2013 11:56 pm Post subject: |
I first heard of this in the video below. I have not tried this myself as I was quite skeptical but since then I have talked to a couple people that swear by it.
keep in mind that these products are meant to treat black plastic which was molded in black. So I don't think that the results would be very good on a painted surface.
If anyone has any feedback on this stuff let us know. Think I may give it a try sometime.
_________________ 1987 Syncro
3 knobs
PumpeDüse TDI (17mm Garret Turbo, bigger injectors, stage 4 malone tune, intercooled)
Cruise Control
Remote Start/locks
Custom Lift
Custom Bumpers with receivers
Coast Mountain Hightop - Comming Soon
1985 2wd Vanagon Pre-runner in the making
soon to be powered by 2.5L Subaru
Custom Lift |
costal_cat Samba Member
Posted: Tue Dec 03, 2013 5:19 pm Post subject: |
canasync wrote: |
This is great I used it on my dad's golf cart and a 2003 530i trim. It is for plastic molded items. BUT BUT and this is the key, it needs to really dry for 24 hours with no water or moister or it spots bad and is hard to reapply. So if you have the car outside overnight and you get dew or condensation in that area it is a problem. I know i did this with the golf cart first time, but got a replacement part from a shop..
If you can keep the car or piece in the garage overnight you are golden. Just follow the instructions, it comes with sponge, gloves and prep material dont take any short cuts and it works fine _________________ 87 Syncro Westy
TDI Overland Parts engine conversion |
thatguydave Samba Member
Joined: April 15, 2015 Posts: 19 Location: Puget Sound
Posted: Mon Dec 18, 2017 8:35 pm Post subject: Re: Best Product for restoring the plastic parts on the exterior |
Bman - Thanks for suggesting Spray Max. My upper and lower grilles look like new! BTW I sprayed Krud Krutter as a degreaser and after drying did not need the mineral spirits.. _________________ -Dave
'91 Weekender w/FAS Conversion |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Jun 15, 2021 4:56 pm Post subject: Re: Best Product for restoring the plastic parts on the exterior |
I am about to tackle this job. I absolutely love Spraymax products so I ordered a can online for about $18 shipped. I plan to use 3m scotch pads and a dregreaser to rough up/prep the surface.
I do remember I have some cracks in my plastic. Not in the paint. Any recommendation for a plastic filler for that? _________________ Brandon
Instagram @joannthevan |
