cwaty Samba Member
Posted: Sun Jul 18, 2010 10:31 am Post subject: EMPI Distributor Problem |
Just installed EMPI distributor with performance wires, had installed dual carb kit a year ago and finally got around to replacing the distributor to get rid of the vacum advanced, now thear will not start, just keeps turning over flooding the motor
The Car is a 68 Beetle with a 1600cc dual port
Help would greatly be appreciated, first time restoring a classic bug, having a blast doing it even though tough
Thank You |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Sun Jul 18, 2010 10:43 am Post subject: |
Have you check to see if you're getting spark at the points?
Pop off the distributor cap, turn the ignition to "ON", and open the points contact, if you see a spark jolt, you have power going to the distributor.
Is the points gapped properly?
Do you have the condensor wire (typically green) going to the negative side of the coil (marked as "1")? _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76949 Location: Sneaking up behind you
Posted: Sun Jul 18, 2010 10:59 am Post subject: |
Are you sure you have the ignition wires on correctly? The location of #1 is different.
_________________ Glenn
Member #1009
#BlueSquare |
cwaty Samba Member
Posted: Sun Jul 18, 2010 2:04 pm Post subject: |
havent checked to see if there is a spark, only one working on it so i would need a second pair of hand which will have to be another time, and i havent checked the cap yet to see where one is, which i will need to do that, i apreciated the replies and will let you know of the results in a couple of day
Thank you |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sun Jul 18, 2010 2:08 pm Post subject: |
You don't need a second set of hands to check for spark. You can use a popsickle stick or etc to move the points apart as suggesest above . I prefer to rotate the engine by turning the generator nut. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
cwaty Samba Member
Posted: Sun Jul 18, 2010 2:16 pm Post subject: |
i'll have to try that thank you for the reply, will let you know how it goes |
