whirlpool Samba Member
Posted: Sun Jul 18, 2010 4:59 pm Post subject: Moving 'your' body around.... |
I have seen some really good looking 'dollies' that have wheels and can carry the body around on. Anybody have plans for such a device or any advice in knocking one together? I am concerned about stability but also want the functionality of being able to work around it, painting etc
Any ideas on how I can single-handedly move the body off and on between the 'dollie' and the chassis?
thanks |
anthracitedub Samba Member
Posted: Sun Jul 18, 2010 6:57 pm Post subject: |
I would suggest you get 3 friends to help set the body…its not a one man job. while I have heard of a single person setting a body on their own (Mike, you know who you are) you could hurt yourself lifting it by yourself….I jacked my lower back up while trying to lift the rear of my Ghia up on my own….put me out of the game for a couple of weeks. |
blarneyman Samba Member
Joined: February 06, 2005 Posts: 1622 Location: Everson/Bellingham, WA
Posted: Sun Jul 18, 2010 7:54 pm Post subject: |
I saw a pretty cool device in a shop once. It was 2 "A" frames with a pipe beam between them. The legs of the A had wheels and the cross bars of the A were made out of heavy chain. It could be folded up and pushed against the wall for storing. _________________ 69 Beetle
70 Ghia(resto) |
fred69vert Samba Member
Joined: August 17, 2007 Posts: 2200 Location: Home of the US Navy Atlantic Fleet, Norfolk, VA
Posted: Mon Jul 19, 2010 6:20 am Post subject: |
When I started the work on my 69 'vert, I originally used the 4X4 sawhorses that are shown in the BugMe Video. Made the sawhorses wide enough (6 1/2 feet) so that the pan (with tires) would roll underneath. I lifted the car single handedly, using two come-a-longs with nylon lifting straps hanging from the ceiling joists in my garage. Worked like a champ, but I found a problem with the sawhorses. I couldn't move the body. So i came up with a different solution.......
I went to Harbor Freight and bought eight large pneumatic tire casters. Went to Lowes and got some 4X4 metal brackets and some 2X6's.
Frist I built a dolly for the pan, a rectangle out of 2X6's with four of the casters. Then I made the dolly for the body. Two long 2X6's with the casters on each end, then 4X4 uprights and 4X4 crossmembers that fit underneath the body. Made it wide enough to slide the pan on its dolly underneath.
Wish I had pictures but sadly, I have none. A little ingenuity goes a long way. _________________ I'm not losing my hair, it's just retired and relocating further south.
1969 VW convertible, "Heidi" |
mlhsquared Samba Member
Joined: October 13, 2008 Posts: 1482 Location: Strasburg, VA
Russ Wolfe Samba Member
Joined: October 08, 2004 Posts: 25187 Location: Central Iowa
Posted: Mon Jul 19, 2010 8:47 am Post subject: |
Not everybody reads the "Ghia" forum. _________________ Society is like stew. If you don't keep it stirred up, you end up with a lot of scum on the top!--Edward Abbey
Gary: OK. Ima poop. |
Posted: Mon Jul 19, 2010 9:56 am Post subject: |
Rather than use the expensive car wheel dollies, I use the 1000 lbs movers dollies from Harbor Freight.
http://www.harborfreight.com/movers-dolly-93888.html
I have loaded cars onto trailers, that did not have a front axle under them. Have yet to break one.
Jeckler Samba Member
Joined: September 27, 2005 Posts: 2718 Location: Mesa, AZ
Posted: Mon Jul 19, 2010 10:43 am Post subject: |
I built this one based on the pics I saw here, after reading the Ghia forum.
Went down to Lowes for the wood and the casters are from HF. I tend to built this stuff in my head as I'm standing in the lumber aisle, so have no plans, but it should be easy enough to figure out. It has to be tall enough to clear the shock towers and wide enough to clear the tires. I couldn't build mine tall enough to clear the shifter and still be able to roll the body under the garage door, so keep that in mind. I could've built it longer so that the body is supported from the fender wells, but my cost would've gone up. As it ws, I think this cost about $100.
_________________ Andy
'63 Bug rebuild here.
Did you know that sellers can't charge a fee to accept PayPal?
bill may wrote: |
I am the crabby old guy. |
Knowledge is knowing that a tomato is a fruit.
Wisdom is knowing not to put it in fruit salad. |
Posted: Mon Jul 19, 2010 12:51 pm Post subject: |
Russ Wolfe wrote: |
Not everybody reads the "Ghia" forum. |
Well, maybe they should! Just kidding.
I just posted the links here trying to help. The first link has good info. on what lumber is needed, measurements, etc...
Enjoy! _________________ Mike
'67 Ghia Coupe |
Posted: Mon Jul 19, 2010 1:08 pm Post subject: |
Here is the one I built, that will carry the whole car.
Surplus dunnage from work,and the base was going to be thrown away.
Cost?? Just my time.
Posted: Mon Jul 19, 2010 7:53 pm Post subject: |
WOW
spend the day working and I have a bit of catching up to do!
Thanks folks; that is exactly what I needed and Jeckler's photo shows me exactly where the support needs to be for the Beetle.
dolly not dollie helps the search
this website rocks! |
Posted: Mon Jul 19, 2010 7:54 pm Post subject: |
Russ Wolfe wrote: |
whats a gear? |
Posted: Mon Jul 19, 2010 8:32 pm Post subject: |
whirlpool wrote: |
Russ Wolfe wrote: |
whats a gear? |
Geesh, try to help a brother out and even get sh*t from the OP. Uh... you're welcome... I think??? _________________ Mike
'67 Ghia Coupe |
Posted: Mon Jul 19, 2010 8:45 pm Post subject: |
mlhsquared wrote: |
Geesh, try to help a brother out and even get sh*t from the OP. Uh... you're welcome... I think??? |
it is only because of envy - I WANT... a fully restored GHIA. I saw one the other day for sale at $25k, fully restored but tastefully converted to EV.
g |
Posted: Tue Jul 20, 2010 10:24 am Post subject: |
Jeckler wrote: |
Good picture, looks like mine, except that I used metal brackets on the corners and larger pneumatic casters (from HF) because my garage floor is not smooth and I also have to pull the body outside (sometimes on the grass) to move things around. These are the casters I used
Note: if they lose air, squirt a little Slime into them and that will fix it. _________________ I'm not losing my hair, it's just retired and relocating further south.
Greezy Joe Samba Member
Joined: April 12, 2010 Posts: 1534 Location: Crawfordville, Fl
Posted: Thu Jul 22, 2010 9:52 pm Post subject: |
Russ Wolfe wrote: |
You have to be part of the Elite to read it
Thanks for the post on the big Pnuematic wheels, I too will have to roll my Ghia Vert onto the grass from time to time..To the OP good luck with your project. _________________ Current:74 Ghia Coupe w/ 2276
71 Ghia Vert w/ 1835
07 GMC Truck
12 Jeep Wrangler
73 Harley FLH 93 cid
89 Harley 883 Sportster (1200)
Owned before: 58, 69 Ghia Coupes, 64 Canvas Sunroof, 68, 72, 73, & 74 Bugs, 63 Single Cab, 65 Bus, 66 & 70 Camper
" Duct tape can't fix stupid, but it'll muffle the sound". |
